单片机第一个点灯程序
zyscxr
2024-9-22 17:48
单片机第一个点灯程序
#include "reg51.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/* define constants */
#define FOSC 11059200L
#define T1MS (65536-FOSC/12/1000) //1ms timer calculation method in 12T mode
/* define SFR */
sbit TEST_LED = P1^0; //work LED, flash once per second
/* define variables */
WORD count; //1000 times counter
/* Timer0 interrupt routine */
void tm0_isr() interrupt 1
TL0 = T1MS; //reload timer0 low byte
TH0 = T1MS >> 8; //reload timer0 high byte
if (count-- == 0) //1ms * 1000 -> 1s
count = 1000; //reset counter
TEST_LED = ! TEST_LED; //work LED flash
/* main program */
TMOD = 0x01; //set timer0 as mode1 (16-bit)
TL0 = T1MS; //initial timer0 low byte
TH0 = T1MS >> 8; //initial timer0 high byte
TR0 = 1; //timer0 start running
ET0 = 1; //enable timer0 interrupt
EA = 1; //open global interrupt switch
count = 0; //initial counter
while (1); //loop
