标题: 单片机秒表(程序) [打印本页]
作者: 新乡工程学院    时间: 2021-12-13 23:18
标题: 单片机秒表(程序)
#include <reg52.h>
unsigned char table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
sbit ge=P0^0;
sbit shi=P0^1;
sbit key0 = P1^5;
sbit key1 = P1^6;
sbit key2 = P1^7;
uint num = 0;
bit key0_enter=0;
bit key1_enter=0;
bit key2_enter=0;
void init(void)
        ge = 0;
        shi = 0;
        EA = 1;
        IT0 = 1;
void delay(uchar ms)
uchar i ,j;
for (i=0;i<ms;i++)
         for(j=101;j>0;j--);
void key_loop()
        if ((key0==0)&&(key0_enter==0))
                key0_enter=1;
                EX0=1;
        if(key0==1)
         key0_enter=0;
        if ((key1==0)&&(key1_enter==0))
                key1_enter=1;
                EX0=0;
        if(key1==1)
         key1_enter=0;
        if ((key2==0)&&(key2_enter==0))
                key2_enter=1;
                num = 0;
        if(key2==1)
         key2_enter=0;
void display()
        static uchar nms=0;
        static bit wei=0;
         uchar ges=0;
         uchar shis=0;
        nms++;
        if(nms>5)
         nms=0;
         if(wei)
           shis=(num/10)%10;
                   ge=1;
                shi=1;
                P2=table[shis];
                shi=0;
                wei=0;
                 ges=num%10;
                ge=1;
                shi=1;
                 P2=table[ges];
                ge=0;
                wei=1;
  init();
  for(;;)
        key_loop();
        display();
        delay(1);
void waibu() interrupt 0
        num++;
