标题: STM32F407单片机的6路串口接收发送DMA源程序 [打印本页]
作者: LI-GONG-004    时间: 2023-8-25 13:16
STM32F407的6路串口接收发送DMA 例程
  1. /*
  2.         该工程为寄存器版本,不过在库函数中仍可添加使用
  3. */
  4. #include "sys.h"
  5. #include "delay.h"
  6. #include "usart.h"
  7. #include "dma.h"
  8. #include "malloc.h"
  9. u8 TestData[10] = {0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0A};
  10. int main(void)
  11. {
  12.         Stm32_Clock_Init(336,8,2,7);//设置时钟,168Mhz
  13.         delay_init(168);                        //延时初始化
  14.
  15.         Init_USART1(84,115200);                //初始化串口波特率为115200
  16.         Init_USART2(42,115200);
  17.         Init_USART3(42,115200);
  18.         Init_UART4(42,115200);
  19.         Init_UART5(42,115200);
  20.         Init_USART6(84,115200);
  21.         my_mem_init(SRAMIN);                //初始化内部内存池
  22.         my_mem_init(SRAMCCM);                //初始化内部CCM内存池
  23.
  24. //USART1发送 --- DMA2,数据流7,CH4---USART1_TXD 外设为串口1,存储器为USART1_TX_BUF,长度为:USART_LEN
  25.         MYDMA_Config(DMA2_Stream7,4,(u32)&USART1->DR,(u32)USART1_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  26. //USART1接收 --- DMA2,数据流5,CH4---USART1_RXD 外设为串口1,存储器为USART1_RX_BUF,长度为:USART_LEN
  27.         MYDMA_Config(DMA2_Stream5,4,(u32)&USART1->DR,(u32)USART1_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  28.         MYDMA_Enable(DMA2_Stream5,(u32)USART1_RX_BUF,USART_LEN);//开始一次DMA传输!
  29.
  30. //USART2发送 --- DMA1,数据流6,CH4---USART2_TXD 外设为串口2,存储器为USART2_TX_BUF,长度为:USART_LEN
  31.         MYDMA_Config(DMA1_Stream6,4,(u32)&USART2->DR,(u32)USART2_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  32. //USART2接收 --- DMA1,数据流5,CH4---USART2_RXD 外设为串口2,存储器为USART2_RX_BUF,长度为:USART_LEN
  33.         MYDMA_Config(DMA1_Stream5,4,(u32)&USART2->DR,(u32)USART2_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  34.         MYDMA_Enable(DMA1_Stream5,(u32)USART2_RX_BUF,USART_LEN);
  35. //USART3发送 --- DMA1,数据流3,CH4---USART3_TXD 外设为串口3,存储器为USART3_TX_BUF,长度为:USART_LEN
  36.         MYDMA_Config(DMA1_Stream3,4,(u32)&USART3->DR,(u32)USART3_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  37. //USART3接收 --- DMA1,数据流1,CH4---USART3_RXD 外设为串口3,存储器为USART3_RX_BUF,长度为:USART_LEN
  38.         MYDMA_Config(DMA1_Stream1,4,(u32)&USART3->DR,(u32)USART3_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  39.         MYDMA_Enable(DMA1_Stream1,(u32)USART3_RX_BUF,USART_LEN);
  40. //USART4发送 --- DMA1,数据流4,CH4---USART4_TXD 外设为串口4,存储器为USART4_TX_BUF,长度为:USART_LEN
  41.         MYDMA_Config(DMA1_Stream4,4,(u32)&UART4->DR,(u32)UART4_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  42. //USART4接收 --- DMA1,数据流2,CH4---USART4_RXD 外设为串口4,存储器为USART4_RX_BUF,长度为:USART_LEN
  43.         MYDMA_Config(DMA1_Stream2,4,(u32)&UART4->DR,(u32)UART4_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  44.         MYDMA_Enable(DMA1_Stream2,(u32)UART4_RX_BUF,USART_LEN);
  45.
  46. //USART5发送 --- DMA1,数据流7,CH4---UART5_TXD 外设为串口5,存储器为UART5_TX_BUF,长度为:USART_LEN
  47.         MYDMA_Config(DMA1_Stream7,4,(u32)&UART5->DR,(u32)UART5_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  48. //USART5接收 --- DMA1,数据流0,CH4---UART5_RXD 外设为串口5,存储器为UART5_RX_BUF,长度为:USART_LEN
  49.         MYDMA_Config(DMA1_Stream0,4,(u32)&UART5->DR,(u32)UART5_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  50.         MYDMA_Enable(DMA1_Stream0,(u32)UART5_RX_BUF,USART_LEN);
  51. //USART6发送 --- DMA2,数据流6,CH5---USART6_TXD 外设为串口6,存储器为USART6_TX_BUF,长度为:USART_LEN
  52.         MYDMA_Config(DMA2_Stream6,5,(u32)&USART6->DR,(u32)USART6_TX_BUF,USART_LEN,DMA_DIR_MemoryToPeripheral);
  53. //USART6接收 --- DMA2,数据流1,CH5---USART6_RXD 外设为串口6,存储器为USART6_RX_BUF,长度为:USART_LEN
  54.         MYDMA_Config(DMA2_Stream1,5,(u32)&USART6->DR,(u32)USART6_RX_BUF,USART_LEN,DMA_DIR_PeripheralToMemory);
  55.         MYDMA_Enable(DMA2_Stream1,(u32)USART6_RX_BUF,USART_LEN);
  56.
  57.         while(1)
  58.         {
  59. //                myDMAprintf(USART1,"usart = %d\tch = %f\r\n",1,1.567);
  60. //                myDMAprintf(USART2,"usart = %d\tch = %f\r\n",2,1.567);
  61.                 myDMAprintf(USART3,"usart = %d\tch = %f\r\n",3,1.567);
  62.                 myDMAprintf(USART3,"usart = %d\tch = %f\r\n",3,1.567);
  63. //                myDMAprintf(UART4,"usart = %d\tch = %f\r\n",4,1.567);
  64. //                myDMAprintf(UART5,"usart = %d\tch = %f\r\n",5,1.567);
  65.                 myDMAprintf(USART6,"usart = %d\tch = %f\r\n",6,1.567);
  66.                 myDMAprintf(USART6,"usart = %d\tch = %f\r\n",6,1.567);
  67.
  68. //                myDMAarray(USART1,(u32)TestData,10);
  69. //                myDMAarray(USART2,(u32)TestData,10);
  70. //                myDMAarray(USART3,(u32)TestData,10);
  71. //                myDMAarray(USART3,(u32)TestData,10);
  72. //                myDMAarray(UART4,(u32)TestData,10);
  73. //                myDMAarray(UART5,(u32)TestData,10);
  74. //                myDMAarray(USART6,(u32)TestData,10);
  75. //                myDMAarray(USART6,(u32)TestData,10);
  76.
  77.                 delay_ms(1000);
  78.         }
  79. }
原理图: 无
仿真: 无
代码: DMA发送&接收.7z (87.28 KB, 下载次数: 47)
作者: 大漠落日    时间: 2023-8-30 21:55
先下载,有空研究学习一下
