MA600角度传感器STM32驱动程序
HLzhou
2024-10-23 15:42
MA600角度传感器STM32驱动程序
/* SPI1 init function */
void MX_SPI1_Init(void)
/* USER CODE BEGIN SPI1_Init 0 */
/* USER CODE END SPI1_Init 0 */
LL_SPI_InitTypeDef SPI_InitStruct = {0};
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
/* Peripheral clock enable */
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SPI1);
LL_AHB2_GRP1_EnableClock(LL_AHB2_GRP1_PERIPH_GPIOA);
/**SPI1 GPIO Configuration
PA5 ------> SPI1_SCK
PA6 ------> SPI1_MISO
PA7 ------> SPI1_MOSI
GPIO_InitStruct.Pin = LL_GPIO_PIN_5;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
GPIO_InitStruct.Alternate = LL_GPIO_AF_5;
LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
GPIO_InitStruct.Pin = LL_GPIO_PIN_6;
GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
// /* SPI1 interrupt Init */
// NVIC_SetPriority(SPI1_IRQn, NVIC_EncodePriority(NVIC_GetPriorityGrouping(),1, 1));
// NVIC_EnableIRQ(SPI1_IRQn);
/* USER CODE BEGIN SPI1_Init 1 */
/* USER CODE END SPI1_Init 1 */
SPI_InitStruct.TransferDirection = LL_SPI_FULL_DUPLEX;
SPI_InitStruct.Mode = LL_SPI_MODE_MASTER;
SPI_InitStruct.DataWidth = LL_SPI_DATAWIDTH_16BIT;
SPI_InitStruct.ClockPolarity = LL_SPI_POLARITY_LOW;
SPI_InitStruct.ClockPhase = LL_SPI_PHASE_1EDGE;
SPI_InitStruct.NSS = LL_SPI_NSS_SOFT;
SPI_InitStruct.BaudRate = LL_SPI_BAUDRATEPRESCALER_DIV16;
SPI_InitStruct.BitOrder = LL_SPI_MSB_FIRST;
SPI_InitStruct.CRCCalculation = LL_SPI_CRCCALCULATION_DISABLE;
SPI_InitStruct.CRCPoly = 7;
LL_SPI_Init(SPI1, &SPI_InitStruct);
LL_SPI_SetStandard(SPI1, LL_SPI_PROTOCOL_MOTOROLA);
LL_SPI_DisableNSSPulseMgt(SPI1);
/* USER CODE BEGIN SPI1_Init 2 */
/* USER CODE END SPI1_Init 2 */
uint16_t MA600GQ_Read_Register(uint8_t Address)
uint16_t Register_Value;
uint16_t txData = 0xd200 + Address; // 0xd2 + 8-bit Reg. Address
uint16_t timeOut = 200;
MA600GQ_CS_Enable();
while(!LL_SPI_IsActiveFlag_TXE(SPI1)) // 检查SPI发送缓存取是否为空
if(timeOut-- == 0)
return 0; // 在超时时直接返回,避免继续执行后续代码
LL_SPI_TransmitData16(SPI1, txData);
timeOut = 2000;
while(LL_SPI_IsActiveFlag_BSY(SPI1)) // 检查SPI发送缓存取是否为空
if(timeOut-- == 0)
timeOut = 2000;
while(!LL_SPI_IsActiveFlag_RXNE(SPI1)) // 检查SPI发送缓存取是否为空
if(timeOut-- == 0)
LL_SPI_ReceiveData16(SPI1);
MA600GQ_CS_Disable();
delay_us(1);
txData = 0x0000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
Register_Value = LL_SPI_ReceiveData16(SPI1);
return Register_Value; // 获取16位的角度数据
uint16_t MA600GQ_Write_Register(uint8_t Address,uint8_t Data)
uint16_t txData = 0xEA54; // 0xea54
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
txData = (((uint16_t)Address)<<8) + Data;
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
txData = 0x0000;
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
Register_Value = LL_SPI_ReceiveData16(SPI1)&0x00FF;
int16_t MA600GQ_Read_Speed(void)
uint16_t txData = 0x0000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
MA600GQ_angle_Value = LL_SPI_ReceiveData16(SPI1);
MA600GQ_angle_Value *= POLE_PAIR_NUM;
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
MA600GQ_speed_Value = LL_SPI_ReceiveData16(SPI1);
// return speed_Value ; // 获取16位的角度数据
uint16_t MA600GQ_GetRawData(void)
uint16_t timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
timeOut = 2000;
if(timeOut-- == 0)
MA600GQ.pdf
2024-10-23 15:39 上传
点击文件名下载附件
下载积分: 黑币 -5
1.49 MB, 下载次数: 0, 下载积分: 黑币 -5
