CC2530基础实验
sereina
2024-6-1 17:00
CC2530基础实验
#include <iocc2530.h>
#define LED1 P0_1
#define LED2 P0_0
#define LED3 P2_0
#define KEY1 P0_7
#define KEY2 P0_6
void LEDINIT()
P0SEL &=~0X03;
P0DIR |=0X03;
P2SEL&=~0x01;
P2DIR |=0X01;
LED1 = 1;
LED2=1;
LED3=1;
void KEYINIT()
P0SEL&=~0X80;
P0DIR&=~0X80;
P0INP&=~0X80;
void CLK32M()
CLKCONCMD&=~0x40;
while(CLKCONCMD&0x40);
CLKCONCMD&=~0x07;
void delay(uint x)
uint i,j;
for(i=0;i<x;i++)
for(j=0;j<288;j++);
uchar i=0;
uchar keyscan1()
if(KEY1==0)
delay(10);
if(KEY1==0)
while(KEY1==0);
i++;
i=i;
if(i>2)
i=i%3;
return i;
uchar j=0;
uchar keyscan2()
if(KEY2==0)
delay(10);
if(KEY2==0)
while(KEY2==0);
j++;
j=j;
if(j>1)
j=j%2;
return j;
LEDINIT();
KEYINIT();
CLK32M();
switch(keyscan1())
case 0:LED1=0;LED2=1;LED3=1;break;
case 1:LED1=1;LED2=0;LED3=1;break;
case 2:LED1=1;LED2=1;LED3=0;break;
if(keyscan2()==1)
LED1=LED2=LED3=1;
delay(500);
delay(500);
delay(500);
delay(500);
if(keyscan2()==1)
LED1=LED2=LED3=0;
delay(500);
LED1=LED2=LED3=1;
