ST7735 1.8寸51单片机例程
DDs99s
2023-5-26 17:10
ST7735 1.8寸51单片机例程
void ST7735_INITIAL ()
//------------------------------------ST7735R Reset Sequence-----------------------------------------//
RES =1;
delay (1); //Delay 1ms
RES =0;
RES =1;
delay (120); //Delay 120ms
//--------------------------------End ST7735R Reset Sequence --------------------------------------//
//--------------------------------End ST7735S Reset Sequence --------------------------------------//
LCD_WriteCommand(0x11); //Sleep out
delay(120); //Delay 120ms
//------------------------------------ST7735S Frame Rate-----------------------------------------//
LCD_WriteCommand(0xB1);
LCD_WriteData(0x05);
LCD_WriteData(0x3C);
LCD_WriteCommand(0xB2);
LCD_WriteCommand(0xB3);
//------------------------------------End ST7735S Frame Rate---------------------------------//
LCD_WriteCommand(0xB4); //Dot inversion
LCD_WriteData(0x03);
//------------------------------------ST7735S Power Sequence---------------------------------//
LCD_WriteCommand(0xC0);
LCD_WriteData(0x28);
LCD_WriteData(0x08);
LCD_WriteData(0x04);
LCD_WriteCommand(0xC1);
LCD_WriteData(0XC0);
LCD_WriteCommand(0xC2);
LCD_WriteData(0x0D);
LCD_WriteData(0x00);
LCD_WriteCommand(0xC3);
LCD_WriteData(0x8D);
LCD_WriteData(0x2A);
LCD_WriteCommand(0xC4);
LCD_WriteData(0xEE);
//---------------------------------End ST7735S Power Sequence-------------------------------------//
LCD_WriteCommand(0xC5); //VCOM
LCD_WriteData(0x1A);
LCD_WriteCommand(0x36); //MX, MY, RGB mode
LCD_WriteData(0xC0);
//------------------------------------ST7735S Gamma Sequence---------------------------------//
LCD_WriteCommand(0xE0);
LCD_WriteData(0x22);
LCD_WriteData(0x07);
LCD_WriteData(0x0A);
LCD_WriteData(0x2E);
LCD_WriteData(0x30);
LCD_WriteData(0x25);
LCD_WriteData(0x26);
LCD_WriteData(0x3A);
LCD_WriteData(0x01);
LCD_WriteData(0x13);
LCD_WriteCommand(0xE1);
LCD_WriteData(0x16);
LCD_WriteData(0x06);
LCD_WriteData(0x2D);
LCD_WriteData(0x23);
LCD_WriteData(0x27);
LCD_WriteData(0x3B);
//------------------------------------End ST7735S Gamma Sequence-----------------------------//
LCD_WriteCommand(0x3A); //65k mode
LCD_WriteCommand(0x29); //Display on
Void ST7735SCPT144PanelTurnOnDisplay (void)
Write(COMMAND,0x29); //Display on
Void ST7735SCPT144PanelTurnOffDisplay (void)
Write(COMMAND,0x28); //Display off
Void ST7735SCPT144PanelTurnOnPartial (void)
Write(COMMAND,0x30); //Setup the partial area
Write(DATA,0x00);
Write(DATA,PSL); //PSL:Start Line
Write(DATA,0x00);
Write(DATA,PEL); //PEL:End Line
Write(COMMAND,0x12); //Turn on partial mode
Void ST7735SCPT144PanelTurnOffPartial (void)
Write(COMMAND,0x13); //Turn off partial mode
Void ST7735SCPT144PanelTurnOnIdle (void)
Write(COMMAND,0x39); //Turn on idle mode
Void ST7735SCPT144PanelTurnOffIdle (void)
Write(COMMAND,0x38); // Turn off idle mode
Void ST7735SCPT144PanelSleepInMode (void)
Write(COMMAND,0x10); //Sleep in
Delayms (120); //Delay 120ms
Void ST7735SCPT144PanelSleepOutMode (void)
Write(COMMAND,0x11); //Sleep out
