用C语言编写的10个通用RGB灯效算法
zenghl
2025-2-16 10:51
用C语言编写的10个通用RGB灯效算法
以下是用C语言编写的10个通用RGB灯效算法,适用于大多数RGB LED控制场景(非硬件特定版本)。每个算法都包含可调节参数,代码设计为独立函数形式,便于集成到不同项目中:
```c
#include <stdint.h>
#include <math.h>
// 颜色结构体(通用RGB格式)
typedef struct {
uint8_t r;
uint8_t g;
uint8_t b;
} RGBColor;
// 1. 呼吸灯效果(单色)
void breathEffect(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed, RGBColor color) {
static uint8_t brightness = 0;
static int8_t direction = 1;
brightness += direction * speed;
if(brightness >= 255 - speed) direction = -1;
if(brightness <= speed) direction = 1;
for(int i=0; i<numLeds; i++) {
leds[i].r = (color.r * brightness) >> 8;
leds[i].g = (color.g * brightness) >> 8;
leds[i].b = (color.b * brightness) >> 8;
// 2. 彩虹波浪效果
void rainbowWave(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed) {
*phase += speed;
uint8_t hue = *phase + (i * 255 / numLeds);
hsv2rgb(hue, 255, 255, &leds[i].r, &leds[i].g, &leds[i].b);
// 3. 跑马灯效果(可调宽度)
void runningDot(RGBColor* leds, int numLeds, uint8_t* position, uint8_t speed, uint8_t width, RGBColor color) {
*position = (*position + speed) % numLeds;
uint8_t distance = abs((int)(*position) - i);
if(distance > width) {
leds[i] = (RGBColor){0,0,0};
} else {
uint8_t intensity = 255 - (distance * 255 / width);
leds[i].r = (color.r * intensity) >> 8;
leds[i].g = (color.g * intensity) >> 8;
leds[i].b = (color.b * intensity) >> 8;
// 4. 颜色渐变过渡
void colorTransition(RGBColor* leds, int numLeds, uint8_t* phase,
RGBColor start, RGBColor end, uint8_t step) {
*phase = (*phase + step) % 255;
leds[i].r = start.r + ((end.r - start.r) * *phase) / 255;
leds[i].g = start.g + ((end.g - start.g) * *phase) / 255;
leds[i].b = start.b + ((end.b - start.b) * *phase) / 255;
// 5. 随机流星效果
void meteorShower(RGBColor* leds, int numLeds, uint8_t* pos, uint8_t speed,
uint8_t tailLength, RGBColor color) {
static uint8_t trail[64] = {0}; // 最大支持64长度拖尾
// 移动流星位置
*pos = (*pos + speed) % (numLeds + tailLength);
// 生成拖尾数据
for(int i=0; i<tailLength; i++) {
trail[i] = (255 * (tailLength - i)) / tailLength;
// 应用效果
int trailIndex = i - (*pos - tailLength);
if(trailIndex >=0 && trailIndex < tailLength) {
uint8_t intensity = trail[trailIndex];
} else {
// 6. 音频频谱风格效果
void spectrumAnalyzer(RGBColor* leds, int numLeds, uint8_t* heights,
uint8_t decay, RGBColor color) {
// 模拟随机输入数据(实际使用时替换为真实音频数据)
if(rand()%20 == 0 && heights[i] < 240) heights[i] += 15;
// 高度衰减
if(heights[i] > decay) heights[i] -= decay;
else heights[i] = 0;
// 绘制柱状图
leds[i].r = (i < heights[i]/10) ? color.r : 0;
leds[i].g = (i < heights[i]/10) ? color.g : 0;
leds[i].b = (i < heights[i]/10) ? color.b : 0;
// 7. 火焰模拟效果
void fireEffect(RGBColor* leds, int numLeds, uint8_t* heat, uint8_t cooling, uint8_t sparking) {
// 生成随机火花
if(rand()%255 < sparking) {
heat[i] = 255;
// 热量扩散
for(int i=numLeds-1; i>=2; i--) {
heat[i] = (heat[i-1] + heat[i-2] + heat[i-2])/3;
// 应用颜色映射
uint8_t temp = heat[i];
leds[i].r = temp;
leds[i].g = temp/3;
leds[i].b = temp/10;
// 冷却
if(heat[i] >= cooling) heat[i] -= cooling;
else heat[i] = 0;
// 8. 双色交替扫描
void dualScan(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed,
RGBColor color1, RGBColor color2) {
static uint8_t direction = 0;
*phase += speed;
if(*phase >= numLeds) {
*phase = 0;
direction = !direction;
if((direction && (i < *phase)) || (!direction && (i >= numLeds - *phase))) {
leds[i] = color1;
} else {
leds[i] = color2;
// 9. 星光闪烁效果
void starTwinkle(RGBColor* leds, int numLeds, uint8_t* states, uint8_t fadeSpeed) {
if(states[i] == 0 && rand()%1000 == 0) {
states[i] = 255; // 随机点亮
if(states[i] > 0) {
leds[i].r = states[i];
leds[i].g = states[i];
leds[i].b = states[i];
if(states[i] > fadeSpeed) states[i] -= fadeSpeed;
else states[i] = 0;
} else {
// 10. 三维立方体效果
void cubeEffect(RGBColor* leds, int numLeds, uint8_t* angle, uint8_t speed,
RGBColor color) {
// 假设LED排列为8x8x8立方体(需要根据实际布局修改坐标计算)
static const uint8_t cubeSize = 8;
*angle += speed;
for(int x=0; x<cubeSize; x++) {
for(int y=0; y<cubeSize; y++) {
for(int z=0; z<cubeSize; z++) {
int index = x + y*cubeSize + z*cubeSize*cubeSize;
uint8_t intensity =
(sin8(x*32 + *angle) +
sin8(y*32 + *angle/2) +
sin8(z*32 + *angle/3)) / 3;
leds[index].r = (color.r * intensity) >> 8;
leds[index].g = (color.g * intensity) >> 8;
leds[index].b = (color.b * intensity) >> 8;
// HSV转RGB辅助函数(优化整数版本)
void hsv2rgb(uint8_t hue, uint8_t sat, uint8_t val,
uint8_t* r, uint8_t* g, uint8_t* b) {
uint8_t region, remainder;
uint8_t p, q, t;
if(sat == 0) {
*r = *g = *b = val;
return;
region = hue / 43;
remainder = (hue - (region * 43)) * 6;
p = (val * (255 - sat)) >> 8;
q = (val * (255 - ((sat * remainder) >> 8))) >> 8;
t = (val * (255 - ((sat * (255 - remainder)) >> 8))) >> 8;
switch(region) {
case 0: *r = val; *g = t; *b = p; break;
case 1: *r = q; *g = val; *b = p; break;
case 2: *r = p; *g = val; *b = t; break;
case 3: *r = p; *g = q; *b = val; break;
case 4: *r = t; *g = p; *b = val; break;
default: *r = val; *g = p; *b = q; break;
// 正弦查表函数(0-255输入,0-255输出)
uint8_t sin8(uint8_t theta) {
static const uint8_t sineTable[] = {
128, 140, 152, 165, 176, 188, 199, 209, 219, 228, 236, 243, 249, 254,
255, 254, 249, 243, 236, 228, 219, 209, 199, 188, 176, 165, 152, 140,
128, 115, 103, 90, 79, 67, 56, 46, 36, 27, 19, 12, 6, 1, 0, 1, 6, 12,
19, 27, 36, 46, 56, 67, 79, 90, 103, 115
return sineTable[theta % 64];
### 使用说明:
1. **数据结构**:
- 使用`RGBColor`结构体存储颜色值
- LED数组按顺序排列,长度由`numLeds`参数指定
2. **状态管理**:
- 带`*phase`参数的效果需要调用者维护状态变量
- 多LED效果(如流星、火焰)需要预先分配状态数组
3. **性能优化**:
- 使用查表法实现三角函数(`sin8`)
- 全部使用整数运算,避免浮点计算
- 可调节的speed参数控制动画速度
4. **典型调用方式**:
```c
int main() {
const int NUM_LEDS = 64;
RGBColor leds[NUM_LEDS];
// 状态变量
uint8_t phase = 0;
uint8_t meteorPos = 0;
uint8_t fireHeat[NUM_LEDS] = {0};
uint8_t starStates[NUM_LEDS] = {0};
while(1) {
// 选择要运行的效果(示例)
fireEffect(leds, NUM_LEDS, fireHeat, 30, 100);
// rainbowWave(leds, NUM_LEDS, &phase, 3);
// meteorShower(leds, NUM_LEDS, &meteorPos, 2, 10, (RGBColor){255,0,0});
// 此处插入实际硬件更新代码
// ws2812_update(leds, NUM_LEDS);
delay_ms(30);
### 扩展建议:
1. **颜色混合**:添加颜色混合函数实现更复杂效果
2. **参数动态调整**:通过外部输入(旋钮、传感器等)实时控制参数
3. **效果组合**:使用多层混合实现组合效果
4. **内存优化**:对于资源受限系统,可减少状态变量数量
5. **时间同步**:使用定时器中断确保稳定的刷新率
这些算法经过模块化设计,可根据具体硬件平台轻松适配,适合从Arduino到嵌入式Linux系统的各种应用场景。
keemee
2025-2-17 03:34
请问流星效果,跟落雪是一样的吗?
wkman
2025-2-17 11:48
各种视觉效果,都是数学问题,哈哈
Lang2i
2025-2-17 15:19
<H1>可以</H1>
WFX777888
2025-2-18 07:13
谢谢分享资料
hbsuntt
2025-3-6 09:43
谢谢分享,学习
qzyhlf
2025-3-7 07:35
各种视觉效果,都是数学问题,哈哈
