* Copyright (C) 2008 The Android Open Source Project | | |
| * Licensed under the Apache License, Version 2.0 (the "License"); | | * you may not use this file except in compliance with the License. |
| * You may obtain a copy of the License at | | |
| * Unless required by applicable law or agreed to in writing, software | | * distributed under the License is distributed on an "AS IS" BASIS, |
| * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. | | * See the License for the specific language governing permissions and |
| * limitations under the License. | | |
| | package com.example.android.apis.app; |
| | import com.example.android.apis.R; |
| | import android.app.Activity; |
| import android.content.Intent; | | import android.content.pm.PackageManager; |
| import android.content.pm.ResolveInfo; | | import android.os.Bundle; |
| import android.speech.RecognizerIntent; | | import android.view.View; |
| import android.view.View.OnClickListener; | | import android.widget.ArrayAdapter; |
| import android.widget.Button; | | import android.widget.ListView; |
| | import java.util.ArrayList;
| | | * Sample code that invokes the speech recognition intent API. |
| | | public class VoiceRecognition extends Activity implements OnClickListener { |
| | private static final int VOICE_RECOGNITION_REQUEST_CODE = 1234; |
| * Called with the activity is first created. | | |
| | | public void onCreate(Bundle savedInstanceState) { |
| super.onCreate(savedInstanceState); | |
| // Inflate our UI from its XML layout description. | | setContentView(R.layout.voice_recognition); |
| | // Get display items for later interaction |
| Button speakButton = (Button) findViewById(R.id.btn_speak); | |
| mList = (ListView) findViewById(R.id.list); | |
| // Check to see if a recognition activity is present | | PackageManager pm = getPackageManager(); |
| List activities = pm.queryIntentActivities( | | new Intent(RecognizerIntent.ACTION_RECOGNIZE_SPEECH), 0); |
| if (activities.size() != 0) { | | speakButton.setOnClickListener(this); |
| | | speakButton.setEnabled(false); |
| speakButton.setText("Recognizer not present"); | | |
| | | * Handle the click on the start recognition button. |
| | | public void onClick(View v) { |
| if (v.getId() == R.id.btn_speak) { | | startVoiceRecognitionActivity(); |
| * Fire an intent to start the speech recognition activity. | | |
| private void startVoiceRecognitionActivity() { | | Intent intent = new Intent(RecognizerIntent.ACTION_RECOGNIZE_SPEECH); |
| intent.putExtra(RecognizerIntent.EXTRA_LANGUAGE_MODEL, | | RecognizerIntent.LANGUAGE_MODEL_FREE_FORM); |
| intent.putExtra(RecognizerIntent.EXTRA_PROMPT, "Speech recognition demo"); | | startActivityForResult(intent, VOICE_RECOGNITION_REQUEST_CODE); |
| | | * Handle the results from the recognition activity. |
| protected void onActivityResult(int requestCode, int resultCode, Intent data) { | | if (requestCode == VOICE_RECOGNITION_REQUEST_CODE && resultCode == RESULT_OK) { |
| // Fill the list view with the strings the recognizer thought it could have heard |
| ArrayList matches = data.getStringArrayListExtra( |
| RecognizerIntent.EXTRA_RESULTS); | | mList.setAdapter(new ArrayAdapter(this, android.R.layout.simple_list_item_1, |
| | super.onActivityResult(requestCode, resultCode, data); |
