最近在看MAX30102,苦于是英文文档有哪位大哥有中文文档吗?或者流程
ysy50
2022-6-11 10:18
如题
iamwzc
2022-6-11 15:00
用下搜索引擎吧,一搜一大把的心得
Hephaestus
2022-6-11 15:29
硬着头皮看下去就行了呗,第一次总是特别难,过了这一关以后就特别简单了。不懂英语还要搞电子,永远给人打杂的命。
kmsj
2022-6-11 15:45
用可以复制的pdf阅读软件打开,关键的东西复制到在线翻译软件,慢慢就能看懂,我就是这样看的,多看就发现自己的英文水平略有提高,加密的pdf文档或者图片扫描的pdf文档就麻烦了。
angmall
2022-6-11 17:24
MAX30102是一款基于PPG((PhotoPlethysmoGraphy)的集成脉搏血氧仪和心率监测生物传感器模块。体积小,可以戴在手指或手腕上进行数据采集。内部集成18bit ADC,传感器支持I2C 数据输出,可兼容大多数控制器。
* @file basicRead.ino
* @brief Output readings of red light and IR
* @n This library supports mainboards: ESP8266, FireBeetle-M0, UNO, ESP32, Leonardo, Mega2560
* @copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
* @licence The MIT License (MIT)
* @author [YeHangYu](hangyu.ye@dfrobot.com)
* @version V0.1
* @date 2020-05-29
* @url https://github.com/DFRobot/DFRobot_MAX30102
#include <DFRobot_MAX30102.h>
DFRobot_MAX30102 particleSensor;
Macro definition opions in sensor configuration
sampleAverage: SAMPLEAVG_1 SAMPLEAVG_2 SAMPLEAVG_4
SAMPLEAVG_8 SAMPLEAVG_16 SAMPLEAVG_32
ledMode: MODE_REDONLY MODE_RED_IR MODE_MULTILED
sampleRate: PULSEWIDTH_69 PULSEWIDTH_118 PULSEWIDTH_215 PULSEWIDTH_411
pulseWidth: SAMPLERATE_50 SAMPLERATE_100 SAMPLERATE_200 SAMPLERATE_400
SAMPLERATE_800 SAMPLERATE_1000 SAMPLERATE_1600 SAMPLERATE_3200
adcRange: ADCRANGE_2048 ADCRANGE_4096 ADCRANGE_8192 ADCRANGE_16384
void setup()
//Init serial
Serial.begin(115200);
*@brief Init sensor
*@param pWire IIC bus pointer object and construction device, can both pass or not pass parameters (Wire in default)
*@param i2cAddr Chip IIC address (0x57 in default)
*@return true or false
while (!particleSensor.begin()) {
Serial.println("MAX30102 was not found");
delay(1000);
*@brief Use macro definition to configure sensor
*@param ledBrightness LED brightness, default value: 0x1F(6.4mA), Range: 0~255(0=Off, 255=50mA)
*@param sampleAverage Average multiple samples then draw once, reduce data throughput, default 4 samples average
*@param ledMode LED mode, default to use red light and IR at the same time
*@param sampleRate Sampling rate, default 400 samples every second
*@param pulseWidth Pulse width: the longer the pulse width, the wider the detection range. Default to be Max range
*@param adcRange Measurement Range, default 4096 (nA), 15.63(pA) per LSB
particleSensor.sensorConfiguration(/*ledBrightness=*/0x1F, /*sampleAverage=*/SAMPLEAVG_4, \
/*ledMode=*/MODE_MULTILED, /*sampleRate=*/SAMPLERATE_400, \
/*pulseWidth=*/PULSEWIDTH_411, /*adcRange=*/ADCRANGE_4096);
void loop()
//Print result
Serial.print("R=");
*@brief Get red value
*@return Red light reading
Serial.print(particleSensor.getRed());
Serial.print(" IR=");
*@brief Get IR value
*@return IR reading
Serial.print(particleSensor.getIR());
Serial.println();
delay(100);
雪玉寐影
2022-6-11 23:15
某度文库不是有中文的吗?
天ノ忆
2022-6-13 13:21
反正我是背单词,这个行业参数的词汇就那么点,背呗,英文不好这条路很容易看到头
Y_G_G
2022-6-13 14:37
如果PDF是图片格式的,那就只能慢慢的去找中文的了
如果是文字格式的,页面比较少的话,用PDF编辑软件加百度翻译,复制粘贴机器翻译就行了
如果是页面比较多,直接上谷歌翻译,机器翻译整个文件(300页以下都可以),然后下载就行
手动翻译的好处是可以修正一下机器翻译的直译,比如电流的"I",机器会直接翻译成"我"
如果文档已经加密,有专门的PDF解密网站,先进行解密再编辑
整个过程除了要电脑的电费和你自己的时间以外,是不要钱的
唉了,说多了都是泪呀,真搞不明白,现在竟然网一堆键盘整天哇哇的叫着取消英语.........
arsheng
2022-6-13 16:53
本站就有了,可以搜索一下喔。
