[萌新]STM32F103C8T6+OLED显示屏驱动
ganxy
2024-4-7 22:40
前言
在学习stm32中....
发现此站一篇文章 下载文件需要黑币 所以把做过像样的程序发上来 希望能帮到有需要的人
硬件连接
GND -- GND
VCC -- 3.3v
SCL -- B8
SDA -- B9
驱动代码
OLED.h头文件
#ifndef __OLED_H
#define __OLED_H
void OLED_Init(void);
void OLED_Clear(void);
void OLED_ShowChar(uint8_t Line, uint8_t Column, char Char);
void OLED_ShowString(uint8_t Line, uint8_t Column, char *String);
void OLED_ShowNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
void OLED_ShowSignedNum(uint8_t Line, uint8_t Column, int32_t Number, uint8_t Length);
void OLED_ShowHexNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
void OLED_ShowBinNum(uint8_t Line, uint8_t Column, uint32_t Number, uint8_t Length);
#endif
OLED.c
#include "stm32f10x.h"
#include "OLED_Font.h"
/*引脚配置*/
#define OLED_W_SCL(x) GPIO_WriteBit(GPIOB, GPIO_Pin_8, (BitAction)(x))
#define OLED_W_SDA(x) GPIO_WriteBit(GPIOB, GPIO_Pin_9, (BitAction)(x))
/*引脚初始化*/
void OLED_I2C_Init(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
OLED_W_SCL(1);
OLED_W_SDA(1);
* @brief I2C开始
* @param 无
* @retval 无
void OLED_I2C_Start(void)
OLED_W_SDA(1);
OLED_W_SCL(1);
OLED_W_SDA(0);
OLED_W_SCL(0);
* @brief I2C停止
* @param 无
* @retval 无
void OLED_I2C_Stop(void)
OLED_W_SDA(0);
OLED_W_SCL(1);
OLED_W_SDA(1);
* @brief I2C发送一个字节
* @param Byte 要发送的一个字节
* @retval 无
void OLED_I2C_SendByte(uint8_t Byte)
uint8_t i;
for (i = 0; i < 8; i++)
OLED_W_SDA(Byte & (0x80 >> i));
OLED_W_SCL(1);
OLED_W_SCL(0);
OLED_W_SCL(1); //额外的一个时钟,不处理应答信号
OLED_W_SCL(0);
* @brief OLED写命令
* @param Command 要写入的命令
* @retval 无
void OLED_WriteCommand(uint8_t Command)
OLED_I2C_Start();
OLED_I2C_SendByte(0x78); //从机地址
OLED_I2C_SendByte(0x00); //写命令
OLED_I2C_SendByte(Command);
OLED_I2C_Stop();
* @brief OLED写数据
* @param Data 要写入的数据
* @retval 无
void OLED_WriteData(uint8_t Data)
OLED_I2C_Start();
OLED_I2C_SendByte(0x40); //写数据
OLED_I2C_SendByte(Data);
OLED_I2C_Stop();
* @brief OLED设置光标位置
* @param Y 以左上角为原点,向下方向的坐标,范围:0~7
* @param X 以左上角为原点,向右方向的坐标,范围:0~127
* @retval 无
void OLED_SetCursor(uint8_t Y, uint8_t X)
OLED_WriteCommand(0xB0 | Y); //设置Y位置
OLED_WriteCommand(0x10 | ((X & 0xF0) >> 4)); //设置X位置高4位
OLED_WriteCommand(0x00 | (X & 0x0F)); //设置X位置低4位
* @brief OLED清屏
* @param 无
* @retval 无
uint8_t i, j;
for (j = 0; j < 8; j++)
OLED_SetCursor(j, 0);
for(i = 0; i < 128; i++)
OLED_WriteData(0x00);
* @brief OLED显示一个字符
* @param Line 行位置,范围:1~4
* @param Column 列位置,范围:1~16
* @param Char 要显示的一个字符,范围:ASCII可见字符
* @retval 无
uint8_t i;
OLED_SetCursor((Line - 1) * 2, (Column - 1) * 8); //设置光标位置在上半部分
OLED_WriteData(OLED_F8x16[Char - ' '][i]); //显示上半部分内容
OLED_SetCursor((Line - 1) * 2 + 1, (Column - 1) * 8); //设置光标位置在下半部分
OLED_WriteData(OLED_F8x16[Char - ' '][i + 8]); //显示下半部分内容
* @brief OLED显示字符串
* @param Line 起始行位置,范围:1~4
* @param Column 起始列位置,范围:1~16
* @param String 要显示的字符串,范围:ASCII可见字符
* @retval 无
uint8_t i;
for (i = 0; String[i] != '\0'; i++)
OLED_ShowChar(Line, Column + i, String[i]);
* @brief OLED次方函数
* @retval 返回值等于X的Y次方
uint32_t OLED_Pow(uint32_t X, uint32_t Y)
uint32_t Result = 1;
while (Y--)
Result *= X;
return Result;
* @brief OLED显示数字(十进制,正数)
* @param Number 要显示的数字,范围:0~4294967295
* @param Length 要显示数字的长度,范围:1~10
* @retval 无
uint8_t i;
for (i = 0; i < Length; i++)
OLED_ShowChar(Line, Column + i, Number / OLED_Pow(10, Length - i - 1) % 10 + '0');
* @brief OLED显示数字(十进制,带符号数)
* @param Number 要显示的数字,范围:-2147483648~2147483647
* @retval 无
uint8_t i;
uint32_t Number1;
if (Number >= 0)
OLED_ShowChar(Line, Column, '+');
Number1 = Number;
OLED_ShowChar(Line, Column, '-');
Number1 = -Number;
OLED_ShowChar(Line, Column + i + 1, Number1 / OLED_Pow(10, Length - i - 1) % 10 + '0');
* @brief OLED显示数字(十六进制,正数)
* @param Number 要显示的数字,范围:0~0xFFFFFFFF
* @param Length 要显示数字的长度,范围:1~8
* @retval 无
uint8_t i, SingleNumber;
SingleNumber = Number / OLED_Pow(16, Length - i - 1) % 16;
if (SingleNumber < 10)
OLED_ShowChar(Line, Column + i, SingleNumber + '0');
OLED_ShowChar(Line, Column + i, SingleNumber - 10 + 'A');
* @brief OLED显示数字(二进制,正数)
* @param Number 要显示的数字,范围:0~1111 1111 1111 1111
* @param Length 要显示数字的长度,范围:1~16
* @retval 无
uint8_t i;
OLED_ShowChar(Line, Column + i, Number / OLED_Pow(2, Length - i - 1) % 2 + '0');
* @brief OLED初始化
* @param 无
* @retval 无
uint32_t i, j;
for (i = 0; i < 1000; i++) //上电延时
for (j = 0; j < 1000; j++);
OLED_I2C_Init(); //端口初始化
OLED_WriteCommand(0xAE); //关闭显示
OLED_WriteCommand(0xD5); //设置显示时钟分频比/振荡器频率
OLED_WriteCommand(0x80);
OLED_WriteCommand(0xA8); //设置多路复用率
OLED_WriteCommand(0x3F);
OLED_WriteCommand(0xD3); //设置显示偏移
OLED_WriteCommand(0x00);
OLED_WriteCommand(0x40); //设置显示开始行
OLED_WriteCommand(0xA1); //设置左右方向,0xA1正常 0xA0左右反置
OLED_WriteCommand(0xC8); //设置上下方向,0xC8正常 0xC0上下反置
OLED_WriteCommand(0xDA); //设置COM引脚硬件配置
OLED_WriteCommand(0x12);
OLED_WriteCommand(0x81); //设置对比度控制
OLED_WriteCommand(0xCF);
OLED_WriteCommand(0xD9); //设置预充电周期
OLED_WriteCommand(0xF1);
OLED_WriteCommand(0xDB); //设置VCOMH取消选择级别
OLED_WriteCommand(0x30);
OLED_WriteCommand(0xA4); //设置整个显示打开/关闭
OLED_WriteCommand(0xA6); //设置正常/倒转显示
OLED_WriteCommand(0x8D); //设置充电泵
OLED_WriteCommand(0x14);
OLED_WriteCommand(0xAF); //开启显示
OLED_Clear(); //OLED清屏
主函数main.c
#include "OLED.h"
#include "max30102.h"
// 延时函数
void delay_ms(uint32_t ms) {
uint32_t i;
for (i = 0; i < ms * 1000; i++) {
__NOP();
// LED 绿灯
void LED_Init() {
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
GPIO_InitTypeDef GPIO_InitStruct;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_13;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOC, &GPIO_InitStruct);
void countTime() {
// 倒计时逻辑
for (int i = 0; i <= 10; i++) {
OLED_ShowNum(4, 7, i, 2); // 更新倒计时显示
OLED_ShowString(4, 9, "s");
delay_ms(7000);
//if(i == 0) {
// i = 60;
// 倒计时结束,显示结束信息
OLED_Clear();
//OLED_ShowString(2, 1, "Time's up!");
OLED_ShowString(1, 2, "Case: Max30102");
OLED_ShowString(2, 4, "2024-04-07");
OLED_ShowString(3, 1, "HR:");
OLED_ShowString(4, 1, "SpO2:");
// OLED屏显示内容
void showOLED() {
OLED_Init();
OLED_ShowString(3, 1, "Put your finger");
if(MAX30102_INIT_FAILED) {
countTime();
} else {
OLED_ShowString(4, 4, "No finger");
int main(void) {
//LED_Init();
showOLED();
(403.61 KB, 下载次数: 14)
下载附件
效果
2024-4-7 22:38 上传
红花无常
2024-4-8 11:52
这个不是江科大例程吗
穹逾
2024-4-29 11:29
这好像是江科大的例程吧?如果楼主可以改成Hal库的版本就好了
JDWED
2024-5-27 16:12
能解释一下第一个吗 刚学有点看不懂
arima
2024-7-27 12:28
谢谢分享!有可直接调用的汉字库吗?
