STM32单片机控制AD9959 DDS和编码输出数字信号 正弦波点频输出源程序
两人鹏34
2022-5-25 16:21
通过STM32控制DDS输出频率,通过按键控制输入十进制四位数字并进行BCD编码,输出结果由LCD12864点阵液晶屏显示
制作出来的实物图如下:
(1.84 MB, 下载次数: 54)
下载附件
2022-5-25 16:20 上传
功能:stm32f103rct6控制,25MHz时钟, AD9959正弦波点频输出,范围0-200M,
显示:12864cog
接口:控制接口请参照AD9959.h 按键接口请参照key.h
#include "stm32_config.h"
#include "stdio.h"
#include "led.h"
#include "lcd.h"
#include "AD9959.h"
#include "key.h"
#include "timer.h"
#include "task_manage.h"
#define Code_Freq 20 //编码输出频率
u8 delay_time = 1000/Code_Freq; //编码延时时间
extern u8 _return;
int main(void)
MY_NVIC_PriorityGroup_Config(NVIC_PriorityGroup_2); //设置中断分组
delay_init(72); //初始化延时函数
LED_Init(); //初始化LED接口
key_init();
Init_AD9959();
Timerx_Init(99,71);
initial_lcd();
delay_ms(300);
Timer2_Init(delay_time*5,7199); //输出定时器初始化
Write_frequence(0,SinFre[0]);
KeyRead();
Set_PointFre(Keycode, 0);
if(_return)
_return=0;
LCD_Refresh_Gram();
KEY_EXIT();
#include "AD9959.H"
u8 CSR_DATA0[1] = {0x10}; // 开 CH0
u8 CSR_DATA1[1] = {0x20}; // 开 CH1
u8 CSR_DATA2[1] = {0x40}; // 开 CH2
u8 CSR_DATA3[1] = {0x80}; // 开 CH3
u8 FR2_DATA[2] = {0x20,0x00};//default Value = 0x0000
u8 CFR_DATA[3] = {0x00,0x03,0x02};//default Value = 0x000302
u8 CPOW0_DATA[2] = {0x00,0x00};//default Value = 0x0000 @ = POW/2^14*360
u8 LSRR_DATA[2] = {0x00,0x00};//default Value = 0x----
u8 RDW_DATA[4] = {0x00,0x00,0x00,0x00};//default Value = 0x--------
u8 FDW_DATA[4] = {0x00,0x00,0x00,0x00};//default Value = 0x--------
//AD9959初始化
void Init_AD9959(void)
u8 FR1_DATA[3] = {0xD0,0x00,0x00};//20倍频 Charge pump control = 75uA FR1<23> -- VCO gain control =0时 system clock below 160 MHz;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE); //PA,PB,PC端口时钟使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_2|GPIO_Pin_7|GPIO_Pin_6|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;//初始化管脚PA2.3.4.5.6.7.8.9.10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; //IO口速度为2MHz
GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_10;//初始化管脚PB0.1.10
GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //初始化管脚PC0
GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC
Intserve(); //IO口初始化
IntReset(); //AD9959复位
WriteData_AD9959(FR1_ADD,3,FR1_DATA,1);//写功能寄存器1
WriteData_AD9959(FR2_ADD,2,FR2_DATA,1);
// WriteData_AD9959(CFR_ADD,3,CFR_DATA,1);
// WriteData_AD9959(CPOW0_ADD,2,CPOW0_DATA,0);
// WriteData_AD9959(ACR_ADD,3,ACR_DATA,0);
// WriteData_AD9959(LSRR_ADD,2,LSRR_DATA,0);
// WriteData_AD9959(RDW_ADD,2,RDW_DATA,0);
// WriteData_AD9959(FDW_ADD,4,FDW_DATA,1);
//写入初始频率
Write_frequence(3,SinFre[3]);
Write_frequence(1,SinFre[1]);
Write_frequence(2,SinFre[2]);
Write_Phase(3, SinPhr[3]);
Write_Phase(0, SinPhr[0]);
Write_Phase(1, SinPhr[1]);
Write_Phase(2, SinPhr[2]);
Write_Amplitude(3, SinAmp[3]);
Write_Amplitude(0, SinAmp[0]);
Write_Amplitude(1, SinAmp[1]);
Write_Amplitude(2, SinAmp[2]);
//延时
void delay1 (u32 length)
length = length*12;
while(length--);
//IO口初始化
void Intserve(void)
AD9959_PWR=0;
CS = 1;
SCLK = 0;
UPDATE = 0;
PS0 = 0;
PS1 = 0;
PS2 = 0;
PS3 = 0;
SDIO0 = 0;
SDIO1 = 0;
SDIO2 = 0;
SDIO3 = 0;
//AD9959复位
void IntReset(void)
Reset = 0;
delay1(1);
Reset = 1;
delay1(30);
Reset = 0;
//AD9959更新数据
void IO_Update(void)
UPDATE = 0;
delay1(2);
UPDATE = 1;
delay1(4);
UPDATE = 0;
函数功能:控制器通过SPI向AD9959写数据
RegisterAddress: 寄存器地址
NumberofRegisters: 所含字节数
*RegisterData: 数据起始地址
temp: 是否更新IO寄存器
void WriteData_AD9959(u8 RegisterAddress, u8 NumberofRegisters, u8 *RegisterData,u8 temp)
u8 ControlValue = 0;
u8 ValueToWrite = 0;
u8 RegisterIndex = 0;
u8 i = 0;
ControlValue = RegisterAddress;
//写入地址
SCLK = 0;
CS = 0;
for(i=0; i<8; i++)
SCLK = 0;
if(0x80 == (ControlValue & 0x80))
SDIO0= 1;
SDIO0= 0;
SCLK = 1;
ControlValue <<= 1;
SCLK = 0;
//写入数据
for (RegisterIndex=0; RegisterIndex<NumberofRegisters; RegisterIndex++)
ValueToWrite = RegisterData[RegisterIndex];
for (i=0; i<8; i++)
SCLK = 0;
if(0x80 == (ValueToWrite & 0x80))
SDIO0= 1;
SDIO0= 0;
SCLK = 1;
ValueToWrite <<= 1;
SCLK = 0;
if(temp != 0)
IO_Update();
CS = 1;
函数功能:设置通道输出频率
Channel: 输出通道
Freq: 输出频率
void Write_frequence(u8 Channel,u32 Freq)
u8 CFTW0_DATA[4] ={0x00,0x00,0x00,0x00}; //中间变量
u32 Temp;
Temp=(u32)Freq*8.589934592; //将输入频率因子分为四个字节 8.589934592=(2^32)/500000000 其中500M=25M*20(倍频数可编程)
CFTW0_DATA[3]=(u8)Temp;
CFTW0_DATA[2]=(u8)(Temp>>8);
CFTW0_DATA[1]=(u8)(Temp>>16);
CFTW0_DATA[0]=(u8)(Temp>>24);
if(Channel==0)
WriteData_AD9959(CSR_ADD,1,CSR_DATA0,1);//控制寄存器写入CH0通道
WriteData_AD9959(CFTW0_ADD,4,CFTW0_DATA,1);//CTW0 address 0x04.输出CH0设定频率
else if(Channel==1)
WriteData_AD9959(CSR_ADD,1,CSR_DATA1,1);//控制寄存器写入CH1通道
WriteData_AD9959(CFTW0_ADD,4,CFTW0_DATA,1);//CTW0 address 0x04.输出CH1设定频率
else if(Channel==2)
WriteData_AD9959(CSR_ADD,1,CSR_DATA2,1);//控制寄存器写入CH2通道
WriteData_AD9959(CFTW0_ADD,4,CFTW0_DATA,1);//CTW0 address 0x04.输出CH2设定频率
else if(Channel==3)
WriteData_AD9959(CSR_ADD,1,CSR_DATA3,1);//控制寄存器写入CH3通道
WriteData_AD9959(CFTW0_ADD,4,CFTW0_DATA,1);//CTW0 address 0x04.输出CH3设定频率
函数功能:设置通道输出幅度
Channel: 输出通道
Ampli: 输出幅度
void Write_Amplitude(u8 Channel, u16 Ampli)
u16 A_temp;//=0x23ff;
u8 ACR_DATA[3] = {0x00,0x00,0x00};//default Value = 0x--0000 Rest = 18.91/Iout
A_temp=Ampli|0x1000;
ACR_DATA[2] = (u8)A_temp; //低位数据
ACR_DATA[1] = (u8)(A_temp>>8); //高位数据
if(Channel==0)
WriteData_AD9959(ACR_ADD,3,ACR_DATA,1);
else if(Channel==1)
else if(Channel==2)
else if(Channel==3)
函数功能:设置通道输出相位
Channel: 输出通道
Phase: 输出相位,范围:0~16383(对应角度:0°~360°)
void Write_Phase(u8 Channel,u16 Phase)
u16 P_temp=0;
P_temp=(u16)Phase;
CPOW0_DATA[1]=(u8)P_temp;
CPOW0_DATA[0]=(u8)(P_temp>>8);
if(Channel==0)
WriteData_AD9959(CPOW0_ADD,2,CPOW0_DATA,1);
else if(Channel==1)
else if(Channel==2)
else if(Channel==3)
Keil5代码下载(仅供参考):
代码.7z
(230.54 KB, 下载次数: 36)
2022-5-25 16:33 上传
点击文件名下载附件
下载积分: 黑币 -5
