..\lvgl\src\widgets\../lv_conf_internal.h(41): error: #5: cannot open source input file "../../lv_conf.h": No such file or directory
# include "../../lv_conf.h" /*Else assume lv_conf.h is next to the lvgl folder*/
..\lvgl\src\widgets\lv_textarea.c: 0 warnings, 1 error
compiling lv_port_fs.c...
compiling lv_port_indev.c...
"..\OBJ\TOUCH.axf" - 121 Error(s), 0 Warning(s).
* Create LED's with different brightness and color
void lv_example_led_1(void)
/*Create a LED and switch it OFF*/
lv_obj_t * led1 = lv_led_create(lv_scr_act());
lv_obj_align(led1, LV_ALIGN_CENTER, -80, 0);
lv_led_off(led1);
/*Copy the previous LED and set a brightness*/
lv_obj_t * led2 = lv_led_create(lv_scr_act());
lv_obj_align(led2, LV_ALIGN_CENTER, 0, 0);
lv_led_set_brightness(led2, 150);
lv_led_set_color(led2, lv_palette_main(LV_PALETTE_RED));
/*Copy the previous LED and switch it ON*/
lv_obj_t * led3 = lv_led_create(lv_scr_act());
lv_obj_align(led3, LV_ALIGN_CENTER, 80, 0);
lv_led_on(led3);
lv_obj_t * ta1 = lv_textarea_create(parent);
lv_obj_set_width(ta1, LV_PCT(100));
lv_textarea_set_one_line(ta1, true);
lv_textarea_set_placeholder_text(ta1, "Click with an encoder to show a keyboard");
