#include "reg51.h" #include <intrins.h> #include <absacc.h> #define uchar unsigned char //定义unsigned char 为 uchar #define uint unsigned int #define keyport P3 //lcd忙检测标志 #define disport P0 uchar key,temp; uchar code dis[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7C,0x39,0x5E,0x79,0x71}; /***************一微秒延时子程序******************/ void delayus(uint delay){ while(delay--); } /***************一毫秒延时子程序******************/ void delayms(uint delay){ while(delay--) delayus(100); } /******************************************************/ uchar getkey() { keyport=0xef; //扫描第三列 temp=keyport; if(temp!=0xef) {delayms(10); temp=keyport; if(temp!=0xef) while((keyport&0x0F)!=0x0F) ; switch(temp) { case 0xee: key=0;break; case 0xed: key=1;break; case 0xeb: key=2;break; case 0xe7: key=3;break; } return key; //返回键值 } keyport=0xdf; //扫描第一列 temp=keyport; if(temp!=0xdf) {delayms(10); temp=keyport; if(temp!=0xdf) while((keyport&0x0f)!=0x0f) ; switch(temp) { case 0xde: key=4;break; case 0xdd: key=5;break; case 0xdb: key=6;break; case 0xd7: key=7;break; } return key; //返回键值 } keyport=0xbf; //扫描第二列 temp=keyport; if(temp!=0xbf) {delayms(10); temp=keyport; if(temp!=0xbf) while((keyport&0x0F)!=0x0F) ; switch(temp) { case 0xbe: key=8;break; case 0xbd: key=9;break; case 0xbb: key=10;break; case 0xb7: key=11;break; } return key; //返回键值 } keyport=0x7f; //扫描第三列 temp=keyport; if(temp!=0x7f) {delayms(10); temp=keyport; if(temp!=0x7f) while((keyport&0x0F)!=0x0F) ; switch(temp) { case 0x7e: key=12;break; case 0x7d: key=13;break; case 0x7b: key=14;break; case 0x77: key=15;break; } return key; //返回键值 } } void main() { EA = 0; while(1) { disport=dis[getkey()] ; P2=0x04; } } |
