标题: ssd1306iic驱动LCD12832怎么改屏幕亮度或对比度? [打印本页]
作者: zxule    时间: 2022-3-1 11:58
同题,研究了数据手册,看到是通过0x81改对比度,就是想请教坛友们这句话应该怎么写,加在程序的哪里?谢谢!程序如下,数据手册在附件。谢谢!
  1. #include <Wire.h>
  2. // OLED I2C 128 x 32 monochrome display **********************************************
  3. const int OLEDAddress = 0x3C;
  4. // Initialisation sequence for OLED module
  5. int const InitLen = 15;
  6. const unsigned char Init[InitLen] PROGMEM = {
  7.   0xA8, // Set multiplex
  8.   0x1F, // for 32 rows
  9.   0x8D, // Charge pump
  10.   0x14,
  11.   0x20, // Memory mode
  12.   0x01, // Vertical addressing
  13.   0xA1, // 0xA0/0xA1 flip horizontally
  14.   0xC8, // 0xC0/0xC8 flip vertically
  15.   0xDA, // Set comp ins
  16.   0x02,
  17.   0xD9, // Set pre charge
  18.   0xF1,
  19.   0xDB, // Set vcom deselect
  20.   0x40,
  21.   0xAF  // Display on
  22. };
  23. const int data = 0x40;
  24. const int single = 0x80;
  25. const int command = 0x00;
  26. void InitDisplay () {
  27.   Wire.beginTransmission(OLEDAddress);
  28.   Wire.write(command);
  29.   for (uint8_t c=0; c<InitLen; c++) Wire.write(pgm_read_byte(&Init[c]));
  30.   Wire.endTransmission();
  31. }
  32. void DisplayOnOff (int On) {
  33.   Wire.beginTransmission(OLEDAddress);
  34.   Wire.write(command);
  35.   Wire.write(0xAE + On);
  36.   Wire.endTransmission();
  37. }
  38. // Graphics **********************************************
  39. int Scale = 2;
  40. boolean Smooth = true;
  41. // Character set for ASCII space up to '9'
  42. const uint8_t CharMap[][6] PROGMEM = {
  43. { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 },
  44. { 0x00, 0x00, 0x5F, 0x00, 0x00, 0x00 },
  45. { 0x00, 0x07, 0x00, 0x07, 0x00, 0x00 },
  46. { 0x14, 0x7F, 0x14, 0x7F, 0x14, 0x00 },
  47. { 0x24, 0x2A, 0x7F, 0x2A, 0x12, 0x00 },
  48. { 0x23, 0x13, 0x08, 0x64, 0x62, 0x00 },
  49. { 0x36, 0x49, 0x56, 0x20, 0x50, 0x00 },
  50. { 0x00, 0x08, 0x07, 0x03, 0x00, 0x00 },
  51. { 0x00, 0x1C, 0x22, 0x41, 0x00, 0x00 },
  52. { 0x00, 0x41, 0x22, 0x1C, 0x00, 0x00 },
  53. { 0x2A, 0x1C, 0x7F, 0x1C, 0x2A, 0x00 },
  54. { 0x08, 0x08, 0x3E, 0x08, 0x08, 0x00 },
  55. { 0x00, 0x80, 0x70, 0x30, 0x00, 0x00 },
  56. { 0x08, 0x08, 0x08, 0x08, 0x08, 0x00 },
  57. { 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 },
  58. { 0x20, 0x10, 0x08, 0x04, 0x02, 0x00 },
  59. { 0x3E, 0x51, 0x49, 0x45, 0x3E, 0x00 },
  60. { 0x00, 0x42, 0x7F, 0x40, 0x00, 0x00 },
  61. { 0x72, 0x49, 0x49, 0x49, 0x46, 0x00 },
  62. { 0x21, 0x41, 0x49, 0x4D, 0x33, 0x00 },
  63. { 0x18, 0x14, 0x12, 0x7F, 0x10, 0x00 },
  64. { 0x27, 0x45, 0x45, 0x45, 0x39, 0x00 },
  65. { 0x3C, 0x4A, 0x49, 0x49, 0x31, 0x00 },
  66. { 0x41, 0x21, 0x11, 0x09, 0x07, 0x00 },
  67. { 0x36, 0x49, 0x49, 0x49, 0x36, 0x00 },
  68. { 0x46, 0x49, 0x49, 0x29, 0x1E, 0x00 },
  69. };
  70. void ClearDisplay () {
  71.   Wire.beginTransmission(OLEDAddress);
  72.   Wire.write(command);
  73.   // Set column address range
  74.   Wire.write(0x21); Wire.write(0); Wire.write(127);
  75.   // Set page address range
  76.   Wire.write(0x22); Wire.write(0); Wire.write(3);
  77.   Wire.endTransmission();
  78.   // Write the data in 37 14-byte transmissions - buffer only 16 bytes
  79.   for (int i = 0 ; i < 37; i++) {
  80.     Wire.beginTransmission(OLEDAddress);
  81.     Wire.write(data);
  82.     for (int i = 0 ; i < 14; i++) Wire.write(0);
  83.     Wire.endTransmission();
  84.   }
  85. }
  86. // Converts bit pattern abcdefgh into aabbccddeeffgghh
  87. int Stretch (int x) {
  88.   x = (x & 0xF0)<<4 | (x & 0x0F);
  89.   x = (x<<2 | x) & 0x3333;
  90.   x = (x<<1 | x) & 0x5555;
  91.   return x | x<<1;
  92. }
  93. // Plots a character; line = 0 to 3; column = 0 to 131
  94. // Redesigned to cope with 16 byte I2C buffer
  95. void PlotChar(int c, int line, int column) {
  96.   Wire.beginTransmission(OLEDAddress);
  97.   Wire.write(command);
  98.   // Set column address range
  99.   Wire.write(0x21); Wire.write(column); Wire.write(column + Scale*6 - 1);
  100.   // Set page address range
  101.   Wire.write(0x22); Wire.write(line); Wire.write(line + Scale - 1);
  102.   Wire.endTransmission();
  103.   uint8_t col0 = pgm_read_byte(&CharMap[c-32][0]);
  104.   int col0L, col0R, col1L, col1R;
  105.   col0L = Stretch(col0);
  106.   col0R = col0L;
  107.   for (uint8_t col = 1 ; col < 5; col++) {
  108.     Wire.beginTransmission(OLEDAddress);
  109.     Wire.write(data);
  110.     uint8_t col1 = pgm_read_byte(&CharMap[c-32][col]);
  111.     col1L = Stretch(col1);
  112.     col1R = col1L;
  113.     if (Scale == 1) Wire.write(col0);
  114.     // Smoothing
  115.     else {
  116.       if (Smooth) {
  117.         for (int i=6; i>=0; i--) {
  118.           for (int j=1; j<3; j++) {
  119.             if (((col0>>i & 0b11) == (3-j)) && ((col1>>i & 0b11) == j)) {
  120.               col0R = col0R | 1<<((i*2)+j);
  121.               col1L = col1L | 1<<((i*2)+3-j);
  122.             }
  123.           }
  124.         }
  125.       }
  126.       Wire.write(col0L); Wire.write(col0L>>8);
  127.       Wire.write(col0R); Wire.write(col0R>>8);
  128.       col0L = col1L; col0R = col1R;
  129.     }
  130.     col0 = col1;
  131.     Wire.endTransmission();
  132.   }
  133.   Wire.beginTransmission(OLEDAddress);
  134.   Wire.write(data);
  135.   if (Scale == 1) Wire.write(col0);
  136.   else {
  137.     Wire.write(col0L); Wire.write(col0L>>8);
  138.     Wire.write(col0R); Wire.write(col0R>>8);
  139.   }
  140.   Wire.endTransmission();
  141. }
  142. // Plot a 9-digit integer
  143. void PlotInt (uint32_t value, int line, int column) {
  144.   boolean suppress = true;
  145.   for (uint32_t d=100000000; d>0; d = d/10) {
  146.     if (d == 100000 || d == 100) {
  147.       PlotChar((suppress ? ' ' : ','), line, column);
  148.       column = column + Scale*5;
  149.     }
  150.     char c = value/d % 10 +'0';
  151.     if (value == 0 && d<=100) c = '-';               // Zero shown as "---"
  152.     else if (c == '0' && suppress && d != 1) c = ' ';
  153.     else suppress = false;
  154.     PlotChar(c, line, column);
  155.     column = column + Scale*6;
  156.   }
  157. }
  158. // Real-Time Clock **********************************************
  159. volatile uint16_t MSByte;
  160. volatile uint32_t Counter;
  161. void RTCSetup () {
  162.   uint8_t temp;
  163.   // Initialize 32.768kHz Oscillator:
  164.   // Disable oscillator:
  165.   temp = CLKCTRL.XOSC32KCTRLA & ~CLKCTRL_ENABLE_bm;
  166.   // Enable writing to protected register
  167.   CPU_CCP = CCP_IOREG_gc;
  168.   CLKCTRL.XOSC32KCTRLA = temp;
  169.   while (CLKCTRL.MCLKSTATUS & CLKCTRL_XOSC32KS_bm); // Wait until XOSC32KS is 0
  170.
  171.   temp = CLKCTRL.XOSC32KCTRLA & ~CLKCTRL_SEL_bm;    // Use External Crystal
  172.
  173.   // Enable writing to protected register
  174.   CPU_CCP = CCP_IOREG_gc;
  175.   CLKCTRL.XOSC32KCTRLA = temp;
  176.
  177.   temp = CLKCTRL.XOSC32KCTRLA | CLKCTRL_ENABLE_bm;  // Enable oscillator
  178.
  179.   // Enable writing to protected register
  180.   CPU_CCP = CCP_IOREG_gc;
  181.   CLKCTRL.XOSC32KCTRLA = temp;
  182.
  183.   // Initialize RTC
  184.   while (RTC.STATUS > 0);                           // Wait until registers synchronized
  185.
  186.   RTC.PER = 1023;                                   // Set period 1 second
  187.   RTC.CLKSEL = RTC_CLKSEL_TOSC32K_gc;               // 32.768kHz External Crystal Oscillator
  188.   RTC.CTRLA = RTC_PRESCALER_DIV32_gc | RTC_RTCEN_bm;// Prescaler /32 and enable
  189. }
  190. // Timer/Counter TCD0 **********************************************
  191. volatile boolean Ready = false;                     // New reading ready?
  192. void TCDSetup () {
  193.   TCD0.CTRLB = TCD_WGMODE_ONERAMP_gc;               // Set one ramp waveform mode
  194.   TCD0.CMPBCLR = 0xFFF;                             // Count up to maximum
  195.   TCD0.INPUTCTRLB = TCD_INPUTMODE_EDGETRIG_gc;      // Capture and reset counter
  196.   TCD0.EVCTRLB = TCD_CFG_ASYNC_gc | TCD_ACTION_bm | TCD_TRIGEI_bm; // Enable event
  197.   TCD0.INTCTRL = TCD_OVF_bm | TCD_TRIGB_bm;         // Enable interrupts
  198.   // Ensure ENRDY bit is set
  199.   while(!(TCD0.STATUS & TCD_ENRDY_bm));
  200.
  201.   // External clock, no prescaler, enable timer
  202.   TCD0.CTRLA = TCD_CLKSEL_EXTCLK_gc | TCD_CNTPRES_DIV1_gc | TCD_ENABLE_bm;
  203. }
  204. // Timer/Counter TCD0 overflow interrupt counts MSByte
  205. ISR (TCD0_OVF_vect) {
  206.   TCD0.INTFLAGS = TCD_OVF_bm;                       // Clear overflow interrupt flag
  207.   MSByte++;
  208. }
  209. // Timer/Counter TCD0 capture interrupt
  210. ISR (TCD0_TRIG_vect) {
  211.   PORTA.IN = PIN4_bm;                               // Toggle LED on
  212.   TCD0.INTFLAGS = TCD_TRIGB_bm;                     // Clear capture interrupt flag
  213.   Counter = TCD0.CAPTUREB;
  214.   Counter = (uint32_t)MSByte<<12 | Counter;
  215.   MSByte = 0;
  216.   Ready = true;
  217.   PORTA.IN = PIN4_bm;                               // Toggle LED off
  218.   TCD0.INTFLAGS = TCD_OVF_bm;                       // Clear overflow interrupt flag
  219. }
  220. // Event System **********************************************
  221. void EvsysSetup (void) {
  222.   EVSYS.ASYNCCH1 = EVSYS_ASYNCCH1_RTC_OVF_gc;       // Event generated from RTC OVF
  223.   EVSYS.ASYNCUSER7 = EVSYS_ASYNCUSER7_ASYNCCH1_gc;  // Event causes a TCD0 capture
  224.
  225.   EVSYS.ASYNCCH0 = EVSYS_ASYNCCH0_PORTA_PIN1_gc;    // PA1 is an event generator
  226.   EVSYS.ASYNCUSER8 = EVSYS_ASYNCUSER8_ASYNCCH0_gc;  // ASYNCUSER8 is EVOUT0 (PA2)
  227.   PORTMUX.CTRLA = PORTMUX_EVOUT0_bm;                // Enable EVOUT0
  228.   PORTA.PIN1CTRL = PORT_INVEN_bm;                   // Invert input
  229. }
  230. // Setup **********************************************
  231. void setup() {
  232.   PORTA.DIRSET = PIN4_bm;                           // Make LED on PA4 an output
  233.   PORTA.PIN4CTRL = PORT_INVEN_bm;                   // Invert output
  234.   Wire.begin();
  235.   InitDisplay();
  236.   ClearDisplay();
  237.   TCDSetup();
  238.   RTCSetup();
  239.   EvsysSetup();
  240. }
  241. void loop() {
  242.   uint32_t temp;
  243.   unsigned long start = millis();
  244.   while (!Ready) {
  245.     if (millis() - start > 1000) {
  246.       Counter = 0;
  247.       break;
  248.     }
  249.   }
  250.   Ready = false;
  251.   cli(); temp = Counter; sei();
  252.   PlotInt(temp, 1, 0);
  253. }
0.91 UN-2832TSWEG02.pdf
1.56 MB, 下载次数: 7
数据手册
作者: Y_G_G    时间: 2022-3-1 17:06
这是一个双字节命令,你要先写入0x81,再写入(对比度:0-ff)指令格式是命令格式(0x00)
