标题: 搞定keil:error C132: : not in formal parameter list [打印本页]
作者: liumei    时间: 2014-4-9 13:40
1:  keil 的一个小错误 error C132: : not in formal parameter list 如果同时调用多个函数C H 文件,当调用某个H 文件,莫名其妙的出错,而且报错非常多。原因:原来是在H文件 函数声明 void init_ADC()时漏了一个小小的“;” 分号。就错了很多地方。。所以每次函数声明时候,copy后,一定要在最后加上分号 ; .。
作者: a110    时间: 2014-7-17 17:41
帮了我的大忙 谢谢
作者: LL951130    时间: 2015-8-7 13:24
#include<stdio.h>
#include<reg51.h>
#include<intrins.h>/*子函数声明*/
void exdelay(void);
void putchar(unsigned int c);
void putstr(unsigned char code *s);
void putsrxy(unsigned char cx,unsigned char cy,unsigned char code *s );
void setcharcgram(unsigned char cindex,unsigned char code *s);
void charursornext(void);
void putimage(unsigned char code *s);
void putsizeimage(unsigned char XSIZE,unsigned charYSIZE,unsigned char code *s) ;
void glcbpos(void);
void charlcbpos(void);
void lcdreset(void);
void delay3ms(void);
void lcdon(void);
void lcoff(void);
void lcgraphon(void);
void lcgraphoff(void);
unsigned char lcdrd(void);
void lcdwd(unsigned char d );
void lcdwc(unsigned char c);
void lcdwaitidle(void);
sbit RSPIN=P3^2;
sbit RWPIN=P3^3;
sbit PEIN=P3^4;
unsigned char CXPOS;
unsigned char CYPOS;
unsigned char GXPOS;
unsigned char GYPOS;
#define USECHAR1CODE 0xffff;
#define USECHAR2CODE 0xfffd;
#define USECHAR3CODE 0xfffb;
#define USECHAR4CODE 0xfff9;
unsigned char code CHAR1CGRAMTAB[]={
0x00,0x0f,
0x00,0x7f,
0x01,0xf0,
0x03,0xc0,
0x07,0x0f,
0x0e,0x3f,
0x1c,0xfe,
0x39,0xfc,
0x33,0xfc,
0x73,0xfe,
0x67,0xff,
0x67,0xe7,
0xcf,0xe3,
0xcf,0xe1,
0xcf,0xe4,
0xc0,0x06
unsigned char code CHAR2CGRAMTAB[]={
0xf0,0x00,
0xfe,0x00,
0x0f,0x80,
0x03,0xc0,
0xf0,0xe0,
0xfc,0x70,
0x7f,0x38,
0x3f,0x9c,
0x3f,0xcc,
0x7f,0xce,
0xff,0xe6,
0xe7,0xe6,
0xc7,0xf3,
0x87,0xff,
0x27,0xff,
0x60,0x03
unsigned char code CHAR3CGRAMTAB[]={
0xc0,0x07,
0xff,0xe7,
0xff,0xe7,
0xcf,0xe7,
0x67,0xe7,
0x67,0xff,
0x73,0xff,
0x33,0xff,
0x39,0xff,
0x1c,0xff,
0x0e,0x3f,
0x07,0x0f,
0x03,0xc0,
0x01,0xf0,
0x00,0x7f,
0x00,0x0f
unsigned char code CHAR4CGRAMTAB[]={
0xe0,0x03,
0xe7,0xf3,
0xe7,0xf3,
0xe7,0xf3,
0xe7,0xe6,
0xff,0xe6,
0xff,0xce,
0xff,0xcc,
0xff,0x9c,
0xff,0x38,
0xfc,0x70,
0xf0,0xe0,
0x03,0xc0,
0x0f,0x80,
0xfe,0x00,
0xf0,0x00
unsigned char codeImg_SUNMAN_128x64[]={};
void main(void )
        lcdreset();
        charlcdfill('');
        puststrxy(2,0,"SMG12864ZK");
        exdelay();
        exdelay();
        putstrxy(0,1,"中文字符图形点阵");
        exdelay();
        exdelay();
        putstrxy(2,2,"液晶显示模块");
        exdelay();
        exdelay();
        putstrxy(0,3,"长沙太阳人SUNMAN");
        exdelay();
        exdelay();
        setcharcgram(0,CHAR1CGRAMTAB);
        setcharcgram(1,CHAR2CGRAMTAB);
        setcharcgram(2,CHAR3CGRAMTAB);
        setcharcgram(3,CHAR4CGRAMTAB);
        CXPOS=4,CYPOS=0;
        putchar(USERCHAR1CODE);
        exdelay();
        putchar(USERCHAR2CODE);
        exdelay();
        CXPOS=4,CYPOS=1;
        putchar(USERCHAR3CODE);
            exdelay();
        putchar(USERCHAR4CODE);
        exdelay();
        exdelay();
        charlcdfill('');
        lcdgraphon();
        GXPOS=0,GYPOS=0;
        putimage(Img__SUNMAN_128x64);
        exdelay();
        exdelay();
        glcdfill(0);
        lcdgraphoff();
void exdelay(void)
unsigned char i,j,k;
_nop_();
_nop_();
i=22;
j=3;
k=227;
do{
do{while(--k);
while(--j);
while(--i);
unsigned char d;
if(c>128)
if((CXPOS&0x1)==1)
lcdwd('');
charcursornext();
charlcdpos();
if((c&0xff00)==0xff00)
c=0xff00-c;
lcdwd(c/256);
charcursornext();
lcdwd(c&0xff);
charcursornext();
charlcdpos();
if((CXPOS&0x1)==1)
d=lcdrd();
charlcdpos();
lcdwd(d);
lcdwd(c);
lcdwd(c);
lcdwd('');
charcursornext();
        unsigned int c;
        while(1);
                c=*s;
                s++;
                if(c==0)brek;
                if(c<128)
                 putchar(c);
                putchar(c*256+*s);
                s++;
void putstrxy(unsigned char cx,unsigned char cy,unsigned char code *s)
  CXPOS=cx;
  CYPOS=cy;
  putstr(s);
        unsigned char i;
        lcdwc(0x34);
        lcdwc(0x02);
        lcdwc(0x30);
        lcdwc((cindex&0x3<<4)|0x40);
        for(i=0;i<32;i++,s++)
lcdwd(*s);
void putsizeimage(unsigned char XSIZE,unsigned char YSIZE,unsigned char code *s)
unsigned char lx,ly,x;
x=GXPOS;
for(ly=0;ly<YSIZE;ly++,GYPOS++)
for(GXPOS=x,lx=0;lx<XSIZE;)
if((GXPOS&0x08)==0)
        glcpos();
lcdwd(*s);
s++;
lx+=8;
GXPOS+=8;
GXPOS=x;
{unsigned char XSIZE,YSIZE;
XSIZE=*s;
s++;
YSIZE=*s;
s++;
putsizeimage(XSIZE,YSIZE,s);
void charlcdpos(void)
unsigned char ddaddr;
CXPOS&=0xf;
ddaddr=CXPOS/2;
if(CYPOS==0)
lcdwc(ddaddr|0x80);
else if(CYPOS==1)
lcdwc(ddaddr|0x90);
else if(CYPOS==2)
lcdwc(ddaddr|0x88);
lcdwc(ddaddr|0x98);
void charcursornext(void)
CXPOS++;
CXPOS&0x0f;
if(CXPOS==0)
CYPOS++;
CYPOS&=0x3;
void lcdreset(void)
lcdwc(0x33);
delay3ms();
lcdwc(0x30);
delay3ms();
lcdwc(0x30);
delay3ms();
lcdwc(0x01);
delay3ms();
lcdon();
void delay3ms(void)
unsigned char i,j;
i=54;
j=199;
do{
while(--j);
while(--i);
void glcdpos(void)
lcdwc(0x36);
lcdwc((GYPOS&0X1f)|0x80);
if(GYPOS>=32)
        lcdwc((GYPOS/16+8)|0x80);
        lcdwc((GYPOS/16)|0x80);
        lcdwc(0x30);
void lcdon(void)
        lcdwc(0x30);
        lcdwc(0x0c);
void lcdoff(void)
        lcdwc(0x30);
        lcdwc(0x08);
void lcdgraphon(void)
        lcdwc(0x36);
        lcdwc(0x30);
void lcdgraphoff(void)
        lcdwc(0x34);
        lcdwc(0x30);
        unsigned char d;
        lcdwaitidle();
        RSPIN=1;
        RWPIN=1;
        EPIN=1;
        _nop_();
        d=P1;
        EPIN=0;
        return d;
void lcdwd(unsigned char d)
        lcdwaitidle();
        P1=d;
        RSPIN=1;
        RWPIN=0;
        EPIN=1;
        _nop_();
        EPIN=0;
        lcdwaitidle();
        P1=c;
        RSPIN=0;
        RWPIN=0;
        EPIN=1;
        _nop_();
        EPIN=0;
        unsigned char i;
        P1=0xff;
        RSPIN=0;
        RWPIN=1;
        EPIN=1;
        for(i=0;i<20;i++)
          if((P1&0X80)!=0x80)break;
        EPIN=0;
能不能看一下为什么这个编译错误么
作者: PatrickShih    时间: 2020-4-20 20:27
太感谢了,真的少了个 ;一堆报错,看来半天
作者: kotorizhehuo    时间: 2020-5-27 21:00
感谢楼主,帮大忙了!
作者: 麻烦死了    时间: 2020-7-21 21:57
真应该给您打个赏
作者: fy666    时间: 2021-6-16 18:53
楼主牛
作者: wyqf    时间: 2022-8-15 11:31
帮大忙了谢谢
作者: mtt661    时间: 2023-7-28 10:26
keil好像是从上往下一条一条编译的,包括#include 如果报错一大堆,从第一个错误开始解决,一般第一个解决了,有可能都解决了。
作者: hhhwudi    时间: 2024-3-4 18:32
帮了我大忙,太感谢了老哥
作者: 无名氏1957    时间: 2024-3-11 05:59
mtt661 发表于 2023-7-28 10:26
keil好像是从上往下一条一条编译的,包括#include 如果报错一大堆,从第一个错误开始解决,一般第一个解决 ...
精辟。的确如此
作者: 临安初雨    时间: 2024-4-17 21:45
真的感谢你
作者: tieq1952    时间: 2024-4-18 06:31
错误C132::不在形式参数列表中
作者: 零点一    时间: 2025-1-1 13:43
tieq1952 发表于 2024-4-18 06:31
错误C132::不在形式参数列表中
兄弟,最后你是怎么解决的,教教我呗
