16*16动态点阵程序-汇编语言
daniu
2014-12-26 23:30
16*16动态点阵程序-汇编语言
LJMP MAIN;
ORG 0030H;
MAIN:
MOV R1,#00H;选择数据指针入口标志
MOV R2,#10H;列选线
MOV R5,#00H;寻字节显示
MOV R3,#00H;R3用于记录某一静态状态重复扫描次数,若到了100,则向右移动一位格。
MOV R4,#00H;R4用于记录移动的格数,这里R4暂时只能在0-255之间变化。
MOV DPTR,#MING;
DISPLAY:DEC R2;
MOV P1,R2;列选线
CJNE R2,#000H,LOOP1;
MOV R2,#010H;
;MOV R5,#00H;放在这里文字会有重影
LOOP1:MOV A,R5;
ADD A,R4;************************************这样最多只能显示8个文字,因为A只有8位。
MOVC A,@A+DPTR;
MOV P0,A;
INC R5;
MOV A,R5;
MOVC A,@A+DPTR;
MOV P2,A;
INC R5;
CJNE R2,#010H,LOOP2;
MOV R5,#00H;
LOOP2:INC R3;**************************************
CJNE R3,#0005H,LOOP0;调节R3的最大值可以改变文字滚动速度。
INC R4;
CJNE R4,#070H,LOOP0;这里的#10H是代表存的文字个数,两个文字的话就是#20H,实际上就是一个字移动16格。
MOV R4,#00H;
INC R1;
CJNE R1,#01H,LOOP5;
MOV DPTR,#MING;
LJMP LOOP0;
LOOP5:CJNE R1,#02H,LOOP6;
MOV DPTR,#Q;
LJMP LOOP0;
LOOP6:CJNE R1,#03H,LOOP0;
MOV DPTR,#Q2;
MOV R1,#00H;
LOOP0:LCALL DELAY;
LJMP DISPLAY;
DELAY:MOV R6,#090H;调节R6的值也可以改变文字滚动速度
DJNZ R6,$;
RET;
MING:
;空格
DB 000H,000H,000H,000H,000H,000H,000H,000H
;欢 CBBB6
DB 028H,004H,024H,008H,022H,032H,021H,0C2H
DB 026H,0C2H,038H,034H,004H,004H,018H,008H
DB 0F0H,030H,017H,0C0H,010H,060H,010H,018H
DB 014H,00CH,018H,006H,010H,004H,000H,000H
;迎 CD3AD
DB 002H,002H,082H,004H,073H,0F8H,020H,004H
DB 000H,002H,03FH,0E2H,020H,042H,040H,082H
DB 040H,002H,03FH,0FAH,020H,002H,020H,042H
DB 020H,022H,03FH,0C2H,000H,002H,000H,000H
;乘 CB3CB
DB 010H,044H,014H,044H,054H,088H,054H,088H
DB 05FH,0D0H,050H,030H,050H,060H,07FH,0FEH
DB 050H,040H,090H,020H,09FH,0B0H,092H,098H
DB 094H,08CH,034H,088H,011H,080H,000H,000H
;坐 CD7F8
DB 000H,082H,001H,002H,006H,022H,038H,022H
DB 004H,022H,003H,022H,000H,022H,0FFH,0FEH
DB 000H,0A2H,001H,022H,002H,022H,03CH,022H
DB 002H,022H,001H,002H,000H,002H,000H,000H
;本 CB1BE
DB 010H,010H,010H,010H,010H,020H,010H,040H
DB 010H,0A0H,013H,020H,01CH,020H,0FFH,0FEH
DB 018H,020H,016H,020H,011H,020H,010H,0C0H
DB 010H,060H,010H,030H,010H,020H,000H,000H
;车 CB3B5
DB 000H,020H,020H,020H,021H,020H,023H,020H
DB 025H,020H,039H,020H,0E1H,020H,021H,020H
DB 02FH,0FFH,021H,020H,021H,020H,021H,020H
DB 021H,020H,021H,020H,000H,020H,000H,000H
DB 000H,000H,000H,000H,01FH,000H,03FH,0ECH
DB 03FH,0ECH,01FH,000H,000H,000H,000H,000H
;上面8个字
;下面8个字
Q:
;请 CC7EB
DB 002H,000H,042H,000H,032H,000H,023H,0FEH
DB 000H,004H,044H,008H,055H,0FFH,055H,050H
DB 055H,050H,0FDH,050H,055H,052H,055H,051H
DB 055H,0FEH,044H,000H,004H,000H,000H,000H
;携 CD0AF
DB 008H,020H,008H,022H,008H,041H,0FFH,0FFH
DB 009H,000H,008H,001H,03FH,0A2H,0EAH,0ACH
DB 02AH,0B0H,0AAH,0A0H,07FH,0A0H,02AH,0AAH
DB 02AH,0B9H,02AH,0A9H,020H,08EH,000H,000H
;带 CB4F8
DB 001H,000H,026H,000H,024H,000H,024H,0FCH
DB 0FCH,080H,024H,080H,024H,080H,0FFH,0FFH
DB 024H,080H,024H,088H,024H,084H,0FCH,0F8H
DB 025H,000H,026H,000H,024H,000H,000H,000H
;好 CBAC3
DB 008H,001H,008H,0C2H,00FH,044H,0F8H,028H
DB 008H,030H,00FH,0CEH,001H,004H,041H,000H
DB 041H,002H,041H,001H,04FH,0FEH,051H,000H
DB 061H,000H,041H,000H,001H,000H,000H,000H
;随 CCBE6
DB 07FH,0FFH,044H,020H,04AH,010H,071H,0E2H
DB 042H,004H,033H,0F8H,000H,004H,024H,004H
DB 02FH,0FAH,039H,042H,0E9H,052H,029H,04AH
DB 02FH,0F2H,020H,002H,020H,002H,000H,000H
;身 CC9ED
DB 000H,000H,000H,042H,000H,042H,000H,044H
DB 03FH,0C4H,06AH,048H,0AAH,048H,02AH,050H
DB 02AH,050H,02AH,062H,02AH,061H,03FH,0FEH
DB 000H,0C0H,007H,040H,002H,040H,000H,000H
;物 CCEEF
DB 002H,020H,03CH,020H,008H,040H,0FFH,0FEH
DB 008H,080H,00BH,022H,004H,044H,018H,088H
DB 0F3H,010H,01CH,020H,010H,0C2H,01FH,001H
DB 010H,002H,01FH,0FCH,000H,000H,000H,000H
;品 CC6B7
DB 000H,000H,000H,0FEH,000H,084H,000H,084H
DB 07EH,084H,044H,084H,044H,0FEH,044H,000H
DB 044H,0FEH,044H,084H,044H,084H,07EH,084H
DB 000H,084H,000H,0FEH,000H,000H,000H,000H
Q2:
;空格
;欢 CBBB6
;迎 CD3AD
;下 CCFC2
DB 000H,000H,040H,000H,040H,000H,040H,000H
DB 040H,000H,040H,000H,040H,000H,07FH,0FEH
DB 044H,000H,046H,000H,043H,080H,041H,000H
DB 040H,000H,0C0H,000H,040H,000H,000H,000H
;次 CB4CE
DB 000H,040H,040H,07AH,038H,0C2H,003H,004H
DB 00CH,004H,032H,008H,00CH,010H,0F0H,020H
DB 010H,0C0H,01FH,080H,010H,060H,010H,010H
;乘 CB3CB
;坐 CD7F8
END
