STC8G1K08单片机片内EEPROM读写数组问题请教
bd5fna
2024-5-11 21:00
各位大佬帮忙看看,下面的单片机代码读写操作数组,读出来的数据是4个0xff.
#include "STC8.h"
#include "intrins.h"
#include "stdio.h"
/************* 本程序功能说明 **************
对STC内部自带的EEPROM(FLASH)进行读写测试。
对FLASH做扇区擦除、写入、读出的操作。
通过串口打印读取EEPROM结果。
注意:下载时,下载界面"硬件选项"中设置用户EEPROM大小,
并确保擦除、写入、读出的地址在EEPROM设置的大小范围之内。
下载时, 选择时钟 11.0592MHz (用户可自行修改频率)。
#define MAIN_Fosc 11059200L //定义主时钟参数
#define BAUD 115200
#define TM (65536 -(MAIN_Fosc/BAUD/4))
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
/*sfr TH2 = 0xD6;
sfr TL2 = 0xD7;
sfr AUXR = 0x8E;
sfr P_SW2 = 0xBA;
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xc9;
sfr P5M0 = 0xca;
sfr IAP_DATA = 0xC2;
sfr IAP_ADDRH = 0xC3;
sfr IAP_ADDRL = 0xC4;
sfr IAP_CMD = 0xC5;
sfr IAP_TRIG = 0xC6;
sfr IAP_CONTR = 0xC7;
sfr IAP_TPS = 0xF5;*/
void PrintfInit(void)
SCON = (SCON & 0x3f) | 0x40;
AUXR |= 0x40; //定时器时钟1T模式
AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
TL1 = TM;
TH1 = TM>>8;
TR1 = 1; //定时器1开始计时
// SCON = (SCON & 0x3f) | 0x40;
// T2L = TM;
// T2H = TM>>8;
// AUXR |= 0x15; //串口1选择定时器2为波特率发生器
void UartPutc(unsigned char dat)
SBUF = dat;
while(TI == 0);
TI = 0;
char putchar(char c)
UartPutc(c);
return c;
void IapIdle()
IAP_CONTR = 0; //关闭IAP功能
IAP_CMD = 0; //清除命令寄存器
IAP_TRIG = 0; //清除触发寄存器
IAP_ADDRH = 0x80; //将地址设置到非IAP区域
IAP_ADDRL = 0;
unsigned char IapRead(int addr)
char dat;
IAP_CONTR = 0x80; //使能IAP
IAP_CMD = 1; //设置IAP读命令
IAP_ADDRL = addr; //设置IAP低地址
IAP_ADDRH = addr >> 8; //设置IAP高地址
IAP_TRIG = 0x5a; //写触发命令(0x5a)
IAP_TRIG = 0xa5; //写触发命令(0xa5)
_nop_();
dat = IAP_DATA; //读IAP数据
IapIdle(); //关闭IAP功能
return dat;
void IapProgram(int addr, unsigned char dat)
IAP_CMD = 2; //设置IAP写命令
IAP_DATA = dat; //写IAP数据
_nop_();
void IapErase(int addr)
IAP_CMD = 3; //设置IAP擦除命令
_nop_(); //
unsigned char i;
unsigned char a[4]={1,2,3,4};
P0M1 = 0; P0M0 = 0; //设置为准双向口
P1M1 = 0; P1M0 = 0; //设置为准双向口
P2M1 = 0; P2M0 = 0; //设置为准双向口
P3M1 = 0; P3M0 = 0; //设置为准双向口
P4M1 = 0; P4M0 = 0; //设置为准双向口
P5M1 = 0; P5M0 = 0; //设置为准双向口
IAP_TPS = 11; //设置EEPROM操作等待参数(11.0592MHz),初始化设置一次即可
PrintfInit();
printf("Read1="); //读取EEPROM原先的内容
for(i=0;i<4;i++)
a[i] = IapRead(0x0000);
printf("0x%02bx ",a[i]);
//if(a[i] == 0xff) a[i] = i; //如果内容为空,则写入初始化数据
//else a[i]++; //如果内容非空,在原先基础上加1
printf("\r\n");
IapErase(0x0000);
printf("Read2="); //擦除、重写后,读取EEPROM现在的内容
for(i=0;i<4;i++)
IapProgram(0x0000+i,a[i]);
printf("\r\n");
while (1);
bd5fna
2024-5-12 20:38
已搞定:
for(i=0;i<4;i++)
a[4] = IapRead(0x0000+i);
printf("0x%02bx ",a[4]);
//if(a
== 0xff) a[ i] = i; //如果内容为空,则写入初始化数据
//else a[ i]++; //如果内容非空,在原先基础上加1
printf("\r\n");
IapErase(0x0000);
for(i=0;i<4;i++)
IapProgram(0x0000+i,a[ i]);
printf("\r\n");
