单片机枚举类型实验
liuda
2015-1-21 23:14
单片机枚举类型实验
是用51hei单片机开发板 电路图详见:
http://www.51hei.com/f/51hei-5.pdf
的数码管部分, 用2个74hc573 锁存,p0口作为数据口 ,p3.6和p3.7分别是段和位的锁存端口.P2口上面是按键
#include<reg52.h>
uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar code ACT[4]={0xfe,0xfd,0xfb,0xf7};
sbit D=P3^6;
sbit V=P3^7;
void delay(uint k);
enum week_day{mon=1,tue,wed,thu,fri,sat,sun};
enum week_day day;
void key_scan(void)
{uchar temp;
P2=0xff;
temp=P2;
if(temp!=0xff)
switch(temp)
case 0xef:day=mon;break;
case 0xdf:day=tue;break;
case 0xcf:day=wed;break;
case 0xbf:day=thu;break;
case 0xaf:day=fri;break;
case 0x9f:day=sat;break;
case 0x8f:day=sun;break;
default:break;
void main(void)
for(;;)
key_scan();
D=1;P0=SEG7[day];D=0;P0=0xff;V=1;P0=ACT[3];V=0;delay(300);
void delay(uint k)
uint data i,j;
for(i=0;i<k;i++){
for(j=0;j<121;j++)
linnyshow
2020-3-6 13:53
挺详细的……
