标题: 单片机实验PCF8591模数转换 [打印本页]
作者: 111ddd222    时间: 2023-12-28 17:11
#include <reg52.h>
#include "PCF8591.h"
bit flagls=1;
unsigned char T0RH=0;
unsigned char T0RL=0;
unsigned char channel=0;
unsigned char LedBuff[4]={0xff,0xff,0xff,0xff};
unsigned char code smgcode[]=
{0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
sbit LSA=P1^5;
sbit LSB=P1^6;
sbit LSC=P1^7;
sbit KEY0=P3^2;
void ConfigTimer0(unsigned int ms);
void ValueToBuff(unsigned char val);
void Delayms (unsigned int xms);
void main(void)
        unsigned char val;
        EA=1;
        EX0=1;
        IT0=1;
        ConfigTimer0(2);
                if(flagls)
                        flagls=0;
                        val=GetADCValue(channel);
                        ValueToBuff(val);
                        channel%=2;
        val=(val*250)/255;
        LedBuff[0]=smgcode[(val%10)];
        LedBuff[1]=smgcode[(val/10)%10];
        LedBuff[2]=smgcode[(val/100)];
        LedBuff[2]&=0x7f;
        unsigned long tmp;
        tmp=11059200/12;
        tmp=(tmp*ms)/1000;
        tmp=65536-tmp;
        tmp=tmp+18;
        T0RH=(unsigned char)(tmp>>8);
        T0RL=(unsigned char)tmp;
        TMOD&=0xf0;
        TMOD|=0x01;
        TH0=T0RH;
        TL0=T0RL;
        ET0=1;
        TR0=1;
void LedScan(void)
        static unsigned char i=0;
        P0=0xff;
        switch(i)
                case 0:
                LSA=1;
                LSB=0;
                LSC=0;
                i++;
                P0=LedBuff[0];
                Delayms(2);
                break;
                case 1:
                LSA=0;
                LSB=1;
                LSC=0;
                i++;
                P0=LedBuff[1];
                Delayms(2);
                break;
                case 2:
                LSA=1;
                LSB=1;
                LSC=0;
                i++;
                P0=LedBuff[2];
                Delayms(2);
                break;
                case 3:
                LSA=0;
                LSB=0;
                LSC=1;
                i=0;
                P0=LedBuff[3];
                Delayms(2);
                break;
                default:
                break;
void InterruptTimer0(void) interrupt 1
        static unsigned int tmrls=0;
        TH0=T0RH;
        TL0=T0RL;
        tmrls++;
        if(tmrls>=5)
                tmrls=0;
                flagls=1;
        LedScan();
void EXINT0(void) interrupt 0
        Delayms(2);
        channel=~channel;
        unsigned int i,j;
        for(i=xms;i>0;i--)
                for(j=106;j>0;j--);
