STM32F103CBT6单片机与CAN通信,无法接收
wang元
2023-7-10 13:36
用的cbt6调试can,可以帮我看一下驱动程序有什么问题吗?125MHZ的双机通信
#include "stm32f10x.h"
#include "./led/bsp_led.h"
#include "./can/bsp_can.h"
__IO uint32_t flag = 0;
CanTxMsg TxMessage;
CanRxMsg RxMessage;
static void can_delay(__IO u32 nCount)
for(; nCount != 0; nCount--);
int main(void)
LED_GPIO_Config();
CAN_Config();
uint8_t m;
LED1_ON;
LED3_ON;
CAN_SetMsg(&TxMessage);
m=CAN_Transmit(CANx, &TxMessage);
if(CAN_TransmitStatus(CANx,m)==CAN_TxStatus_Ok)
LED1_OFF;
can_delay(10000);
if(flag==1)
LED1_TOGGLE;
flag=0;
static void CAN_GPIO_Config(void)
/* Enable GPIO clock */
RCC_APB2PeriphClockCmd(CAN_TX_GPIO_CLK|CAN_RX_GPIO_CLK, ENABLE);
// //ÖØÓ³ÉäÒý½Å
// GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE);
/* Configure CAN TX pins */
GPIO_InitStructure.GPIO_Pin = CAN_TX_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(CAN_TX_GPIO_PORT, &GPIO_InitStructure);
/* Configure CAN RX pins */
GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(CAN_RX_GPIO_PORT, &GPIO_InitStructure);
static void CAN_NVIC_Config(void)
NVIC_InitTypeDef NVIC_InitStructure;
/* Configure one bit for preemption priority */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/*ÖжÏÉèÖÃ*/
NVIC_InitStructure.NVIC_IRQChannel = CAN_RX_IRQ;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
* º¯ÊýÃû£ºCAN_Mode_Config
* ÃèÊö £ºCANµÄģʽ ÅäÖÃ
* ÊäÈë £ºÎÞ
* Êä³ö : ÎÞ
* µ÷Óà £ºÄÚ²¿µ÷ÓÃ
static void CAN_Mode_Config(void)
CAN_InitTypeDef CAN_InitStructure;
/* Enable CAN clock */
RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
/*CAN¼Ä´æÆ÷³õʼ»¯*/
CAN_DeInit(CANx);
CAN_StructInit(&CAN_InitStructure);
/*CANµ¥Ôª³õʼ»¯*/
CAN_InitStructure.CAN_TTCM=DISABLE;
CAN_InitStructure.CAN_ABOM=DISABLE;
CAN_InitStructure.CAN_AWUM=ENABLE;
CAN_InitStructure.CAN_NART=DISABLE;
CAN_InitStructure.CAN_RFLM=DISABLE;
CAN_InitStructure.CAN_TXFP=ENABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal
CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
CAN_InitStructure.CAN_BS1=CAN_BS1_10tq
CAN_InitStructure.CAN_BS2=CAN_BS2_5tq
CAN_InitStructure.CAN_Prescaler =18
CAN_Init(CANx, &CAN_InitStructure);
在中断里接受
extern __IO uint32_t flag ;
extern CanRxMsg RxMessage;
void CAN_RX_IRQHandler(void)
CAN_Receive(CANx, CAN_FIFO0, &RxMessage);
if((RxMessage.ExtId==0x1314) && (RxMessage.IDE==CAN_ID_EXT) )//&& (RxMessage.DLC==8)
flag = 1;
flag = 0;
sbskywalker
2023-7-10 15:45
请确认 两者设置条件一致,从描述上来看 125MHZ?这是不可能达到的通信速率,主频一般都不能超过72Mhz
wang元
2023-7-10 16:26
STM32的can的最大速率不是可以达到1MHZ吗?
wang元
2023-7-10 16:28
程序里应该是125khz
