MAX6675_STM32单片机程序(OLED显示+热电偶+蓝牙+继电器)
QEQWE123
2023-8-11 09:48
功能如标题已经测试通过
* 文件名 :main.c
* 描述 :通过stm32的spi1读取max6675的温度值,并通过uart1发送出来
* 实验平台:STM32开发板
* 库版本 :ST3.0.0
* 硬件连接: ------------------------------------
* |PA6-SPI1-MISO:MAX6675-SO |
* |PA7-SPI1-MOSI:MAX6675-SI |
* |PA5-SPI1-SCK :MAX6675-SCK |
* |PA4-SPI1-NSS :MAX6675-CS |
#include "stm32f10x.h"
#include "usart1.h"
#include "led.h"
#include "oled.h"
#include "hc05.h"
#include "usart3.h"
#include "string.h"
#define MAX6675_CS GPIO_Pin_4
#define MAX6675_CSL() GPIOA->BRR = MAX6675_CS;
#define MAX6675_CSH() GPIOA->BSRR = MAX6675_CS;
* 函数名:SPI1_Init
* 描述 MAX6675 接口初始化
* 输入 :无
* 输出 :无
* 返回 :无
void SPI_MAX6675_Init(void)
SPI_InitTypeDef SPI_InitStructure;
/* 使能 SPI1 时钟 */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_SPI1, ENABLE);
/* ---------通信I/O初始化----------------
* PA5-SPI1-SCK :MAX6675_SCK
* PA6-SPI1-MISO:MAX6675_SO
* PA7-SPI1-MOSI:MAX6675_SI
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用输出
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* ---------控制I/O初始化----------------*/
/* PA4-SPI1-NSS:MAX6675_CS */ // 片选
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; // 推免输出
GPIO_SetBits(GPIOA, GPIO_Pin_4); // 先把片选拉高,真正用的时候再拉低
/* SPI1 配置 */
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI1, &SPI_InitStructure);
/* 使能 SPI1 */
SPI_Cmd(SPI1, ENABLE);
unsigned char MAX6675_ReadByte(void)
/* Loop while DR register in not emplty */
while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_TXE) == RESET);
/* Send byte through the SPI1 peripheral */
SPI_I2S_SendData(SPI1, 0xff);
/* Wait to receive a byte */
while(SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET);
/* Return the byte read from the SPI bus */
return SPI_I2S_ReceiveData(SPI1);
void HC05_Role_Show(void)
if(HC05_Get_Role()==1)printf("ROLE:Master"); //主机
else printf("ROLE:Slave "); //从机
//显示ATK-HC05模块的连接状态
void HC05_Sta_Show(void)
if(HC05_LED)printf("STA:Connected "); //连接成功
else printf("STA:Disconnect"); //未连接
* 函数名:main
* 描述 :主函数
* 输入 :无
* 输出 :无
main (void)
unsigned int t,i;
unsigned char c;
unsigned char flag;
float temprature;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
/* 配置系统时钟为72M */
SystemInit();
LED_Init();
/* MAX6675 SPI 接口初始化 */
SPI_MAX6675_Init();
USART1_Config();
OLED_IIC_Init();
LED0=LED1=0 ;
//OLED_ShowNum(0,1,6666666,8,16);
OLED_P8x16Str(0,0,"temp:");
HC05_Init();
// while(HC05_Init()) //初始化ATK-HC05模块
//OLED_P8x16Str(2,2,"xxxx");
OLED_P8x16Str(3,3,"222");
HC05_Role_Show();
USART3_RX_STA=0;
MAX6675_CSL();
c = MAX6675_ReadByte();
i = c;
i = i<<8;
MAX6675_CSH();
i = i|((unsigned int)c); //i是读出来的原始数据
flag = i&0x04; //flag保存了热电偶的连接状态
t = i<<1;
t = t>>4;
temprature = t*0.25;
if(i!=0) //max6675有数据返回
if(flag==0) //热电偶已连接
printf("原始数据是:%04X, 当前温度是:%4.2f。\r\n",i,temprature);
OLED_ShowNum(17,1,temprature,4,16);
// if(temprature< 25) //温度小于25°加热,
// LED0=1;// 加热
// LED1=0; // 关闭风扇
// else if (temprature >30) //温度高于30都 散热
// LED1=1; //打开风扇
// LED0=0; //关闭加热
else //热电偶掉线
printf("未检测到热电偶,请检查。\r\n");
else //max6675没有数据返回
printf("max6675没有数据返回,请检查max6675连接。\r\n");
for(i=0;i<0x2fffff;i++); //max6675的转换时间是0.2秒左右,所以两次转换间隔不要太近
原理图:无
仿真:无
程序:
程序.7z
(182.89 KB, 下载次数: 47)
2023-8-11 14:26 上传
点击文件名下载附件
下载积分: 黑币 -5
