单片机按键异常的不灵敏,求各位大佬指教程序
雨人1212
2022-8-30 22:49
单片机主程序:
#include "reg52.h"
#include <intrins.h>
#include<OLED.h>
#include "key.h"
#include"delay.h"
#include"show_num.h"
#include"light.h"
uint key_scan();
void light_time();
void Math_Distance(uint distance);
sbit echo = P2^7;
sbit trig = P2^3;
sbit beep = P2^4;
bit flag = 0; //测量成功标志位全局参定义
uint time_H,time_L; //暂存值,只用来存储定时器的高低八位返回数值
uint time; //时间
uint max=2,min=1; //单位为米
uint cm_table1[2]={0,0};
uint cm_table2[2]={0,0}; //储存距离参数的数组
uint maxnum[2]={0,0};
uint minnum[2]={0,0};
uint distance = 0; //参数:距离
uint save = 0; //参数:(上一次的)距离保存。用于修正错误值
uint i = 5;
beep=0; //蜂鸣器上电后不响
delay(1000);
OLED_Init(); // OLED初始化
OLED_Fill(0x00);
trig = 0; //先关触发信号 //指示灯
TMOD = 0x10; //开定时器1-> 0001_0000 16位工作方式
TH1 = 0; //定时器高八位初填装值清空
TL1 = 0; //定时器低八位初填装值清空
TF1=0; //T1溢出中断标志位。可自动由硬件至高/清零
ET1 = 0; //T1中断使能
EA = 1; //开总中断
flag = 0; //标志位清0
trig = 1; //给触发信号
delay_20us(); //等那么一小段时间
trig = 0; //关触发信号 ————这样就给了一小段高电平触发信号,以至于不会一直触发
while(!echo); //等待接收端出现高电平(如果是低,那就一直等)
TR1 = 1; //T1运行控制位,开始计时
while(echo); //等待高电平结束(如果是高,那就一直等)
TR1 = 0; //关定时器T1
time_H = TH1; //把T1的高低八位定时数据取出
time_L = TL1; // ↑
if(flag == 0) //如果测距成功
time=time_H*256+time_L; //将定时器的高低八位返回值赋给时间参数time
distance = time*0.173; //来回1/2*时间time*声速346(m/s)*0.001(单位换算:mm)
save = distance; //暂存正确的距离值
if(distance > max*1000)
beep = 1;
if(distance <= max*1000 && distance >= min*1000)
beep = 0;
light_time();
if(distance < min*1000)
beep = 1;
delay(50000);
beep=0;
Math_Distance(distance);
else if(flag == 1)
distance = save;
switch(key_scan())
case 0:
break;
case 1:
if(max == 10)
max = 10;
max++;
break;
case 2:
if(max == 0)
max = 0;
max--;
break;
case 3:
if(min == 10)
min = 10;
min++;
break;
case 4:
if(min == 0)
min = 0;
min--;
break;
default:
break;
OLED_P6x8Str(0,1,"maximums:");
Show_Number(8,2,maxnum,2);
OLED_P8x16Str(26,2,"m");
OLED_P6x8Str(74,1,"minimums:");
Show_Number(82,2,minnum,2);
OLED_P8x16Str(100,2,"m");
OLED_P8x16Str(28,4,"distance:");
OLED_P8x16Str(78,6,"dm");
Show_Number(32,6,cm_table1,2);
OLED_P6x8Str(50,7,".");
Show_Number(58,6,cm_table2,2);
delay(5000);
* 函 数 名 : Math_Distance
void Math_Distance(uint distance) //距离值数学转换
cm_table1[0]=distance/1000;
cm_table1[1]=distance/100;
cm_table2[0]=distance%100/10;
cm_table2[1]=distance%100%10;
maxnum[0]=max/10;
maxnum[1]=max%10;
minnum[0]=min/10;
minnum[1]=min%10;
按键检测:
#include"key.h"
sbit A4 = P2^0;
sbit A5 = P3^3;
sbit A6 = P2^1;
sbit A7 = P2^2;
* 函数名: 键值函数
uint key_scan()
uint keynum = 0;
if(A4 == 0)
keynum = 1;
if(A5 == 0)
keynum = 2;
if(A6 == 0)
keynum = 3;
if(A7 == 0)
keynum = 4;
return keynum;
yzwzfyz
2022-8-31 08:28
灵敏:是指在短时间内能响应你的事件。
这里理解为,你按下了键,CPU在短时间就发现了,且响应了一下。
为何不灵敏了呢?因为在这段时间时,CPU【干私活】不理采你的按键了。
查一查,有没有CPU耗时长的程序部分。要想键灵敏,必须保CPU在短时间内能扫键一下。
lkc8210
2022-8-31 09:00
不要用delay
OLED显示常量只须在初始化时更新一次,如OLED_P6x8Str(0,1,"maximums:");
OLED显示变量可以定时更新或变量有变化时更新
xxxevery
2022-9-1 00:09
如果main函数里干的事情太多,就会影响到一些要求实时响应的工作,最好就把按键检测放到定时中断函数里去,可以设定个10ms中断检测一次按键情况,就不会有按键不灵敏的感觉了
wufa1986
2022-9-1 08:07
使用非阻塞编程,或者直接上系统多个while
starsphere
2022-9-2 23:36
扫描按键是否按下可以用定时器来扫描,这样可以避免在执行其他耗时操作时,无法扫描按键
