标题: STM32单片机使用SPI控制器件,都返回值一直为0xFF [打印本页]
作者: 1123qqw    时间: 2022-10-14 19:29
这个是SPI初始化代码
void SPIx_I2Cx_GPIOs_Init(void* bus_type)
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,  DISABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO,  ENABLE);
        //SPI1_NSS
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PA4
        GPIO_Init(GPIOA,&GPIO_InitStructure);
      //SPI1_CLK
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;//PA5
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        //SPI_MISO
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;//PA6
        //SPI_MOSI
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;//PA7
        SPI_I2S_DeInit(bus_type);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;//PD4
        GPIO_Init(GPIOD, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PD3
        // SPIx Enable = 0 for SPI Mode // SPIx Enable = RSN for GP22
        GPIO_WriteBit(GPIOD, GPIO_Pin_3, Bit_RESET);
void SPIx_I2Cx_Interface_Init(void* bus_type)
        SPI_InitTypeDef SPI_InitStructure;
        //RCC_SYSCLKConfig (RCC_SYSCLKSource_HSI);
        //RCC_HCLKConfig (RCC_SYSCLK_Div1);
        RCC_APB2PeriphResetCmd (RCC_APB2Periph_SPI1, DISABLE);
        RCC_APB2PeriphClockCmd (RCC_APB2Periph_SPI1, ENABLE);
        // All are defined in stm32f10x_spi.h
  SPI_InitStructure.SPI_Direction         = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode              = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize          = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL              = SPI_CPOL_Low;
  SPI_InitStructure.SPI_CPHA              = SPI_CPHA_2Edge;//
  SPI_InitStructure.SPI_NSS               = SPI_NSS_Soft;
  // SPI frequence devider
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
  SPI_InitStructure.SPI_FirstBit          = SPI_FirstBit_MSB;
  // Apply SPIx configuration
  SPI_Init(bus_type, &SPI_InitStructure);
  // Enabling the SPIx Interface
  SPI_Cmd(bus_type, ENABLE);
  // Enabling the NSS Output during transmission
//  SPI_SSOutputCmd (bus_type, ENABLE);
        GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_SET);
这个是应用代码:
unsigned char Send_24Bit_Opcode(unsigned char command, unsigned short address, unsigned char data)
  unsigned char    Result_read = 0;
  // x >> y, mean x is shifted by y bit-positions to the right
  unsigned char Byte_0  = data;
  unsigned char Byte_1  = address;
  unsigned char Byte_2  = address>>8 | command;
  // SPIx BUS_TYPE -------------------------------------------------------------
  // Deactivating Reset SPIx
  GPIO_WriteBit(GPIOA, GPIO_Pin_4, Bit_RESET);
  // GPIO_WriteBit(GPIOB, GPIO_Pin_12, Bit_RESET);
   while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE)==0) {}
   SPI_I2S_SendData(SPI1, Byte_2);     // send byte 2
   SPI_I2S_SendData(SPI1, Byte_1);     // send byte 1
   if (command==0x90) // write command
     SPI_I2S_SendData(SPI1, Byte_0);     // send byte 0
    Simple_delay_43ns((void*)10); // important delay (16) at SPI freq.=750kHz
   if (command==0x10) // read command
     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE)==RESET) {};
     //Compulsory reads to DR and SR to clear OVR,
     //so that next incoming data is saved
     SPI_I2S_ReceiveData(SPI1);                     // To clear OVR
     SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE); // To clear OVR
     //Reading byte1
     SPI_I2S_SendData(SPI1, 0xFF);  // DUMMY WRITE
     // Wait until RX buffer is not empty, then read the received data
     while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE)==0) {}
     Result_read = SPI_I2S_ReceiveData(SPI1); //  Read
     // Reset to device SPIx
     //GPIO_WriteBit(GPIOB, GPIO_Pin_12, Bit_SET);
  return Result_read;
Send_24Bit_Opcode(0x90,1,0x55);//0x90 写
err =  Send_24Bit_Opcode(0x10,1,0xff);//err = 0x55 0x10读
在使用的过程中,怎么弄也读不出来正确的数值,现在读出来的都是0xff。请大家看看究竟是哪出现了问题。
情景是:
用STM32控制器件,通讯使用SPI1,器件要求spi: CPOL=0;CPHA=1;MODE=1;DORD为0,MSB最先输出。
作者: adject    时间: 2022-10-14 19:29
SPI_InitStructure.SPI_NSS               = SPI_NSS_Soft; 由软件控制就不需要 SPI_SSOutputCmd (bus_type, ENABLE);
作者: 1123qqw    时间: 2022-10-15 12:19
adject 发表于 2022-10-14 22:57
SPI_InitStructure.SPI_NSS               = SPI_NSS_Soft; 由软件控制就不需要 SPI_SSOutputCmd (bus_typ ...
是的,我注释掉了,忘记修改了。我经过昨天测试,感觉是硬件问题,正在修改
