标题: stc8h8k64u内部12位ad加lcd1602做得电压表为啥运行不了? [打印本页]
作者: @GS    时间: 2024-3-5 13:07
#include <STC8h.H>
#include <stdio.h>
#include <intrins.h>
//        uint Get_ADC12bitResult(uchar channel);
//void iO();
sbit RS = P2^4;   //定义端口
sbit RW = P2^5;
sbit EN = P2^6;
#define RS_CLR RS=0
#define RS_SET RS=1
#define RW_CLR RW=0
#define RW_SET RW=1
#define EN_CLR EN=0
#define EN_SET EN=1
#define DataPort P0
void delay(unsigned int ms)        //@11.0592MHz
        unsigned char data i, j;
   while(ms--)
        i = 15;
        j = 90;
        do
                while (--j);
        } while (--i);
              判忙函数
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS_CLR;
RW_SET;
EN_CLR;
delay(1);
EN_SET;
         delay(1);
return (bit)(DataPort & 0x80);
              写入命令函数
void LCD_Write_Com(unsigned char com)
while(LCD_Check_Busy()); //忙则等待
RS_CLR;
RW_CLR;
EN_SET;
DataPort= com;
delay(1);
EN_CLR;
         delay(1);
              写入数据函数
void LCD_Write_Data(unsigned char Data)
RS_SET;
RW_CLR;
EN_SET;
DataPort= Data;
delay(1);
EN_CLR;
         delay(1);
                清屏函数
void LCD_Clear(void)
LCD_Write_Com(0x01);
delay(5);
              写入字符串函数
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         LCD_Write_Com(0x80 + x);     //表示第一行
        LCD_Write_Com(0xC0 + x);      //表示第二行
while ((*s)!='\0')
LCD_Write_Data( *s);
s ++;
              写入字符函数
void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 0)
LCD_Write_Data( Data);
              初始化函数
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*显示模式设置*/
   delay(5);
   delay(5);
   delay(5);
   LCD_Write_Com(0x08);    /*显示关闭*/
   LCD_Write_Com(0x01);    /*显示清屏*/
   LCD_Write_Com(0x06);    /*显示光标移动设置*/
   delay(5);
   LCD_Write_Com(0x0C);    /*显示开及光标设置*/
void adc_init() {
    ADCCFG =ADCCFG|0x20;  // 将P1.0设置为ADC功能
    ADC_RES = 0;
        ADC_RESL = 0;
    ADC_CONTR = 0x80;
unsigned int adc_read()
    ADC_CONTR |= 0x40;
                delay(3);
    while ((ADC_CONTR&0x20)==0);
    ADC_CONTR &= ~0x20;
    return (ADC_RES << 8) + ADC_RESL;
void main() {
    unsigned int voltage;
        unsigned char i;
    char str[16];
    LCD_Init();
    adc_init();
    while (1) {
        voltage = adc_read();
        sprintf(str, "Voltage: %.2fV", voltage * 5.0 / 4096);
        LCD_Write_Com(0x80);  // 设置光标位置为第一行第一列
        for ( i = 0; i < 16; i++) {
            LCD_Write_Data(str[i]);
        delay(1000);  // 延时1秒钟
有没有大佬回答!这个显示没有报错,但是运行不了,是哪个原因?
作者: cocolala    时间: 2024-3-5 14:06
    你好,你这里只给了程序,看不到原理图和硬件不好分析,下面从典型的几点给下参考:
    1、先分开测试,比如先点亮屏,屏需要硬件调节对比度的。不知道你的硬件,我把我手上有的艾克姆的STC8H8K64U的程序附件发上。
    2、如果屏可以显示(注意参考时把IO口都注意到,修改到),然后可以测下ADC,程序见附件。注意ADC选择的通道。例程用的P0.4口。
ADC.rar
42.32 KB, 下载次数: 11
LCD1602.rar
40.56 KB, 下载次数: 9
作者: aidianzi    时间: 2024-3-5 15:48
你说的运行不了是具体只什么,显示也显示不了还是能显示ADC转换不正常。程序中没有看到你初始化IO模式,STC8H的IO看看手册上面P3.0、P3.1是默认准双向,其余IO是默认高阻模式,初始化驱动LCD的GPIO模式为准双向或者推挽模式,不熟悉的情况下设置为准双向
作者: wulin    时间: 2024-3-5 16:40
给你一个STC8H测量电压,数码管显示并串口上传数据的示例,只要把对应端口和数码管改1602显示就行。
STC8H测量电源电压计算输入电压串口上传数据.rar (22.1 KB, 下载次数: 26)
作者: Hephaestus    时间: 2024-3-5 17:40
是没有显示还是显示的数值不对?
作者: @GS    时间: 2024-3-5 19:58
没有显示
作者: lingwise    时间: 2024-3-9 10:29
单片机的P0数据口得配置推挽输出,
如果是自己做的板子注意需要把显示屏的VL引脚接一个1K电阻到地,调高对比度
