标题: 单片机流水灯开启慢到快,关闭快到慢,可切换模式,程序飞了 麻烦大佬指导下 [打印本页]
作者: 菜鸟一个622    时间: 2022-1-25 14:19
试着大佬之前帮我的快慢流水程序让它开时流水慢到快固定,关时快到慢关闭。加了切换模式和长按开短按切换,程序keil没报错,仿真测试开始是慢到快,关没有效果直接关闭,再开还是快的流水。。。应该在哪里清零?保存键值是程序关在哪个模式开在哪个模式,怎么关的时候没有快到慢在关。。。。我是不是哪里搞错了。。
#include <reg51.h>
sbit key1=P3^0;
typedef unsigned char u8;MODE;slow;
typedef unsigned int u16;count;
typedef unsigned long u32;
unsigned char dat1[4]={0xf1,0xf2,0xf4,0xf8};
unsigned char dat2[4]={0xfc,0xf9,0xf3,0xf6};
unsigned char dat3[4]={0xfe,0xfd,0xfb,0xf7};
bit Power_On = 1;
bit sign;
u16 TMR_XX_ACC;
u16 TMR_XX_PRE = 500;
u8 index = 0;
void mode1(void);
void mode2(void);
void mode3(void);
void key_Proc();
void Delay_XD(unsigned int x);
void key_Proc()
      if(key1==0)
         if(count<501)count++;
             if(count==500)//长按
            sign=~sign;
            if(sign)
                     slow=MODE;//保存键值
                      MODE = 0;//关闭流水
                                        else MODE=slow; //还原键值
                                        if(count>20 && count<500)//短按
                                                ++MODE;
                                                if(MODE>3)
                                                        MODE=1;
                                  count = 0;
    while (1)
           key_Proc();
                            switch(MODE)
                         case 0: P0=0xFF;break;
                        case 1: mode1();break;
                        case 2: mode2();break;
                        case 3: mode3();break;
    Delay_XD(1);
      unsigned int i,j;
        for(i=0;i<x;i++)
               for(j=0;j<120;j++);//12T
void mode1(void)
   if(++TMR_XX_ACC >= TMR_XX_PRE)
                         TMR_XX_ACC=0;
       if(TMR_XX_PRE != 500)
          P0=dat1[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
              if(TMR_XX_PRE>20)//固定到快
                 TMR_XX_PRE -=10;
            if(TMR_XX_PRE<500)//固定到慢
            TMR_XX_PRE +=20;
void mode2(void)
                         TMR_XX_ACC=0;
          P0=dat2[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
void mode3(void)
                         TMR_XX_ACC=0;
          P0=dat3[index];
          index = ++index %4;
          P0 = 0xFF;
         if(Power_On)
                 TMR_XX_PRE -=10;
            TMR_XX_PRE +=20;
作者: lkc8210    时间: 2022-1-25 19:56
把sign转做Power_On
