STC8a8k64S4A12怎么实现流水呼吸灯?只有呼吸灯的PWM代码
duan030
2021-12-27 18:41
STC8a8k64S4A12怎么实现流水呼吸灯?只有呼吸灯的PWM代码,现在想实现8个灯呈现波浪式的起伏,也算是流水呼吸灯了
求助大佬们,非常非常感谢!
#include "reg51.h"
#include "intrins.h"
//测试工作频率为11.0592MHz
#define CYCLE 0x1000
sfr P_SW2 = 0xba;
sfr PWMCFG = 0xf1;
sfr PWMIF = 0xf6;
sfr PWMFDCR = 0xf7;
sfr PWMCR = 0xfe;
#define PWMC (*(unsigned int volatile xdata *)0xfff0)
#define PWMCKS (*(unsigned char volatile xdata *)0xfff2)
#define TADCP (*(unsigned int volatile xdata *)0xfff3)
#define PWM0T1 (*(unsigned int volatile xdata *)0xff00)
#define PWM0T2 (*(unsigned int volatile xdata *)0xff02)
#define PWM0CR (*(unsigned char volatile xdata *)0xff04)
#define PWM0HLD (*(unsigned char volatile xdata *)0xff05)
#define PWM1T1 (*(unsigned int volatile xdata *)0xff10)
#define PWM1T2 (*(unsigned int volatile xdata *)0xff12)
#define PWM1CR (*(unsigned char volatile xdata *)0xff14)
#define PWM1HLD (*(unsigned char volatile xdata *)0xff15)
#define PWM2T1 (*(unsigned int volatile xdata *)0xff20)
#define PWM2T2 (*(unsigned int volatile xdata *)0xff22)
#define PWM2CR (*(unsigned char volatile xdata *)0xff24)
#define PWM2HLD (*(unsigned char volatile xdata *)0xff25)
#define PWM3T1 (*(unsigned int volatile xdata *)0xff30)
#define PWM3T2 (*(unsigned int volatile xdata *)0xff32)
#define PWM3CR (*(unsigned char volatile xdata *)0xff34)
#define PWM3HLD (*(unsigned char volatile xdata *)0xff35)
#define PWM4T1 (*(unsigned int volatile xdata *)0xff40)
#define PWM4T2 (*(unsigned int volatile xdata *)0xff42)
#define PWM4CR (*(unsigned char volatile xdata *)0xff44)
#define PWM4HLD (*(unsigned char volatile xdata *)0xff45)
#define PWM5T1 (*(unsigned int volatile xdata *)0xff50)
#define PWM5T2 (*(unsigned int volatile xdata *)0xff52)
#define PWM5CR (*(unsigned char volatile xdata *)0xff54)
#define PWM5HLD (*(unsigned char volatile xdata *)0xff55)
#define PWM6T1 (*(unsigned int volatile xdata *)0xff60)
#define PWM6T2 (*(unsigned int volatile xdata *)0xff62)
#define PWM6CR (*(unsigned char volatile xdata *)0xff64)
#define PWM6HLD (*(unsigned char volatile xdata *)0xff65)
#define PWM7T1 (*(unsigned int volatile xdata *)0xff70)
#define PWM7T2 (*(unsigned int volatile xdata *)0xff72)
#define PWM7CR (*(unsigned char volatile xdata *)0xff74)
#define PWM7HLD (*(unsigned char volatile xdata *)0xff75)
void PWM_Isr() interrupt 22
static bit dir = 1;
static int val = 0;
char store;
if (PWMCFG & 0x80)
PWMCFG &= ~0x80; //清中断标志
if (dir)
val++;
if (val >= CYCLE) dir = 0;
val--;
if (val <= 1) dir = 1;
store = P_SW2;
P_SW2 |= 0x80;
PWM0T2 = val;
P_SW2 = store;
P_SW2 = 0x80;
PWMCKS = 0x00; // PWM时钟为系统时钟
PWMC = CYCLE; //设置PWM周期为
PWM0T1= 0x0000;
PWM0T2= 0x0001;
PWM0CR= 0x80; //使能PWM0输出
P_SW2 = 0x00;
PWMCR = 0xc0; //启动PWM模块
EA = 1;
while (1);
这个代码是定义了一个灯,多个灯定义加上PWM1、2...即可
风之痕于梦想
2021-12-29 15:37
呼吸灯函数可以带入口参数,然后采用轮询的方式把每个等赋值给入口参数即可。
tatachaoren
2021-12-29 16:23
可以不用PWM中断去做。我做过一个呼吸灯产品,思路是:用定时器定时一个1ms的中断,然后根据时间去改变A的PWM占空比,比如20ms改变一次,当A的占空比从0到100%再递减到30%时,你开始递加B的PWM的占空比,当A的占空比0的时候,B的占空比就在30%,类比下去C,D,E等等。我做的不是海浪,不过你可以根据海浪的特性去做。
lkc8210
2021-12-29 16:58
手上没有STC8A的单片机
试试这样改
static char dir[8] = {0, 0, 0, 0, 0, 0, 0, 0};
static int val[8]= {0, 0, 0, 0, 0, 0, 0, 0};
static char Enb[8]= {0, 0, 0, 0, 0, 0, 0, 0};
char store, index;
static unsigned int delay_on = 0;
static char delay_on_i = 0;
if(!delay_on)
delay_on = 1500;//~0.5sec
if(delay_on_i<8)
Enb[delay_on_i] = 1;
delay_on_i++;
}else{
delay_on--;
if (PWMCFG & 0x80)
for(index = 0;index < 8; index++)
if(Enb[index])
if (!dir[index])
val[index]++;
if (val[index] >= CYCLE) dir[index] = 0;
val[index]--;
if (val[index] <= 1) dir[index] = 1;
store = P_SW2;
P_SW2 |= 0x80;
PWM0T2 = val[0];
PWM1T2 = val[1];
PWM2T2 = val[2];
PWM3T2 = val[3];
PWM4T2 = val[4];
PWM5T2 = val[5];
PWM6T2 = val[6];
PWM7T2 = val[7];
P_SW2 = store;
