运行错误 单片机步进电机模块 正转,反转调速Proteus仿真+程序
14003
2022-3-29 22:50
步进电机模块,正转,反转调速
(95.48 KB, 下载次数: 65)
下载附件
2022-3-29 23:28 上传
LCD1602.C文件 LCD1602的函数
#include "hardware.h"
#include "lcd1602.h"
void LCD_check_busy(void) //检测LCD状态,看它是不是还在忙呢
LCD_EN=0;
LCD_RS=0;
LCD_RW=1;
LCD_DATA=0xff;
LCD_EN=1;
if(!LCD_BUSY)break;
LCD_EN=0;
void LCD_cls(void) //LCD清屏
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=1;
LCD_EN=1;
LCD_EN=0;
void LCD_write_instruction(unsigned char LCD_instruction) //写指令到LCD
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=LCD_instruction;
LCD_EN=1;
LCD_EN=0;
void LCD_write_data(unsigned char LCD_data) //输出一个字节数据到LCD
LCD_check_busy();
LCD_RS=1;
LCD_RW=0;
LCD_DATA=LCD_data;
LCD_EN=1;
LCD_EN=0;
void LCD_set_position(unsigned char x) //LCD光标定位到x处
LCD_write_instruction(0x80+x);
void LCD_go_home(void) //LCD光标归位
LCD_write_instruction(LCD_GO_HOME);
void LCD_printc(unsigned char lcd_data) //输出一个字符到LCD
LCD_write_data(lcd_data);
void LCD_prints(unsigned char *lcd_string) //输出一个字符串到LCD
unsigned char i=0;
while(lcd_string[ i]!=0x00)
LCD_write_data(lcd_string[ i]);
i++;
void LCD_initial(void) //初始化LCD
LCD_write_instruction(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
LCD_write_instruction(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
LCD_write_instruction(LCD_DISPLAY_DOUBLE_LINE);
LCD_cls();
运行错误 求指导:
步进电机模块.zip
(59.61 KB, 下载次数: 11)
2022-3-29 22:49 上传
点击文件名下载附件
songxia8013
2022-3-30 10:08
仿真图没有Lcd1602,程序里面怎么有Lcd1602的程序呢?
