1. libncursesw.so.5: cannot open shared object file
首先是会有这样的错误输出
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb -q --interpreter=mi2
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: error while loading shared libraries: libncursesw.so.5: cannot open shared object file: No such file or directory
观察ldd可以看到缺少两个so: libncursesw.so.5, libpython3.6m.so.1.0
2. libpython3.6m.so.1.0: cannot open shared object file
这样就剩下另一个动态连接库无法找到
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: error while loading shared libraries: libpython3.6m.so.1.0: cannot open shared object file: No such file or directory
但是 Ubuntu20.04 自带的 Python3.8, 无法安装 Python3.6
~$ sudo apt-get install libpython3.6
Reading package lists... Done
Building dependency tree
Reading state information... Done
Note, selecting 'libpython3.6-stdlib' for regex 'libpython3.6'
0 upgraded, 0 newly installed, 0 to remove and 29 not upgraded.
$ /opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb -q --interpreter=mi2
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: Symbol `PyBool_Type' has different size in shared object, consider re-linking
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: Symbol `PySlice_Type' has different size in shared object, consider re-linking
/opt/gcc-arm/gcc-arm-11.2-2022.02-x86_64-arm-none-eabi/bin/arm-none-eabi-gdb: Symbol `PyFloat_Type' has different size in shared object, consider re-linking
=thread-group-added,id="i1"
(gdb)
使用
点击 Run And Debug 中的绿色运行图标启动Debug, F10 下一步, F11 进入, Shift + F11 跳出. 左侧能观察到变量值和寄存器值. 操作方法和其它IDE基本一致.
