标题: Proteus画PCB出错Connectors have been pre-annotated as J1,J2,J3 and J4 so you ... [打印本页] 作者: 瞌睡哥 时间: 2022-12-3 21:51 标题: Proteus画PCB出错Connectors have been pre-annotated as J1,J2,J3 and J4 so you ... Connectors have been pre-annotated as J1,J2,J3 and J4 so you must manually annotate the corresponding connectors in the schematic.接头已预先标注为J1、J2、J3和J4,因此必须手动标注原理图中的相应接头。
