标题: 解决#error This file requires compiler and library support for the ISO C++ 2... [打印本页]
作者: wangyin    时间: 2014-7-30 14:08
#error  This file requires compiler and library support for the ISO C++ 2011 standard. This support is currently experimental, and must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
解决方法:
在工程文件.pro中添加:
QMAKE_CXXFLAGS+=-std=c++0x
或者
QMAKE_CXXFLAGS += -std=gnu++11
作者: qiao1997    时间: 2020-9-14 11:04
姐姐,windows下怎么解决
