stm32单片机流水灯代码
heidianzilt
2023-4-21 11:37
stm32单片机流水灯代码
代码:
#include "stm32f10x.h"
#include "bsp_led.h"
#include "bsp_key.h"
void Tim3_Int_Init(u16 arr,u16 psc);
void TIM3_IRQHandler(void);
int x = 1;
int mode = 0;
int change = 0;
int y = 1;
* @brief 主函数
* @param 无
* @retval 无
int main(void)
/* LED 端口初始化 */
LED_GPIO_Config();
while (1)
if (mode==1 && change==0)
Tim3_Int_Init(4999, 7199);
change = 1;
else if (mode==2 && change==0)
Tim3_Int_Init(7199, 9999);
change = 1;
TIM3_IRQHandler();
if( Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_PIN) == KEY_ON )
mode += 1;
change = 0;
if (mode >= 5)
mode = 1;
if( Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_PIN) == KEY_ON )
y += 1;
LED1_ON;
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;//配置定时器时钟
NVIC_InitTypeDef NVIC_InitStruct;//配置中断控制器
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);//使能定时器时钟
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;//设置时钟分割
TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;//设置为向上计数模式
TIM_TimeBaseInitStruct.TIM_Period = arr;//设置在下一个更新时间装入活动的自动重装载寄存器周期的值
TIM_TimeBaseInitStruct.TIM_Prescaler = psc;//预分频值
TIM_TimeBaseInit(TIM3,&TIM_TimeBaseInitStruct);//初始化
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);//使能TIM3中断,允许更新中断
NVIC_InitStruct.NVIC_IRQChannel = TIM3_IRQn;
NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStruct.NVIC_IRQChannelSubPriority = 3;
NVIC_Init(&NVIC_InitStruct);//NVIC
TIM_Cmd(TIM3,ENABLE);//使能TIM3
if(TIM_GetITStatus(TIM3,TIM_IT_Update) == 1)//检查TIM3更新中断发生与否
TIM_ClearITPendingBit(TIM3,TIM_IT_Update);//清除TIMx更新中断标志
x += 1;
switch(mode)
case 1:
if (x==1)
LED3_OFF;
LED1_ON;
else if (x==2)
LED1_OFF;
LED2_ON;
else if (x==3)
LED2_OFF;
LED3_ON;
x = 0;
break;
case 2:
if (x==1)
LED2_OFF;
LED3_OFF;
LED1_ON;
else if (x==2)
LED2_ON;
LED3_ON;
x = 0;
break;
case 3:
if (y==1)
LED3_OFF;
LED1_ON;
else if (y==2)
LED1_OFF;
LED2_ON;
else if (y==3)
LED2_OFF;
LED3_ON;
y = 1;
break;
default:
break;
