标题: stc12单片机制作示波器,LCD12864显示程序有点不太懂 [打印本页]
作者: lalalala11    时间: 2022-5-10 20:26
void disp_0(unsigned char x,unsigned char y)
Lcd_PutPixel(x+1,y+1,1);
Lcd_PutPixel(x+1,y+2,1);
Lcd_PutPixel(x+1,y+3,1);
Lcd_PutPixel(x+2,y+0,1);
Lcd_PutPixel(x+2,y+4,1);
Lcd_PutPixel(x+3,y+1,1);
Lcd_PutPixel(x+3,y+2,1);
Lcd_PutPixel(x+3,y+3,1);
这一段程序不知道是在画什么图。
在程序中看到了ADC采集程序,没有看到转换啊
还有主函数中:
        case 0:
                delnop=1;
                disp_p(91,54);
                clr(66,54,71,57);
                clr(41,54,46,57);
                clr(16,54,21,57);
这是在画什么呢?
程序附上,感谢各位大哥解答!
  1.     #include <STC12c5a.H>
  2.     #include<intrins.h>
  3.     #include<math.h>
  4.     sbit RS=P2^5;
  5.     sbit RW=P2^6;
  6.     sbit E=P2^7;
  7.     sbit led=P1^0;
  8.     sbit jiakey=P3^0;
  9.     sbit jiankey=P3^1;
  10.     sbit ledkey=P3^2;
  11.     #define  LcdData P0
  12.     unsigned char dati=0;
  13.     unsigned char dat[100];
  14.     unsigned char over=0;
  15.     unsigned int temp=0;
  16.     unsigned char mode=0;
  17.     unsigned int delnop=0;
  18.     //////////////////////////////////////
  19.     unsigned char Lcd_CheckBusy(void)
  20.     {
  21.         unsigned char Busy;
  22.              LcdData=0xff;
  23.         RS=0;
  24.         RW=1;
  25.         E=1;
  26.         _nop_();
  27.         Busy=LcdData&0x80;
  28.         E=0;
  29.         return Busy;
  30.     }
  31.     void Lcd_WriteData(unsigned char Data)
  32.     {
  33.             while(Lcd_CheckBusy());
  34.             RS=1;
  35.             RW=0;
  36.             E=0;
  37.             _nop_();
  38.             _nop_();
  39.             LcdData=Data;
  40.             E=1;
  41.             _nop_();
  42.             _nop_();
  43.             E=0;
  44.     }
  45.     unsigned char Lcd_ReadData(void)
  46.     {
  47.             unsigned char Temp;
  48.             while(Lcd_CheckBusy());
  49.              LcdData=0xff;
  50.              RS=1;
  51.             RW=1;
  52.             E=1;
  53.             _nop_();
  54.                Temp=LcdData;
  55.                E=0;
  56.                return Temp;
  57.     }
  58.     void Lcd_WriteCmd(unsigned char CmdCode)
  59.     {
  60.             while(Lcd_CheckBusy());
  61.                RS=0;
  62.                RW=0;
  63.                E=0;
  64.                _nop_();
  65.             _nop_();
  66.                LcdData=CmdCode;
  67.                _nop_();
  68.             _nop_();
  69.                E=1;
  70.                _nop_();
  71.             _nop_();
  72.                E=0;
  73.     }
  74.     code unsigned int LcdMaskTab[]={0x0001,0x0002,0x0004,0x0008,0x0010,0x0020,0x0040,0x0080,0x0100,0x0200,0x0400,0x0800,0x1000,0x2000,0x4000,0x8000};
  75.     void Lcd_PutPixel(unsigned char x,unsigned char y,unsigned char Color)
  76.     {
  77.             unsigned char z,w;
  78.             unsigned int Temp;
  79.             if(x>=128||y>=64)
  80.                     return;
  81.             Color=Color%2;
  82.             w=15-x%16;
  83.             x=x/16;
  84.             if(y<32)
  85.                     z=0x80;
  86.             else
  87.                     z=0x88;
  88.             y=y%32;
  89.
  90.             Lcd_WriteCmd(0x36);
  91.             Lcd_WriteCmd(y+0x80);
  92.             Lcd_WriteCmd(x+z);
  93.             Temp=Lcd_ReadData();
  94.             Temp=(unsigned int)Lcd_ReadData()<<8;
  95.             Temp|=(unsigned int)Lcd_ReadData();
  96.
  97.             if(Color==1)
  98.                     Temp|=LcdMaskTab[w];
  99.             else
  100.                     Temp&=~LcdMaskTab[w];
  101.
  102.             Lcd_WriteCmd(y+0x80);
  103.             Lcd_WriteCmd(x+z);
  104.        Lcd_WriteData(Temp>>8);
  105.        Lcd_WriteData(Temp&0x00ff);
  106.             Lcd_WriteCmd(0x30);
  107.
  108.     }
  109.
  110.     void Lcd_Clear(unsigned char Mode)
  111.     {
  112.             unsigned char x,y,ii;
  113.             unsigned char Temp;
  114.             if(Mode%2==0)
  115.                     Temp=0x00;
  116.             else
  117.                     Temp=0xff;
  118.             Lcd_WriteCmd(0x36);
  119.             for(ii=0;ii<9;ii+=8)
  120.                     for(y=0;y<0x20;y++)
  121.                             for(x=0;x<8;x++)
  122.                             {
  123.
  124.                                     Lcd_WriteCmd(y+0x80);
  125.                                     Lcd_WriteCmd(x+0x80+ii);
  126.                                     Lcd_WriteData(Temp);
  127.                                     Lcd_WriteData(Temp);
  128.
  129.                             }
  130.             Lcd_WriteCmd(0x30);
  131.     }
  132.
  133.     void Lcd_Reset()
  134.     {
  135.             Lcd_WriteCmd(0x30);
  136.             Lcd_WriteCmd(0x0c);
  137.             Lcd_WriteCmd(0x01);
  138.             Lcd_WriteCmd(0x06);
  139.     }
  140.     //////////////////////////////////////
  141.     void InitADC()
  142.     {
  143.     P1ASF=0X80;
  144.     ADC_RES=0;
  145.     ADC_CONTR=0xef;
  146.     EADC=1;
  147.     }
  148.     void adc_isr() interrupt 5 using 1
  149.     {
  150.     ADC_CONTR=0xef;
  151.     if(over==0)
  152.     {
  153.             temp=delnop;
  154.             while(temp)
  155.             {
  156.             temp--;
  157.             }
  158.             dat[dati]=ADC_RES;
  159.             dati++;
  160.             if(dati>100)
  161.             {
  162.             dati=0;
  163.             over=1;
  164.             }
  165.     }
  166.     }
  167.     //////////////////////////////////////
  168.     void disp_0(unsigned char x,unsigned char y)
  169.     {
  170.     Lcd_PutPixel(x+1,y+1,1);
  171.     Lcd_PutPixel(x+1,y+2,1);
  172.     Lcd_PutPixel(x+1,y+3,1);
  173.     Lcd_PutPixel(x+2,y+0,1);
  174.     Lcd_PutPixel(x+2,y+4,1);
  175.     Lcd_PutPixel(x+3,y+1,1);
  176.     Lcd_PutPixel(x+3,y+2,1);
  177.     Lcd_PutPixel(x+3,y+3,1);
  178.     }
  179.     void disp_1(unsigned char x,unsigned char y)
  180.     {
  181.     Lcd_PutPixel(x+1,y+1,1);
  182.     Lcd_PutPixel(x+1,y+4,1);
  183.     Lcd_PutPixel(x+2,y+0,1);
  184.     Lcd_PutPixel(x+2,y+1,1);
  185.     Lcd_PutPixel(x+2,y+2,1);
  186.     Lcd_PutPixel(x+2,y+3,1);
  187.     Lcd_PutPixel(x+2,y+4,1);
  188.     Lcd_PutPixel(x+3,y+4,1);
  189.     }
  190.     void disp_2(unsigned char x,unsigned char y)
  191.     {
  192.     Lcd_PutPixel(x+1,y+0,1);
  193.     Lcd_PutPixel(x+1,y+2,1);
  194.     Lcd_PutPixel(x+1,y+3,1);
  195.     Lcd_PutPixel(x+1,y+4,1);
  196.     Lcd_PutPixel(x+2,y+0,1);
  197.     Lcd_PutPixel(x+2,y+2,1);
  198.     Lcd_PutPixel(x+2,y+4,1);
  199.     Lcd_PutPixel(x+3,y+0,1);
  200.     Lcd_PutPixel(x+3,y+1,1);
  201.     Lcd_PutPixel(x+3,y+2,1);
  202.     Lcd_PutPixel(x+3,y+4,1);
  203.     }
  204.     void disp_3(unsigned char x,unsigned char y)
  205.     {
  206.     Lcd_PutPixel(x+1,y+0,1);
  207.     Lcd_PutPixel(x+1,y+2,1);
  208.     Lcd_PutPixel(x+1,y+4,1);
  209.     Lcd_PutPixel(x+2,y+0,1);
  210.     Lcd_PutPixel(x+2,y+2,1);
  211.     Lcd_PutPixel(x+2,y+4,1);
  212.     Lcd_PutPixel(x+3,y+0,1);
  213.     Lcd_PutPixel(x+3,y+1,1);
  214.     Lcd_PutPixel(x+3,y+2,1);
  215.     Lcd_PutPixel(x+3,y+3,1);
  216.     Lcd_PutPixel(x+3,y+4,1);
  217.     }
  218.     void disp_4(unsigned char x,unsigned char y)
  219.     {
  220.     Lcd_PutPixel(x+1,y+0,1);
  221.     Lcd_PutPixel(x+1,y+1,1);
  222.     Lcd_PutPixel(x+1,y+2,1);
  223.     Lcd_PutPixel(x+2,y+2,1);
  224.     Lcd_PutPixel(x+3,y+0,1);
  225.     Lcd_PutPixel(x+3,y+1,1);
  226.     Lcd_PutPixel(x+3,y+2,1);
  227.     Lcd_PutPixel(x+3,y+3,1);
  228.     Lcd_PutPixel(x+3,y+4,1);
  229.     }
  230.     void disp_5(unsigned char x,unsigned char y)
  231.     {
  232.     Lcd_PutPixel(x+1,y+0,1);
  233.     Lcd_PutPixel(x+1,y+1,1);
  234.     Lcd_PutPixel(x+1,y+2,1);
  235.     Lcd_PutPixel(x+1,y+4,1);
  236.     Lcd_PutPixel(x+2,y+0,1);
  237.     Lcd_PutPixel(x+2,y+2,1);
  238.     Lcd_PutPixel(x+2,y+4,1);
  239.     Lcd_PutPixel(x+3,y+0,1);
  240.     Lcd_PutPixel(x+3,y+2,1);
  241.     Lcd_PutPixel(x+3,y+3,1);
  242.     Lcd_PutPixel(x+3,y+4,1);
  243.     }
  244.     void disp_p(unsigned char x,unsigned char y)
  245.     {
  246.     Lcd_PutPixel(x+0,y+0,1);
  247.     Lcd_PutPixel(x+1,y+0,1);
  248.     Lcd_PutPixel(x+1,y+1,1);
  249.     Lcd_PutPixel(x+2,y+0,1);
  250.     Lcd_PutPixel(x+2,y+1,1);
  251.     Lcd_PutPixel(x+2,y+2,1);
  252.     Lcd_PutPixel(x+3,y+0,1);
  253.     Lcd_PutPixel(x+3,y+1,1);
  254.     Lcd_PutPixel(x+4,y+0,1);
  255.     }
  256.     void disp_k(unsigned char x,unsigned char y)
  257.     {
  258.     Lcd_PutPixel(x+0,y+0,1);
  259.     Lcd_PutPixel(x+0,y+1,1);
  260.     Lcd_PutPixel(x+0,y+2,1);
  261.     Lcd_PutPixel(x+0,y+3,1);
  262.     Lcd_PutPixel(x+0,y+4,1);
  263.     Lcd_PutPixel(x+1,y+2,1);
  264.     Lcd_PutPixel(x+2,y+1,1);
  265.     Lcd_PutPixel(x+2,y+3,1);
  266.     Lcd_PutPixel(x+3,y+0,1);
  267.     Lcd_PutPixel(x+3,y+4,1);
  268.     }
  269.     void disp_hz(unsigned char x,unsigned char y)
  270.     {
  271.     Lcd_PutPixel(x+0,y+0,1);
  272.     Lcd_PutPixel(x+0,y+1,1);
  273.     Lcd_PutPixel(x+0,y+2,1);
  274.     Lcd_PutPixel(x+0,y+3,1);
  275.     Lcd_PutPixel(x+0,y+4,1);
  276.     Lcd_PutPixel(x+1,y+2,1);
  277.     Lcd_PutPixel(x+2,y+0,1);
  278.     Lcd_PutPixel(x+2,y+1,1);
  279.     Lcd_PutPixel(x+2,y+2,1);
  280.     Lcd_PutPixel(x+2,y+3,1);
  281.     Lcd_PutPixel(x+2,y+4,1);
  282.     Lcd_PutPixel(x+4,y+1,1);
  283.     Lcd_PutPixel(x+4,y+3,1);
  284.     Lcd_PutPixel(x+4,y+4,1);
  285.     Lcd_PutPixel(x+5,y+1,1);
  286.     Lcd_PutPixel(x+5,y+2,1);
  287.     Lcd_PutPixel(x+5,y+4,1);
  288.     }
  289.     void disp_ledon(unsigned char x,unsigned char y)
  290.     {
  291.     Lcd_PutPixel(x+1,y+0,1);
  292.     Lcd_PutPixel(x+1,y+1,1);
  293.     Lcd_PutPixel(x+1,y+2,1);
  294.     Lcd_PutPixel(x+1,y+3,1);
  295.     Lcd_PutPixel(x+1,y+4,1);
  296.     Lcd_PutPixel(x+2,y+1,1);
  297.     Lcd_PutPixel(x+2,y+2,1);
  298.     Lcd_PutPixel(x+2,y+3,1);
  299.     Lcd_PutPixel(x+3,y+0,1);
  300.     Lcd_PutPixel(x+3,y+4,1);
  301.     Lcd_PutPixel(x+4,y+2,1);
  302.     }
  303.     void disp_ledoff(unsigned char x,unsigned char y)
  304.     {
  305.     Lcd_PutPixel(x+1,y+0,1);
  306.     Lcd_PutPixel(x+1,y+1,1);
  307.     Lcd_PutPixel(x+1,y+2,1);
  308.     Lcd_PutPixel(x+1,y+3,1);
  309.     Lcd_PutPixel(x+1,y+4,1);
  310.     Lcd_PutPixel(x+2,y+1,1);
  311.     Lcd_PutPixel(x+2,y+2,1);
  312.     Lcd_PutPixel(x+2,y+3,1);
  313.     }
  314.     void clr(unsigned char starx,unsigned char stary,unsigned char endx,unsigned char endy)
  315.     {
  316.     char x=0;
  317.     char y=0;
  318.     for(x=starx;x<endx;x++)
  319.     {
  320.             for(y=stary;y<endy;y++)
  321.             {
  322.                     Lcd_PutPixel(x,y,0);
  323.             }
  324.     }
  325.     }
  326.     void disp_bj(void)
  327.     {
  328.     unsigned char x=0;
  329.     unsigned char y=0;
  330.     for(x=13;x<114;x++)
  331.     {
  332.     Lcd_PutPixel(x,52,1);
  333.     }
  334.     for(y=0;y<52;y++)
  335.     {
  336.     Lcd_PutPixel(13,y,1);
  337.     }
  338.     for(y=0;y<52;y++)
  339.     {
  340.     #include <REGX51.H>
  341.     Lcd_PutPixel(114,y,1);
  342.     }
  343.     Lcd_PutPixel(13,51,0);
  344.     Lcd_PutPixel(13,41,0);
  345.     Lcd_PutPixel(13,31,0);
  346.     Lcd_PutPixel(13,21,0);
  347.     Lcd_PutPixel(13,11,0);
  348.     Lcd_PutPixel(13,1,0);
  349.     Lcd_PutPixel(114,51,0);
  350.     Lcd_PutPixel(114,41,0);
  351.     Lcd_PutPixel(114,31,0);
  352.     Lcd_PutPixel(114,21,0);
  353.     Lcd_PutPixel(114,11,0);
  354.     Lcd_PutPixel(114,1,0);
  355.     disp_0(5,50);
  356.     disp_1(5,40);
  357.     disp_2(5,30);
  358.     disp_3(5,20);
  359.     disp_4(5,10);
  360.     disp_5(5,0);
  361.     disp_0(117,50);
  362.     disp_1(117,40);
  363.     disp_2(117,30);
  364.     disp_3(117,20);
  365.     disp_4(117,10);
  366.     disp_5(117,0);
  367.     disp_2(13,58);
  368.     disp_hz(18,58);
  369.     disp_2(38,58);
  370.     disp_0(43,58);
  371.     disp_hz(48,58);
  372.     disp_2(63,58);
  373.     disp_0(68,58);
  374.     disp_0(73,58);
  375.     disp_hz(78,58);
  376.     disp_2(88,58);
  377.     disp_k(93,58);
  378.     disp_hz(98,58);
  379.     }
  380.     void line(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1)
  381.     {
  382.     int i,dx,dy,e,x,y;
  383.     Lcd_PutPixel(x0,y0,1);
  384.     Lcd_PutPixel(x1,y1,1);
  385.     dx=x1-x0;
  386.     dy=y1-y0;
  387.     x=x0;
  388.     y=y0;
  389.     if(dx>0&&dy>0)
  390.     {
  391.     if(dx>dy)
  392.     {
  393.     e=-dx;
  394.     for(i=0;i<dx;i++)
  395.             {
  396.             Lcd_PutPixel(x,y,1);
  397.             x++;
  398.             e=e+2*dy;
  399.             if(e>=0)
  400.                     {
  401.                     y++;
  402.                     e=e-2*dx;
  403.                     }
  404.             }
  405.     }
  406.     else
  407.     {
  408.     e=-dy;
  409.     x=x0;
  410.     y=y0;
  411.     for(i=0;i<dy;i++)
  412.             {
  413.             Lcd_PutPixel(x,y,1);
  414.             y++;
  415.             e=e+2*dx;
  416.             if(e>=0)
  417.                     {
  418.                     x++;
  419.                     e=e-2*dy;
  420.                     }
  421.             }
  422.     }
  423.     }
  424.     if(dx<0&&dy<0)
  425.     {
  426.     dx=x0-x1;
  427.     dy=y0-y1;
  428.     if(dx>dy)
  429.     {
  430.     e=-dx;
  431.     for(i=0;i<dx;i++)
  432.             {
  433.             Lcd_PutPixel(x,y,1);
  434.             x--;
  435.             e=e+2*dy;
  436.             if(e>=0)
  437.                     {
  438.                     y--;
  439.                     e=e-2*dx;
  440.                     }
  441.             }
  442.     }
  443.     else
  444.     {
  445.     e=-dy;
  446.     for(i=0;i<dy;i++)
  447.             {
  448.             Lcd_PutPixel(x,y,1);
  449.             y--;
  450.             e=e+2*dx;
  451.             if(e>=0)
  452.                     {
  453.                     x--;
  454.                     e=e-2*dy;
  455.                     }
  456.             }
  457.     }
  458.     }
  459.     if(dx>0&&dy<0)
  460.     {
  461.     dy=y0-y1;
  462.     if(dx>dy)
  463.     {
  464.     e=-dx;
  465.     for(i=0;i<dx;i++)
  466.             {
  467.             Lcd_PutPixel(x,y,1);
  468.             x++;
  469.             e=e+2*dy;
  470.             if(e>=0)
  471.                     {
  472.                     y--;
  473.                     e=e-2*dx;
  474.                     }
  475.             }
  476.     }
  477.     else
  478.     {
  479.     e=-dy;
  480.     for(i=0;i<dy;i++)
  481.             {
  482.             Lcd_PutPixel(x,y,1);
  483.             y--;
  484.             e=e+2*dx;
  485.             if(e>=0)
  486.                     {
  487.                     x++;
  488.                     e=e-2*dy;
  489.                     }
  490.             }
  491.     }
  492.     }
  493.     if(dx<0&&dy>0)
  494.     {
  495.     dx=x0-x1;
  496.     if(dx>dy)
  497.     {
  498.     e=-dx;
  499.     for(i=0;i<dx;i++)
  500.             {
  501.             Lcd_PutPixel(x,y,1);
  502.             x--;
  503.             e=e+2*dy;
  504.             if(e>=0)
  505.                     {
  506.                     y++;
  507.                     e=e-2*dx;
  508.                     }
  509.             }
  510.     }
  511.     else
  512.     {
  513.     e=-dy;
  514.     for(i=0;i<dy;i++)
  515.             {
  516.             Lcd_PutPixel(x,y,1);
  517.             y++;
  518.             e=e+2*dx;
  519.             if(e>=0)
  520.                     {
  521.                     x--;
  522.                     e=e-2*dy;
  523.                     }
  524.             }
  525.     }
  526.     }
  527.     if(dx!=0&&dy==0)
  528.     {
  529.     if(dx>0)
  530.     {
  531.     for(i=0;i<dx;i++)
  532.             {
  533.             Lcd_PutPixel(x,y,1);
  534.             x++;
  535.             }
  536.     }
  537.     else
  538.     {
  539.     dx=x0-x1;
  540.     for(i=0;i<dx;i++)
  541.             {
  542.             Lcd_PutPixel(x,y,1);
  543.             x--;
  544.             }
  545.     }
  546.     }
  547.     if(dx==0&&dy!=0)
  548.     {
  549.     if(dy>0)
  550.     {
  551.     for(i=0;i<dy;i++)
  552.             {
  553.             Lcd_PutPixel(x,y,1);
  554.             y++;
  555.             }
  556.     }
  557.     else
  558.     {
  559.     dy=y0-y1;
  560.     for(i=0;i<dy;i++)
  561.             {
  562.             Lcd_PutPixel(x,y,1);
  563.             y--;
  564.             }
  565.     }
  566.     }
  567.     }
  568.     void disp_ware()
  569.     {
  570.     unsigned char x=0;
  571.     unsigned char y=0;
  572.                     clr(14,0,15,52);
  573.                     for(x=1;x<100;x++)
  574.                     {
  575.                             clr(x+14,0,x+15,52);
  576.                             line(x+13,51-(dat[x-1]/5),x+14,51-(dat[x]/5));
  577.                     }
  578.     }
  579.     //////////////////////////////////////
  580.     main()
  581.     {
  582.     Lcd_Reset();
  583.     Lcd_Clear(0);
  584.     InitADC();
  585.     disp_bj();
  586.     EA=1;
  587.     while(1)
  588.     {
  589.     if(over)
  590.             {
  591.                     disp_ware();
  592.                     if(ledkey==0)
  593.                     {
  594.                     led=~led;
  595.                     }
  596.                     if(jiakey==0)
  597.                     {
  598.                     if(mode<3)
  599.                             {
  600.                             mode++;
  601.                             }
  602.                     }
  603.                     if(jiankey==0)
  604.                     {
  605.                     if(mode>0)
  606.                             {
  607.                             mode--;
  608.                             }
  609.                     }
  610.                     if(led)
  611.                     {
  612.                     clr(5,58,10,63);
  613.                     disp_ledon(5,58);
  614.                     }
  615.                     else
  616.                     {
  617.                     clr(5,58,10,63);
  618.                     disp_ledoff(5,58);
  619.                     }
  620.             switch(mode)
  621.             {
  622.             case 0:
  623.                     delnop=1;
  624.                     disp_p(91,54);
  625.                     clr(66,54,71,57);
  626.                     clr(41,54,46,57);
  627.                     clr(16,54,21,57);
  628.             break;
  629.             case 1:
  630.                     delnop=40;
  631.                     disp_p(66,54);
  632.                     clr(91,54,96,57);
  633.                     clr(41,54,46,57);
  634.                     clr(16,54,21,57);
  635.             break;
  636.             case 2:
  637.                     delnop=440;
  638.                     disp_p(41,54);
  639.                     clr(91,54,96,57);
  640.                     clr(66,54,71,57);
  641.                     clr(16,54,21,57);
  642.             break;
  643.             case 3:
  644.                     delnop=4440;
  645.                     disp_p(16,54);
  646.                     clr(91,54,96,57);
  647.                     clr(41,54,46,57);
  648.                     clr(66,54,71,57);
  649.             break;
  650.             default:
  651.             break;
  652.             }
  653.             over=0;
  654.             }
  655.     }
  656.     }
作者: yzwzfyz    时间: 2022-5-11 11:21
X轴显示时间
Y轴显示电压
确定好X轴的位置,例如在第几行,确定好x轴的单位,例如一个点位代表多少时间。
确定好Y轴的位置,例如在第几列,确定好Y轴的单位,例如一个点位代表多少电压。
将测量到的数据,电压值转换成Y值,在测量的时间点上,打个点。一直重复此过程。
