stc89c52rc单片机+TEA5767的收音机程序(不带显示)
丙丁先生
2023-7-22 10:34
原理图及代码在附件
(109.1 KB, 下载次数: 34)
下载附件
2023-7-22 15:11 上传
#include <reg51.h>
#include <string.h>
#include <math.h>
#include <uart.h>
#include <i2c.h>
#define max_freq 108000
#define min_freq 87500
sbit KEY1=P3^2;
sbit KEY2=P3^3;
unsigned char radio_write_data[5]={0x29,0xc2,0x20,0x11,0x00}; //要写入TEA5767的数据
//unsigned char radio_write_data[5]={0x2a,0xb6,0x40,0x11,0x40}; //要写入TEA5767的数据
unsigned char radio_read_data[5]; //TEA5767读出的状态
unsigned int default_pll=0x301d; //0x29f9; //默认存台的pll,95.8MHz
//unsigned int max_pll=0x339b; //108MHz时的pll,
//unsigned int min_pll=9000; //70MHz时的pll
unsigned long frequency;
unsigned int pll;
/*void delay(unsigned int time)
while(time--);
void delay1ms (unsigned int b)//1ms
for(b;b>0;b--)
{unsigned int i;
for(i=0;i<300;i++)
void radio_write(void)
unsigned char i;
iic_start();
iic_write8bit(0xc0); //TEA5767写地址
if(!iic_testack())
for(i=0;i<5;i++)
iic_write8bit(radio_write_data[i]);
iic_ack();
iic_stop();
//由频率计算PLL
void get_pll(void)
unsigned char hlsi;
// unsigned int twpll=0;
hlsi=radio_write_data[2]&0x10; //HLSI位
if (hlsi)
pll=(unsigned int)((float)((frequency+225)*4)/(float)32.768); //频率单位:k
pll=(unsigned int)((float)((frequency-225)*4)/(float)32.768); //频率单位:k
//由PLL计算频率
void get_frequency(void)
unsigned char hlsi;
unsigned int npll=0;
npll=pll;
if (hlsi)
frequency=(unsigned long)((float)(npll)*(float)8.192-225); //频率单位:KHz
frequency=(unsigned long)((float)(npll)*(float)8.192+225); //频率单位:KHz
//读TEA5767状态,并转换成频率
void radio_read(void)
unsigned char i;
unsigned char temp_l,temp_h;
pll=0;
iic_start();
iic_write8bit(0xc1); //TEA5767读地址
if(!iic_testack())
for(i=0;i<5;i++)
radio_read_data[i]=iic_read8bit();
iic_ack();
iic_stop();
temp_l=radio_read_data[1];
temp_h=radio_read_data[0];
temp_h&=0x3f;
pll=temp_h*256+temp_l;
get_frequency();
//手动设置频率,mode=1,+0.1MHz; mode=0:-0.1MHz ,不用考虑TEA5767用于搜台的相关位:SM,SUD
void search(bit mode)
radio_read();
if(mode)
frequency+=10;
if(frequency>max_freq)
frequency=min_freq;
frequency-=10;
if(frequency<min_freq)
frequency=max_freq;
get_pll();
radio_write_data[0]=pll/256;
radio_write_data[1]=pll%256;
radio_write_data[2]=0x20;
radio_write_data[3]=0x11;
radio_write_data[4]=0x00;
radio_write();
//自动搜台,mode=1,频率增加搜台; mode=0:频率减小搜台,不过这个好像不能循环搜台
/*void auto_search(bit mode)
radio_read();
get_pll();
if(mode)
radio_write_data[2]=0xa0;
radio_write_data[0]=pll/256+0x40;
radio_write();
radio_read();
while(!(radio_read_data[0]&0x80)) //搜台成功标志
delay(1000);
radio_read();
//disp_freq(9,1);
PutNum(frequency);
UART_Init();//串口初始化
UART_Send_Str("调频收音机\n");
radio_write();
if(KEY1==0)
delay1ms(15); //延时15ms
if(KEY1==0)
while(KEY1==0);//等待按键释放
search(1);
radio_read();
UART_Send_Str("目前频率\n");
UART_Put_Num(frequency);
UART_Send_Str("\n");
if(KEY2==0)
if(KEY2==0)
while(KEY2==0);//等待按键释放
search(0);
radio_read();
Keil代码下载:
01.7z
(59.83 KB, 下载次数: 26)
2023-7-22 15:13 上传
点击文件名下载附件
下载积分: 黑币 -5
joyb
2023-7-22 18:50
手头有BK1088ES和stc89c52rc单片机,能否给个思路
hi等你
2023-7-31 10:38
为啥你们都会画电路图?我连更高难度的TEF6686收音程序都写出来了,电路图都不会画
