单片机逻辑判断实验
liuda
2015-1-21 22:56
单片机逻辑判断实验
是用51hei单片机开发板 电路图详见:
http://www.51hei.com/f/51hei-5.pdf
的数码管部分, 用2个74hc573 锁存,p0口作为数据口 ,p3.6和p3.7分别是段和位的锁存端口.
#include<reg52.h>
uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
sbit D=P3^6;
sbit V=P3^7;
sbit P2_5=P2^5;
sbit P2_6=P2^6;
uchar data a=0,b=0,out;
uchar key_S1(void);
uchar key_S2(void);
void delay(uint k);
void main(void)
b=key_S1();
a=key_S2();
if((a==8)&&(b==5))out=1;
else out=0;
D=1;
P0=SEG7[a];
D=0;
P0=0xff;
V=1;
P0=0xfe;
V=0;
delay(2);
D=1;
P0=SEG7[b];
D=0;
P0=0xff;
V=1;
P0=0xfd;
V=0;
delay(2);
D=1;
if(out==1)P0=0x73;
else P0=0x00;
D=0;
P0=0xff;
V=1;
P0=0xfb;
V=0;
delay(2);
void delay(uint k)
uint i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
uchar key_S1(void)
{uchar data x;
P2=0xff;
if(!P2_5)x=5;
else x=0;
return x;
uchar key_S2(void)
{uchar data y;
P2=0xff;
if(!P2_6)y=8;
else y=0;
return y;
18246288682
2015-4-14 22:49
感谢分享
