标题: Get 565TFT Color From Windows (Small Tool Develop By C#) [打印本页]
作者: xiaojuan    时间: 2014-9-17 22:39
App Face
/*****Form1  Source Code ****************************************/
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace 取颜色
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private int R=255, G=255, B=255;
        private int RU = 5, GU = 6, BU = 5;
        private void Form1_Load(object sender, EventArgs e)
            SetColorToButton();
        private void button2_Click(object sender, EventArgs e)
        private void hScrollBar1_ValueChanged(object sender, EventArgs e)
            SetColorToButton();
        private void hScrollBar2_ValueChanged(object sender, EventArgs e)
            SetColorToButton();
        private void hScrollBar3_ValueChanged(object sender, EventArgs e)
            SetColorToButton();
        private void SetColorToButton()
            int C;
            RU = int.Parse(textBox3.Text.Trim());
            GU = int.Parse(textBox4.Text.Trim());
            BU = int.Parse(textBox5.Text.Trim());
            R = hScrollBar1.Value;
            G = hScrollBar2.Value;
            B = hScrollBar3.Value;
            button1.Text = R.ToString();
            button8.Text = G.ToString();
            button2.Text = B.ToString();
            button2.BackColor = Color.FromArgb(0, 0, B);
            button8.BackColor = Color.FromArgb(0, G, 0);
            button1.BackColor = Color.FromArgb(R, 0, 0);
            textBox1.BackColor = Color.FromArgb(R, G, B);
            textBox2.BackColor = Color.FromArgb(R, G, B);
            textBox1.ForeColor= Color.FromArgb(255-R, 255-G, 255-B);
            textBox2.ForeColor = Color.FromArgb(255 - R, 255 - G, 255 - B);
            textBox1.Text = "WinColor:" + Color.FromArgb(R, G, B).ToString();
            C = 0;
            C = (R * (int)Math.Pow(2, RU) / 256); C <<= GU;
            C += (G * (int)Math.Pow(2, GU) / 256); C <<= BU;
            C+= (B*(int)Math.Pow(2, BU)/256);
            textBox2.Text = "TFT:0x" + C.ToString("X");
        private void timer1_Tick(object sender, EventArgs e)
            if (checkBox1.Checked == true)
                textBox1.BackColor = ColorPickerManager.GetColor(MousePosition.X, MousePosition.Y);
                hScrollBar1.Value = textBox1.BackColor.R;
                hScrollBar2.Value= textBox1.BackColor.G;
                hScrollBar3.Value=textBox1.BackColor.B;
                SetColorToButton();
/**************************Form1 End*********************************************************************/
/*************************GetColor  Class******************************************************************/
using System;
using System.Runtime.InteropServices;
namespace 取颜色
    /// <summary>
    /// 获取当前光标处颜色,win8下wpf测试成功
    /// </summary>
    public static class ColorPickerManager
        /// <summary>
        /// </summary>
        /// <param >鼠标相对于显示器的坐标X</param>
        /// <param >鼠标相对于显示器的坐标Y</param>
        /// <returns></returns>
        public static Color GetColor(int x, int y)
            IntPtr hdc = GetDC(IntPtr.Zero);
            uint pixel = GetPixel(hdc, x, y);
            ReleaseDC(IntPtr.Zero, hdc);
            Color color = Color.FromArgb((int)(pixel & 0x000000FF), (int)(pixel & 0x0000FF00) >> 8, (int)(pixel & 0x00FF0000) >> 16);
            return color;
        [DllImport("gdi32.dll")]
        private static extern bool BitBlt(
        IntPtr hdcDest, // 目标设备的句柄
        int nXDest, // 目标对象的左上角的X坐标
        int nYDest, // 目标对象的左上角的X坐标
        int nWidth, // 目标对象的矩形的宽度
        int nHeight, // 目标对象的矩形的长度
        IntPtr hdcSrc, // 源设备的句柄
        int nXSrc, // 源对象的左上角的X坐标
        int nYSrc, // 源对象的左上角的X坐标
        int dwRop // 光栅的操作值
        private static extern IntPtr CreateDC(
        string lpszDriver, // 驱动名称
        string lpszDevice, // 设备名称
        string lpszOutput, // 无用,可以设定位"NULL"
        IntPtr lpInitData // 任意的打印机数据
        /// <summary>
        /// 获取指定窗口的设备场景
        /// </summary>
        /// <param >将获取其设备场景的窗口的句柄。若为0,则要获取整个屏幕的DC</param>
        /// <returns>指定窗口的设备场景句柄,出错则为0</returns>
        [DllImport("user32.dll")]
        private static extern IntPtr GetDC(IntPtr hwnd);
        /// <summary>
        /// 释放由调用GetDC函数获取的指定设备场景
        /// </summary>
        /// <param >要释放的设备场景相关的窗口句柄</param>
        /// <param >要释放的设备场景句柄</param>
        /// <returns>执行成功为1,否则为0</returns>
        private static extern Int32 ReleaseDC(IntPtr hwnd, IntPtr hdc);
        /// <summary>
        /// 在指定的设备场景中取得一个像素的RGB值
        /// </summary>
        /// <param >一个设备场景的句柄</param>
        /// <param >逻辑坐标中要检查的横坐标</param>
        /// <param >逻辑坐标中要检查的纵坐标</param>
        /// <returns>指定点的颜色</returns>
        private static extern uint GetPixel(IntPtr hdc, int nXPos, int nYPos);
/************************************End Get Color Class***********************************************************************/
/************************************Form1 Designer Source Code*************************************************************/
namespace 取颜色
    partial class Form1
        /// <summary>
        /// 必需的设计器变量。
        /// </summary>
        private System.ComponentModel.IContainer components = null;
        /// <summary>
        /// 清理所有正在使用的资源。
        /// </summary>
        /// <param >如果应释放托管资源,为 true;否则为 false。</param>
        protected override void Dispose(bool disposing)
            if (disposing && (components != null))
                components.Dispose();
            base.Dispose(disposing);
        #region Windows 窗体设计器生成的代码
        /// <summary>
        /// 设计器支持所需的方法 - 不要
        /// 使用代码编辑器修改此方法的内容。
        /// </summary>
        private void InitializeComponent()
            this.components = new System.ComponentModel.Container();
            this.button1 = new System.Windows.Forms.Button();
            this.hScrollBar1 = new System.Windows.Forms.HScrollBar();
            this.hScrollBar2 = new System.Windows.Forms.HScrollBar();
            this.button8 = new System.Windows.Forms.Button();
            this.hScrollBar3 = new System.Windows.Forms.HScrollBar();
            this.button2 = new System.Windows.Forms.Button();
            this.textBox1 = new System.Windows.Forms.TextBox();
            this.textBox2 = new System.Windows.Forms.TextBox();
            this.textBox3 = new System.Windows.Forms.TextBox();
            this.textBox4 = new System.Windows.Forms.TextBox();
            this.textBox5 = new System.Windows.Forms.TextBox();
            this.checkBox1 = new System.Windows.Forms.CheckBox();
            this.timer1 = new System.Windows.Forms.Timer(this.components);
            this.SuspendLayout();
            // button1
            this.button1.BackColor = System.Drawing.Color.Red;
            this.button1.FlatStyle = System.Windows.Forms.FlatStyle.Popup;
            this.button1.Font = new System.Drawing.Font("楷体", 12.75F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(134)));
            this.button1.ForeColor = System.Drawing.SystemColors.ButtonFace;
            this.button1.Location = new System.Drawing.Point(30, 122);
            this.button1.Name = "button1";
            this.button1.Size = new System.Drawing.Size(94, 33);
            this.button1.TabIndex = 0;
            this.button1.Text = "255";
            this.button1.UseVisualStyleBackColor = false;
            // hScrollBar1
            this.hScrollBar1.Location = new System.Drawing.Point(127, 122);
            this.hScrollBar1.Maximum = 264;
            this.hScrollBar1.Name = "hScrollBar1";
            this.hScrollBar1.Size = new System.Drawing.Size(556, 33);
            this.hScrollBar1.TabIndex = 6;
            this.hScrollBar1.Value = 255;
            this.hScrollBar1.ValueChanged += new System.EventHandler(this.hScrollBar1_ValueChanged);
            // hScrollBar2
            this.hScrollBar2.Location = new System.Drawing.Point(127, 161);
            this.hScrollBar2.Maximum = 264;
            this.hScrollBar2.Name = "hScrollBar2";
            this.hScrollBar2.Size = new System.Drawing.Size(556, 33);
            this.hScrollBar2.TabIndex = 8;
            this.hScrollBar2.Value = 255;
            this.hScrollBar2.ValueChanged += new System.EventHandler(this.hScrollBar2_ValueChanged);
            // button8
            this.button8.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(192)))), ((int)(((byte)(0)))));
            this.button8.FlatStyle = System.Windows.Forms.FlatStyle.Popup;
            this.button8.Font = new System.Drawing.Font("楷体", 12.75F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(134)));
            this.button8.ForeColor = System.Drawing.SystemColors.ButtonFace;
            this.button8.Location = new System.Drawing.Point(30, 160);
            this.button8.Name = "button8";
            this.button8.Size = new System.Drawing.Size(94, 33);
            this.button8.TabIndex = 7;
            this.button8.Text = "255";
            this.button8.UseVisualStyleBackColor = false;
            // hScrollBar3
            this.hScrollBar3.Location = new System.Drawing.Point(127, 197);
            this.hScrollBar3.Maximum = 264;
            this.hScrollBar3.Name = "hScrollBar3";
            this.hScrollBar3.Size = new System.Drawing.Size(556, 33);
            this.hScrollBar3.TabIndex = 10;
            this.hScrollBar3.Value = 255;
            this.hScrollBar3.ValueChanged += new System.EventHandler(this.hScrollBar3_ValueChanged);
            // button2
            this.button2.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(192)))));
            this.button2.FlatStyle = System.Windows.Forms.FlatStyle.Popup;
            this.button2.Font = new System.Drawing.Font("楷体", 12.75F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(134)));
            this.button2.ForeColor = System.Drawing.SystemColors.ButtonFace;
            this.button2.Location = new System.Drawing.Point(30, 197);
            this.button2.Name = "button2";
            this.button2.Size = new System.Drawing.Size(94, 33);
            this.button2.TabIndex = 9;
            this.button2.Text = "255";
            this.button2.UseVisualStyleBackColor = false;
            // textBox1
            this.textBox1.Font = new System.Drawing.Font("宋体", 15F);
            this.textBox1.Location = new System.Drawing.Point(30, 39);
            this.textBox1.Name = "textBox1";
            this.textBox1.Size = new System.Drawing.Size(653, 30);
            this.textBox1.TabIndex = 11;
            this.textBox1.TextAlign = System.Windows.Forms.HorizontalAlignment.Center;
            // textBox2
            this.textBox2.Font = new System.Drawing.Font("宋体", 15F);
            this.textBox2.Location = new System.Drawing.Point(190, 75);
            this.textBox2.Name = "textBox2";
            this.textBox2.Size = new System.Drawing.Size(493, 30);
            this.textBox2.TabIndex = 12;
            this.textBox2.TextAlign = System.Windows.Forms.HorizontalAlignment.Center;
            // textBox3
            this.textBox3.BackColor = System.Drawing.Color.Red;
            this.textBox3.Font = new System.Drawing.Font("宋体", 15F);
            this.textBox3.ForeColor = System.Drawing.Color.Black;
            this.textBox3.Location = new System.Drawing.Point(30, 75);
            this.textBox3.Name = "textBox3";
            this.textBox3.Size = new System.Drawing.Size(42, 30);
            this.textBox3.TabIndex = 13;
            this.textBox3.Text = "5";
            this.textBox3.TextAlign = System.Windows.Forms.HorizontalAlignment.Center;
            // textBox4
            this.textBox4.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(192)))), ((int)(((byte)(0)))));
            this.textBox4.Font = new System.Drawing.Font("宋体", 15F);
            this.textBox4.Location = new System.Drawing.Point(82, 75);
            this.textBox4.Name = "textBox4";
            this.textBox4.Size = new System.Drawing.Size(42, 30);
            this.textBox4.TabIndex = 14;
            this.textBox4.Text = "6";
            this.textBox4.TextAlign = System.Windows.Forms.HorizontalAlignment.Center;
            // textBox5
            this.textBox5.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(192)))));
            this.textBox5.Font = new System.Drawing.Font("宋体", 15F);
            this.textBox5.Location = new System.Drawing.Point(133, 75);
            this.textBox5.Name = "textBox5";
            this.textBox5.Size = new System.Drawing.Size(42, 30);
            this.textBox5.TabIndex = 15;
            this.textBox5.Text = "5";
            this.textBox5.TextAlign = System.Windows.Forms.HorizontalAlignment.Center;
            // checkBox1
            this.checkBox1.AutoSize = true;
            this.checkBox1.Font = new System.Drawing.Font("宋体", 13F);
            this.checkBox1.ForeColor = System.Drawing.Color.Black;
            this.checkBox1.Location = new System.Drawing.Point(30, 12);
            this.checkBox1.Name = "checkBox1";
            this.checkBox1.Size = new System.Drawing.Size(63, 22);
            this.checkBox1.TabIndex = 16;
            this.checkBox1.Text = "捕捉";
            this.checkBox1.UseVisualStyleBackColor = true;
            // timer1
            this.timer1.Enabled = true;
            this.timer1.Interval = 10;
            this.timer1.Tick += new System.EventHandler(this.timer1_Tick);
            // Form1
            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 12F);
            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
            this.AutoSizeMode = System.Windows.Forms.AutoSizeMode.GrowAndShrink;
            this.BackColor = System.Drawing.Color.FromArgb(((int)(((byte)(49)))), ((int)(((byte)(112)))), ((int)(((byte)(111)))));
            this.ClientSize = new System.Drawing.Size(718, 262);
            this.Controls.Add(this.checkBox1);
            this.Controls.Add(this.textBox5);
            this.Controls.Add(this.textBox4);
            this.Controls.Add(this.textBox3);
            this.Controls.Add(this.textBox2);
            this.Controls.Add(this.textBox1);
            this.Controls.Add(this.hScrollBar3);
            this.Controls.Add(this.button2);
            this.Controls.Add(this.hScrollBar2);
            this.Controls.Add(this.button8);
            this.Controls.Add(this.hScrollBar1);
            this.Controls.Add(this.button1);
            this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Fixed3D;
            this.MaximizeBox = false;
            this.Name = "Form1";
            this.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen;
            this.Text = "实用TFT颜色助手V1.0    From:童";
            this.Load += new System.EventHandler(this.Form1_Load);
            this.ResumeLayout(false);
            this.PerformLayout();
        #endregion
        private System.Windows.Forms.Button button1;
        private System.Windows.Forms.HScrollBar hScrollBar1;
        private System.Windows.Forms.HScrollBar hScrollBar2;
        private System.Windows.Forms.Button button8;
        private System.Windows.Forms.HScrollBar hScrollBar3;
        private System.Windows.Forms.Button button2;
        private System.Windows.Forms.TextBox textBox1;
        private System.Windows.Forms.TextBox textBox2;
        private System.Windows.Forms.TextBox textBox3;
        private System.Windows.Forms.TextBox textBox4;
        private System.Windows.Forms.TextBox textBox5;
        private System.Windows.Forms.CheckBox checkBox1;
        private System.Windows.Forms.Timer timer1;
/************************************End Form1 Designer Source Code*************************************************************/
