标题: 51单片机系列 点阵 C语言 proteus [打印本页]
作者: heicad    时间: 2014-6-17 16:09
口/管脚
7/A
0
0
0
1
0
0
0
1
6/B
0
0
1
0
0
0
1
0
5/C
0
1
0
0
0
0
0
0
4/D
1
0
0
0
1
0
0
0
3/E
0
0
0
1
0
0
0
1
2/F
0
0
1
0
0
0
1
0
1/G
0
1
0
0
0
0
0
0
0/DP
1
0
0
0
1
0
0
0
1
2
4
8
1
2
4
8
注意:高7位→低0位,1→1H
l  P0口、P3口是字符码、P2口是显示位控制码。
l  同是共阴极或共阳极用同样的字符代码,若一阴一阳则需要代码反转—用CPL指令。
l  显示位控制码用MOV P2,88H显示最右侧(个位)位,用MOV P2,11H显示最左侧(千位)位。由此可见其它显示代码的表达。CA—Yang,CC—Yin
l  综合显示可以匹配12H或21H等交叉进行。
点阵显示技术与程序特点,点阵的显示测试(各口控制电位)、编码技术(4-1对位)、显示技术(延时)、各口8位扫描字形的2进制与16进制转换与表征,使用数组描述,扫描,数组中的16进制
//点阵扫描数字0移动
#include
#include
uchar code SaoMiaoG[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80,
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar code SaoMiaoD[]={0xFF,0xC3,0xBD,0xBD,0xC3,0xFF,0xFF,0xFF,
0xC3,0xBD,0xBD,0xC3,0xFF,0xFF,0xFF,0xFF,
0xBD,0xBD,0xC3,0xFF,0xFF,0xFF,0xFF,0xC3,
0xBD,0xC3,0xFF,0xFF,0xFF,0xFF,0xC3,0xBD,
0xC3,0xFF,0xFF,0xFF,0xFF,0xC3,0xBD,0xBD,
0xFF,0xFF,0xFF,0xFF,0xC3,0xBD,0xBD,0xC3,
0xFF,0xFF,0xFF,0xC3,0xBD,0xBD,0xC3,0xFF,
0xFF,0xC3,0xBD,0xBD,0xC3,0xFF,0xFF,0xFF};
void  DelayMS(uint x);      //声明后可使得函数在任意之处,否则函数需要在调用之前
  uint i,j;
void main()//显示数字0主程序
proteus{
loop:
i=0,j=0;//
loop1:
P2=~SaoMiaoG[i ];
i++;
  P1=~SaoMiaoD[j];
  j++;
    DelayMS(10);
if(i<64)
goto loop1 ;
goto loop ;
  uchar t;
  while(x--)
  for (t=0;t<120;t++);
