标题: 停车场240329 [打印本页]
作者: crrr    时间: 2024-3-29 15:35
标题: 停车场240329
#include "oled.h"
#include <intrins.h>
//按钮
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
sbit k5=P1^4;
sbit k6=P1^5;
sbit speaker1=P1^7;
sbit speaker2=P2^0;
sbit speaker3=P2^1;
sbit speaker4=P2^2;
sbit beep=P3^7;
uchar sec=0;//定时
uchar sec2=0;
uchar mode=0;//模式
uchar flag=0;
uchar time_err=60,error=0;
uchar kahao=0;//号
uchar point=0;
uchar beep_time=0;
uchar nian=24,yue=4,ri=1,shi=12,fen=24,miao=00;
uchar flag1,flag2;
uchar danjia=10,dangqianchewei=0,shengyu=0,zongchewei=8,shijian,shijian2,jiage,jiage2;
uchar *p,*q;
//号显示
void ka_disp()
    if(kahao==1)//C1
                                OLED_ShowString(48,2,"C111");
    if(kahao==2)//C2
                                OLED_ShowString(48,2,"C222");
                OLED_Init();                        //初始化OLED
                OLED_Clear()          ;
    // 初始化12864
                OLED_ShowCHinese(0,0,0);//
                OLED_ShowCHinese(18,0,1);//
                OLED_ShowCHinese(36,0,2);//
                OLED_ShowCHinese(54,0,3);//
                OLED_ShowCHinese(72,0,4);//
                OLED_ShowCHinese(90,0,5);//
                OLED_ShowCHinese(108,0,6);//
                OLED_ShowCHinese(0,2,7);//zong
                OLED_ShowCHinese(18,2,8);//:
                OLED_ShowCHinese(0,4,9);//sheng
                OLED_ShowCHinese(18,4,8);//:
    //定时器初始化
    TMOD|=0X01;
    TH0=0X3C;
    TL0=0XB0;
    ET0=1;//打开定时器0中断允许
    EA=1;//打开总中断
    TR0=1;//打开定时器
    while (1)
        if(P1!=0xff)//蜂鸣器响
            beep_time=10;
        //错误检测
        if(time_err>0)
            if(!k4)
                time_err=60;
                mode=1;
                error=1;
                kahao=1;
            if(!k5)
                time_err=60;
                mode=1;
                error=1;
                kahao=2;
            if(!k6)
                time_err=60;
                mode=1;
                error=1;
                kahao=3;
                                if(shengyu<1)
                                         beep=0;
        //按键检测
        if((mode<20)&&(time_err==0))
            if(!k4)//1
                mode=2;
                kahao=1;
                while(!k4);
            if(!k5)//2
                mode=3;
                kahao=2;
                while(!k5);
            if(!k1)//设置
                mode=4;
                if(point<8)
                    point++;
                    point=0;
                    mode=0;
                while(!k1);
            if(mode==4)
                if(!k2)//加
                    switch(point)
                    case 1://年
        nian++;
                                if(nian>99){nian=0;}//年
                        break;
                    case 2://月
        yue++;
                                if(yue>12){yue=1;}//
                          break;
                    case 3://日
        ri++;
                                if(ri>31){ri=1;}//
                        break;
                    case 4://时
        shi++;
                                if(shi>23){shi=0;}//
                        break;
                    case 5://分
        fen++;
                                if(fen>59){fen=0;}//
                        break;
                    case 6://秒
        miao++;
                                if(miao>59){miao=0;}//
                        break;
                    case 7://单价
                        if(danjia<200)
                            danjia++;
                        break;
                    case 8://车位
                        if(zongchewei<10)
                            zongchewei++;
                    while(!k2);
if(!k3)//减
switch(point)
case 1://年
nian--;
if(nian>0){nian=99;}//
break;
case 2://月
yue--;
if(yue>0){yue=12;}//
break;
case 3://日
ri--;
if(ri>0){ri=31;}//
break;
case 4://时
shi--;
if(shi>0){shi=23;}//
break;
case 5://分
fen--;
if(fen>0){fen=59;}//
break;
case 6://秒
miao--;
if(miao>0){miao=59;}//
break;
case 7://单价
if(danjia>0)
danjia--;
break;
case 8://车位
if(zongchewei>0)
zongchewei--;
while(!k3);
//定时器中断
void Timer0() interrupt 1
    uchar i,j;
    uchar k,k1;
          uchar m,m1,m2,m3;
    if(beep_time>0)        //蜂鸣器控制
        beep_time--;
        beep=0;
        beep=1;
    if(time_err>0) //启动倒计时
        time_err--;
        if(error==1)
            mode=0;
            error=0;
        if(mode==20)
            mode=0;
                if(sec2++>19)//1s
                        sec2=0;
                        miao++;
                        if(miao>59)
                          miao=0;
                                fen++;
                                if(fen>60)
                                  fen=0;
                                        shi++;
                                        if(shi>23)
                                          shi=0;
                                                ri++;
                                                if(ri>30)
                                                        ri=1;
                                                  yue++;
                                                        if(yue>12)
                                                           yue=1;
        nian++;
        if(nian>99)
        nian=0;
                if(sec<10)//0.5s
                sec++;flag1++;
        sec=0;
        flag=!flag;
        //初始界面
        if(mode==0)
                                        if(flag1>50)
                                                flag1=0;
                                          OLED_Clear();
                                                speaker1=1;
                                                speaker2=1;
                                                speaker3=1;
                                                speaker4=1;
                                                OLED_ShowNum(42,2,zongchewei,3,16);
            shengyu=zongchewei-dangqianchewei;
OLED_ShowNum(42,4,shengyu,3,16);
//            //------------------------------时间
OLED_ShowNum(0,6,20,2,16);
OLED_ShowNum(16,6,nian,2,16);
OLED_ShowString(32,6,"-");
if(yue<10)
{OLED_ShowNum(40,6,0,1,16);
OLED_ShowNum(48,6,yue%10,1,16);
else{OLED_ShowNum(40,6,yue,2,16);                                                        }
OLED_ShowString(56,6,"-");
if(ri<10){OLED_ShowNum(64,6,0,1,16);
OLED_ShowNum(72,6,ri%10,1,16);        }
else{                                                        OLED_ShowNum(64,6,ri,2,16);        }
if(shi<10)
{                                                  OLED_ShowNum(88,6,0,1,16);
OLED_ShowNum(96,6,shi%10,1,16);        }
else                                                {                                                        OLED_ShowNum(88,6,shi,2,16);        }
OLED_ShowString(104,6,":");
if(fen<10)
{                                                  OLED_ShowNum(108,6,0,1,16);
OLED_ShowNum(116,6,shi%10,1,16);        }
else                                                {                                                OLED_ShowNum(108,6,fen,2,16);                                                        }        }
        //错误界面
        if(mode==1)
            OLED_Clear();               // 清屏
                                                OLED_ShowCHinese(0,2,10);//
                                                OLED_ShowCHinese(16,2,11);//
            OLED_ShowString(32,2,":");
            ka_disp();//显示号
//请重刷!
OLED_ShowCHinese(0,4,12);//
OLED_ShowCHinese(18,4,13);//
OLED_ShowCHinese(36,4,14);//
OLED_ShowString(54,4,"!");
if((mode>1)&&(mode<4))
OLED_Clear();               // 清屏
OLED_ShowCHinese(18,2,11);//
OLED_ShowString(36,2,":");
ka_disp();//显示号
//1记录、结算
if(mode==2)
//判断进出
if(k>0)//结算
k=0;
speaker1=1;
speaker2=1;
speaker3=1;
speaker4=0;
dangqianchewei=dangqianchewei-1;
i=shi;
j=fen;
m1=shi*60+j;
shijian=m1-m;
OLED_ShowCHinese(0,4,15);//计时
OLED_ShowCHinese(16,4,16);//
OLED_ShowString(36,4,":");
OLED_ShowNum(48,4,shijian%1000/100,1,16);
OLED_ShowNum(56,4,shijian%100/10,1,16);
OLED_ShowNum(64,4,shijian%10,1,16);
OLED_ShowCHinese(72,4,30);    //分
OLED_ShowCHinese(0,6,31);    //共计
OLED_ShowString(36,6,":");
jiage=shijian*danjia;//价格
OLED_ShowNum(48,6,jiage%1000/100,1,16);
OLED_ShowNum(56,6,jiage%100/10,1,16);
OLED_ShowString(64,6,".");
OLED_ShowNum(72,6,jiage%10,1,16);
OLED_ShowCHinese(88,6,29);//元
else//记录
k=1;        speaker1=0;        speaker2=1;        speaker3=1;        speaker4=1;
dangqianchewei=dangqianchewei+1;
i=shi;
j=fen;
m=shi*60+j;
OLED_ShowCHinese(0,4,25);//单价
OLED_ShowCHinese(16,4,26);
OLED_ShowString(32,4,":");
OLED_ShowNum(40,4,danjia%100/10,2,16);
OLED_ShowString(56,4,".");
OLED_ShowNum(64,4,danjia%10,1,16);
OLED_ShowCHinese(80,4,29);//元
OLED_ShowString(96,4,"/min");                        //请停车!
OLED_ShowCHinese(8,6,12);
OLED_ShowCHinese(24,6,0);
OLED_ShowCHinese(43,6,1);           }
            time_err=100;
            mode=20;
//2记录、结算
if(mode==3)
{        //判断进出
if(k1>0)//结算
{        k1=0;
speaker1=1;
speaker2=1;
speaker3=1;
speaker4=0;
i=shi;
j=fen;
m2=i*60+j;
shijian2=m2-m3;
OLED_ShowNum(48,4,shijian2%1000/100,1,16);
OLED_ShowNum(56,4,shijian2%100/10,1,16);
OLED_ShowNum(64,4,shijian2%10,1,16);
jiage2=shijian2*danjia;//价格
OLED_ShowNum(48,6,jiage2%1000/100,1,16);
OLED_ShowNum(56,6,jiage2%100/10,1,16);
OLED_ShowNum(72,6,jiage2%10,1,16);
else//记录
         k1=1;
                speaker1=1;
                speaker2=0;
                speaker3=1;
                speaker4=1;
                i=shi;
                j=fen;
                m3=i*60+j;
                //请停车!
                k=j*256+i-1;
            time_err=100;
            mode=20;
        //==============================================设置
        if(mode==4)
            if(point<7)
                OLED_ShowCHinese(0,2,17);//日期
                OLED_ShowCHinese(16,2,18);//
                OLED_ShowCHinese(0,4,19);//时间
                OLED_ShowCHinese(16,4,20);//
                OLED_ShowString(40,2,":");
                OLED_ShowString(40,4,":");
                OLED_ShowString(64,2,"-");
                OLED_ShowString(64,4,":");
                OLED_ShowString(88,2,"-");
                OLED_ShowString(88,4,":");
                OLED_ShowCHinese(18,0,21);//设置参数
                OLED_ShowCHinese(36,0,22);
                OLED_ShowCHinese(54,0,23);
                OLED_ShowCHinese(72,0,24);
                OLED_ShowCHinese(0,2,25);//单价
                OLED_ShowCHinese(18,2,26);
                OLED_ShowCHinese(0,4,1);//车位
                OLED_ShowCHinese(18,4,27);
                OLED_ShowCHinese(80,2,29);//元
                OLED_ShowString(96,2,"/min");
                OLED_ShowCHinese(80,4,27);//位
if(point<7)
                if(point==1)//年
                                if(flag)
                                                OLED_ShowNum(48,2,nian,2,16);
                                                OLED_ShowString(48,2,"__");
if(point==2)//月
                if(flag)
                                OLED_ShowNum(72,2,yue,2,16);
                                OLED_ShowString(72,2,"__");
if(point==3)//日
                if(flag)
                                OLED_ShowNum(96,2,ri,2,16);
                                OLED_ShowString(96,2,"__");
if(point==4)//时
                if(flag)
                                OLED_ShowNum(48,4,shi,2,16);
                                OLED_ShowString(48,4,"__");
if(point==5)//分
                if(flag)
                                OLED_ShowNum(72,4,fen,2,16);
                                OLED_ShowString(72,4,"__");
if(point==6)//秒
        if(flag)
                        OLED_ShowNum(96,4,miao,2,16);
                        OLED_ShowString(96,4,"__");
if(point==7)//单价
        if(flag)
                        OLED_ShowNum(48,2,danjia/100,1,16);
                        OLED_ShowNum(56,2,danjia%100/10,1,16);
                        OLED_ShowString(64,2,".");
                        OLED_ShowNum(72,2,danjia%10,1,16);
                        OLED_ShowString(72,2,"_");
if(point==8)//车位
                if(flag)
                                OLED_ShowNum(48,4,zongchewei%1000/100,1,16);
                                OLED_ShowNum(56,4,zongchewei%100/10,1,16);
                                OLED_ShowNum(64,4,zongchewei%10,1,16);
                                OLED_ShowString(48,4,"___");
        k=j*256+i;
                        if(flag1>10)
                                flag1=0;
                                OLED_Clear();
    TH0=0X3C; //重装定时器
    TL0=0XB0;
