想寻求一个通过光敏电阻控制led亮暗程度的代码
1234590qwehjm
2023-4-14 18:08
谢谢大家
1234590qwehjm
2023-4-14 18:08
基于stc15
afasga
2023-4-14 19:38
#include "ADC1.h"
//光敏
void ADC1_Init(void)
//使能PC口时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
//配置IO口 模拟输入
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.GPIO_Mode=GPIO_Mode_AN;
//GPIO_InitStruct.GPIO_OType=
GPIO_InitStruct.GPIO_Pin=GPIO_Pin_0;
//GPIO_InitStruct.GPIO_PuPd=
GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStruct);
//配置ADC--12精度 右对齐 单次不扫描 通道数1
RCC_APB2PeriphClockLPModeCmd(RCC_APB2Periph_ADC1, ENABLE);
ADC_InitTypeDef ADC_InitStruct={0};
ADC_Init(ADC1, &ADC_InitStruct);
ADC_InitStruct.ADC_ContinuousConvMode=DISABLE; //连续单次模式
ADC_InitStruct.ADC_DataAlign=ADC_DataAlign_Right; //数据对齐(左or右)
// ADC_InitStruct.ADC_ExternalTrigConv= //外部触发方式
// ADC_InitStruct.ADC_ExternalTrigConvEdge= //外部触发极性配置
ADC_InitStruct.ADC_NbrOfConversion =1; //AD转换通道数
ADC_InitStruct.ADC_Resolution =ADC_Resolution_12b;//分辨率
ADC_InitStruct.ADC_ScanConvMode = DISABLE; //扫描模式
//配置--独立模式 采样频率 两次采样间隔时间 是否使能DMA
ADC_CommonInitTypeDef ADC_CommonInitStruct;
ADC_CommonInitStruct.ADC_DMAAccessMode=ADC_DMAAccessMode_Disabled;
ADC_CommonInitStruct.ADC_Mode=ADC_Mode_Independent; //独立模式,单个ADC使用
ADC_CommonInitStruct.ADC_Prescaler=ADC_Prescaler_Div4; //采样频率(84/4<36)
ADC_CommonInitStruct.ADC_TwoSamplingDelay=ADC_TwoSamplingDelay_20Cycles;//两次采样延时
ADC_CommonInit(&ADC_CommonInitStruct);
ADC_Cmd(ADC1, ENABLE);
// ADC_SoftwareStartConv(ADC1);//软件触发使能
//设定ADC规则组通道,转化顺序和采样时间
// ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_480Cycles);
u16 ADC1_Read_Value(void)
while(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC)==0);//等待规则组转换完成
ADC_ClearFlag(ADC1, ADC_FLAG_EOC); //清规则组转换完成标记位
return ADC_GetConversionValue(ADC1);//返回读取到的ADC值
//pwm灯光控制
#include "pwm.h"
void TIM3_PWM_Init(int psc,int val) //psc预分频系数 val重装载值
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);//使能TIM3时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
// GPIO_InitTypeDef Fan3;//风扇 PC8
GPIO_InitTypeDef Led3;//LED3 PB0
TIM_OCInitTypeDef PWM={0};
// Fan3.GPIO_Pin=GPIO_Pin_8;
// Fan3.GPIO_Mode=GPIO_Mode_AF;
// Fan3.GPIO_Speed=GPIO_Speed_2MHz ;
// Fan3.GPIO_OType=GPIO_OType_PP;
// Fan3.GPIO_PuPd=GPIO_PuPd_UP;
// GPIO_Init(GPIOC,&Fan3);
// GPIO_PinAFConfig(GPIOC,GPIO_PinSource8,GPIO_AF_TIM3);
Led3.GPIO_Pin=GPIO_Pin_0;
Led3.GPIO_Mode=GPIO_Mode_AF;
Led3.GPIO_Speed=GPIO_Speed_2MHz ;
Led3.GPIO_OType=GPIO_OType_PP;
Led3.GPIO_PuPd=GPIO_PuPd_UP;
GPIO_Init(GPIOB,&Led3);
GPIO_PinAFConfig(GPIOB,GPIO_PinSource0,GPIO_AF_TIM3);
PWM.TIM_Pulse=0;//先写0,默认为0%低电平
PWM.TIM_OCMode=TIM_OCMode_PWM1;//PWM1模式
PWM.TIM_OCPolarity=TIM_OCPolarity_Low;//低电平有效
PWM.TIM_OutputState=TIM_OutputState_Enable;//使能输出控制
TIM_OC3Init(TIM3,&PWM);
TIM_TimeBaseInitTypeDef T3;//基本定时器初始化结构体
T3.TIM_ClockDivision=TIM_CKD_DIV1;//时钟分频
T3.TIM_CounterMode=TIM_CounterMode_Up;//向下计数模式
T3.TIM_Period=val;//重装载值(计时,systick是记次数)
T3.TIM_Prescaler=psc-1;//预分频
T3.TIM_RepetitionCounter=0;//tim1 和tim8有
TIM_TimeBaseInit(TIM3,&T3);//基本定时器初始化
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);//定时器中断配置使能
TIM_Cmd(TIM3,ENABLE);//使能TIM3
1234590qwehjm
2023-4-15 16:08
afasga 发表于 2023-4-14 19:38
#include "ADC1.h"
//光敏
谢谢,但是请问有51的程序吗
