51单片机定时器不进中断
qsj00000
2024-9-29 20:30
51单片机定时器不进中断
void Time_Init(unsigned char register_Position,unsigned char register_Mode,unsigned char use_Mode,
unsigned char THx,unsigned char TLx,
unsigned char interrupt_Enable,unsigned char interrupt_Grade)
TMOD=0x00;
TCON=0x00;
if(register_Position==1) //Time1
if(register_Mode==0){TMOD = TMOD||0x00;}
else if(register_Mode==1){TMOD = TMOD||0x04;}
if(use_Mode==0){TMOD = TMOD||0x00;TH0=THx;TL0=TLx;}
else if(use_Mode==1){TMOD = TMOD||0x01;TH0=THx;TL0=TLx;}
else if(use_Mode==2){TMOD = TMOD||0x02;TH0=THx;TL0=TLx;}
else if(use_Mode==3){TMOD = TMOD||0x03;TH0=THx;TL0=TLx;}
if(interrupt_Enable==0){ET1==0;}
else if(interrupt_Enable==1){ET1==1;}
TR1=1;
else if(register_Position==0) //Time0
else if(register_Mode==1){TMOD = TMOD||0x40;}
if(use_Mode==0){TMOD = TMOD||0x00;0x01;TH1=THx;TL1=TLx;}
else if(use_Mode==1){TMOD = TMOD||0x01;TH1=THx;TL1=TLx;}
else if(use_Mode==2){TMOD = TMOD||0x02;TH1=THx;TL1=TLx;}
else if(use_Mode==3){TMOD = TMOD||0x03;TH1=THx;TL1=TLx;}
if(interrupt_Enable==0){ET0==0;}
else if(interrupt_Enable==1){ET0==1;}
TR0=1;
TMOD=0x00;
EA=1;
外部中断0:中断号为0;
定时器0:中断号为1;
外部中断1:中断号为2;
定时器1:中断号为3;
void Timex_Suspend() interrupt 3
Time_Init(0,0,1,(65535-1000)/256,(65535-1000)%256,1,0);
//此函数结果TMOD=00000001 TCON=00110000
P2=TMOD;
P1=TCON;
void Timex_Suspend() interrupt 1
P0=~P0;
P3=0x00;
TH0=(65535-1000)/256;
TL0=(65535-1000)%256;
wpppmlah
2024-9-30 10:48
请问你是怎么判断没有进入 中断的?
飞云居士
2024-9-30 12:48
Timex_Suspend() interrupt 3 函数的中断号应该是interrupt 3,而不是interrupt 1。
在Time_Init函数中,TMOD = TMOD||0x00;0x01; 这一行代码是错误的,应该是 TMOD = TMOD | 0x01;。
代码中没有定义ET1和ET0,它们应该是ET1 = 1;和ET0 = 1;。
Timex_Suspend函数的中断号应该与声明的中断号一致,即interrupt 3用于定时器1,interrupt 1用于定时器0。
lkc8210
2024-10-4 09:50
(60.73 KB, 下载次数: 2)
下载附件
2024-10-4 09:50 上传
