标题: STM32学习手记⑨-RTC实时时钟 [打印本页]
作者: daming 时间: 2014-12-30 00:45
#include "stm32f10x_lib.h"
#include"stdio.h"
vu32 TimeDisplay = 0;
void RCC_Configuration()
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO | RCC_APB2Periph_USART1 , ENABLE); //打开APB2外设
RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR | RCC_APB1Periph_BKP, ENABLE); //使能电源时钟和备份区时钟
void NVIC_Configuration( )
NVIC_InitTypeDef NVIC_InitStructure; //定义一个中断结构体
NVIC_InitStructure.NVIC_IRQChannel = RTC_IRQChannel;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //无抢占式优先级
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //响应优先级为0
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void GPIO_Configuration()
GPIO_InitTypeDef GPIO_InitStructure; //定义GPIO初始化结构体
//--------将USART1 的TX 配置为复用推挽输出 AF_PP---------------------//
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_9; //管脚位置定义,标号可以是NONE、ALL、0至15。
GPIO_InitStructure.GPIO_Speed=GPIO_Speed_2MHz; //输出速度2MHz
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_PP; //推挽输出模式 Out_PP
GPIO_Init(GPIOA,&GPIO_InitStructure); //E组GPIO初始化
//--------将USART1 的RX 配置为浮空输入 IN_FLOATING---------------------//
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_10; //管脚位置定义
//输入模式下配置输出速度无意义
//GPIO_InitStructure.GPIO_Speed=GPIO_Speed_2MHz; //输出速度2MHz
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING; //浮空输入 IN_FLOATING
GPIO_Init(GPIOA,&GPIO_InitStructure); //C组GPIO初始化
void USART1_Configuration( )
USART_InitTypeDef USART_InitStructure; //串口设置恢复默认参数
USART_ClockInitTypeDef USART_ClockInitStructure;
USART_InitStructure.USART_BaudRate = 115200; //波特率115200
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字长8位
USART_InitStructure.USART_StopBits = USART_StopBits_1; //1位停止字节
USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //打开Rx接收和Tx发送功能
USART_Init(USART1, &USART_InitStructure); //初始化
USART_Cmd(USART1, ENABLE); //启动串口
//-----如下语句解决第1个字节无法正确发送出去的问题-----//
USART_ClearFlag(USART1, USART_FLAG_TC); // 清标志
void RTC_Configuration(void)
PWR_BackupAccessCmd(ENABLE); //取消备份区写保护(写保护在每次硬件复位后被使能)
BKP_DeInit(); //备份区恢复默认
RCC_LSEConfig(RCC_LSE_ON); //LSE(外部低速振荡时钟)打开
while(RCC_GetFlagStatus(RCC_FLAG_LSERDY) == RESET); //等待LSE准备就绪
RCC_RTCCLKConfig(RCC_RTCCLKSource_LSE); //将LSE作为RTC时钟
RCC_RTCCLKCmd(ENABLE); //RTC时钟打开
RTC_WaitForSynchro(); //等待RTC寄存器同步
RTC_WaitForLastTask(); //对RTC任何寄存器的操作,都必须在前一次写操作完成后执行
RTC_ITConfig(RTC_IT_SEC, ENABLE); //使能 秒中断
RTC_SetPrescaler(32767); //对RTC时钟分频 32.768K/(32767+1)=1Hz
u8 USART_Scanf(u32 value)
u32 index = 0;
u32 tmp[2] = {0, 0};
while(index < 2)
/* Loop until RXNE = 1 */
while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET);
tmp[index++] = (USART_ReceiveData(USART1));
if((tmp[index - 1] < 0x30) || (tmp[index - 1] > 0x39))
printf("\n\rPlease enter valid number between 0 and 9");
index--;
/* Calculate the Corresponding value */
index = (tmp[1] - 0x30) + ((tmp[0] - 0x30) * 10);
/* Checks */
if(index > value)
printf("\n\rPlease enter valid number between 0 and %d", value);
return 0xFF;
return index;
u32 Time_Regulate(void)
u32 Tmp_HH = 0xFF, Tmp_MM = 0xFF, Tmp_SS = 0xFF;
printf("\r\n==============Time Settings=====================================");
printf("\r\n Please Set Hours");
while(Tmp_HH == 0xFF)
Tmp_HH = USART_Scanf(23);
printf(": %d", Tmp_HH);
printf("\r\n Please Set Minutes");
while(Tmp_MM == 0xFF)
Tmp_MM = USART_Scanf(59);
printf(": %d", Tmp_MM);
printf("\r\n Please Set Seconds");
while(Tmp_SS == 0xFF)
Tmp_SS = USART_Scanf(59);
printf(": %d", Tmp_SS);
/* Return the value to store in RTC counter register */
return((Tmp_HH*3600 + Tmp_MM*60 + Tmp_SS));
void Time_Adjust(void)
RTC_SetCounter(Time_Regulate()); //设置计数值
void Time_Display(u32 TimeVar)
u32 THH = 0, TMM = 0, TSS = 0;
THH = TimeVar/3600; //计算小时
TMM = (TimeVar % 3600)/60;//计算分
TSS = (TimeVar % 3600)% 60; //计算秒
printf("Time: %0.2d:%0.2d:%0.2d\r\n",THH, TMM, TSS);
void Time_Show(void)
while(1) //infinite loop
if(TimeDisplay == 1) //if 1s has passed
Time_Display(RTC_GetCounter()); //display current time
TimeDisplay = 0;
int fputc(int ch, FILE *f) //在源代码中添加fputc函数,可以用printf函数做为调试输出
/* 将Printf内容发往串口 */
USART_SendData(USART1, (u8) ch);
/* 循环,直到传送完成 */
while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
return ch;
int main()
RCC_Configuration();
GPIO_Configuration();
NVIC_Configuration( );
USART1_Configuration();
if (BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5){ //检查是否第一次配置RTC
printf("\r\n\n RTC not yet configured....");
RTC_Configuration();
printf("\r\n RTC configured....");
Time_Adjust();
BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
else{
if(RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET) //检查是否是上电复位
printf("\r\n\n Power On Reset occurred....");
else if(RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET) //检查是否是复位脚复位
printf("\r\n\n External Reset occurred....");
printf("\r\n No need to configure RTC....");
RCC_ClearFlag(); //清除复位标志
Time_Show();
//秒中断函数 ,在 stm32f10x_it.c 里
void RTC_IRQHandler(void)
if(RTC_GetITStatus(RTC_IT_SEC) != RESET) //判断是否是秒中断
RTC_ClearITPendingBit(RTC_IT_SEC); //清除RTC秒中断标志
TimeDisplay = 1; //将标志位置1,代表1s过去
RTC_WaitForLastTask(); //wait until last write operation on RTC regisiters has finished
if(RTC_GetCounter() == 0x00015180) //reset RTC counter when time is 23:59:59
RTC_SetCounter(0x0);
| 欢迎光临 (http://www.51hei.com/bbs/) |
Powered by Discuz! X3.1 |
