ST7735驱动程序
kinglighting
2022-9-19 14:55
ST7735驱动程序
(92.87 KB, 下载次数: 39)
下载附件
2022-9-19 14:55 上传
void ST7735S_init(void)
/* ST7735R Reset Sequence */
LCD_RST_HIGH;
delay(5); //Delay 1ms
LCD_RST_LOW;
LCD_RST_HIGH;
delay(120); //Delay 120ms
/* End ST7735S Reset Sequence */
Lcd_WriteCmd(0x01); //SWRESET Software reset
delay(130);
Lcd_WriteCmd(0x11); //Sleep out
delay(130); //Delay 120ms
/* ST7735S Frame rate */
Lcd_WriteCmd(0xB1); //Frame rate 80Hz
Lcd_WriteData(0x05);
Lcd_WriteData(0x3C);
Lcd_WriteCmd(0xB2); //Frame rate 80Hz
Lcd_WriteCmd(0xB3); //Frame rate 80Hz
/* End ST7735S Frame rate */
Lcd_WriteCmd(0xB4); //Dot inversion
Lcd_WriteData(0x03);
/* ST7735S Power Sequence */
Lcd_WriteCmd(0xC0); //Power control 1
Lcd_WriteData(0xA2); //AVDD=5,GVDD=4.6
Lcd_WriteData(0x02); //GVCL=-4.6
Lcd_WriteData(0x84); //AUTO,VRHN5=0,VRHP5=0
Lcd_WriteCmd(0xC1); //Power control 2
Lcd_WriteData(0xC5); //V25=2.4,VGL=-10,VGH=3*AVDD-0.5
Lcd_WriteCmd(0xC2); //Power control 3
Lcd_WriteData(0x0D); //Large current,Small current
Lcd_WriteData(0x00);
Lcd_WriteCmd(0xC3); //Power control 4
Lcd_WriteData(0x8D); //
Lcd_WriteData(0x2A);
Lcd_WriteCmd(0xC4); //Power control 5
Lcd_WriteData(0xEE);
/* End ST7735S Power Sequence */
Lcd_WriteCmd(0xC5); //VCOM
Lcd_WriteData(0x0a); //VCOM=-0.675
Lcd_WriteCmd(0x36); //MX, MY, RGB mode; 控制显示方向
Lcd_WriteData(0xC0); //0xC8 LCD refresh Top to Bottom, Left to right
/* ST7735S Gamma Sequence */
Lcd_WriteCmd(0xE0);
Lcd_WriteData(0x12);
Lcd_WriteData(0x1C);
Lcd_WriteData(0x10);
Lcd_WriteData(0x18);
Lcd_WriteData(0x33);
Lcd_WriteData(0x2C);
Lcd_WriteData(0x25);
Lcd_WriteData(0x28);
Lcd_WriteData(0x27);
Lcd_WriteData(0x2F);
Lcd_WriteCmd(0xE1);
Lcd_WriteData(0x2D);
Lcd_WriteData(0x23);
Lcd_WriteData(0x26);
Lcd_WriteData(0x3B);
Lcd_WriteCmd(0x2A); //设置列地址
Lcd_WriteData(0x7F);//128
Lcd_WriteCmd(0x2B); //设置行地址
Lcd_WriteData(0x9F);//160
Lcd_WriteCmd(0xF0); //Enable test command
Lcd_WriteData(0x01);
Lcd_WriteCmd(0xF6); //Disable ram power save mode
/* End ST7735S Gamma Sequence */
Lcd_WriteCmd(0x3A); //65k mode
Lcd_WriteCmd(0x29); //Display on
Lcd_WriteCmd(0x2c);
delay(50);
kinglighting
2022-9-19 14:59
这是近期做的一个项目中的TFT显示部分,用的是1.77寸的屏,驱动芯片是st7735。4线SPI接口,单片机模拟驱动时序
