无字库12864液晶屏滚动显示程序
huxiao
2015-1-24 15:23
无字库12864液晶屏滚动显示程序
同志们,做实验的时候一定要把端口重新设置成和你的实际硬件一样,不要说我是骗人的,着东西可编了我3个多小时,绝对没问题!记得P0口加上拉,或者用其他端口,如果不显示,参照《
12864及1602液晶的驱动指南
》,如果还不行,联系本人,
这是个静态图片,大家看看,绝对真实!
#include<reg52.h>
#include<intrins.h>
#include<absacc.h>
#define Lcd_Bus P0 //MCU P0<------> LCM
#define Disp_On 0x3f//开显示
#define Disp_Off 0x3e//关显示
#define Col_Add 0x40//列地址
#define Page_Add 0xb8//页地址
#define Start_Line 0xc0//起始页
sbit cs1=P2^3; //Master chip enable
sbit cs2=P2^4; //Slave chip enable
sbit Enable=P2^2; // mode Enable single
sbit Di=P2^0; //Data or Instrument Select
sbit RW=P2^1; //Write or Read
sbit Lcd_Rst=P2^5; //Lcm reset
字模,此字体下对应的
点阵为:宽x高=16x16
unsigned char code Chinese_character[][32]=
{0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xF2,0x02,0x00 ,
0x00,0x7F,0x28,0x24,0x22,0x21,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00},/*"西",0*/
{0x80,0x90,0x8C,0x84,0x84,0xF4,0xA5,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x84,0x00,
0x80,0x80,0x80,0x40,0x47,0x28,0x28,0x10,0x28,0x24,0x43,0xC0,0x40,0x00,0x00,0x00},/*"安",1*/
{0x00,0x42,0x62,0x5A,0xC6,0x10,0x54,0x54,0x54,0xFF,0x54,0x54,0x7C,0x10,0x10,0x00,
0x40,0x23,0x14,0x08,0x17,0x28,0x29,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x40,0x00},/*"建",2*/
{0x10,0x48,0x47,0xCC,0x54,0x44,0x14,0xE8,0x27,0x24,0x2C,0xF4,0x04,0x04,0x04,0x00,
0x10,0x30,0x10,0x0F,0x88,0x48,0x30,0x0F,0x01,0x06,0x00,0x3F,0x40,0x40,0x70,0x00},/*"筑",3*/
{0x10,0x12,0x92,0x72,0xFE,0x51,0x91,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,
0x04,0x02,0x01,0x00,0xFF,0x00,0x04,0x04,0x04,0x02,0x02,0x02,0xFF,0x01,0x01,0x00},/*"科",4*/
{0x08,0x08,0x88,0xFF,0x48,0x28,0x00,0xC8,0x48,0x48,0x7F,0x48,0xC8,0x48,0x08,0x00,
0x01,0x41,0x80,0x7F,0x00,0x40,0x40,0x20,0x13,0x0C,0x0C,0x12,0x21,0x60,0x20,0x00},/*"技",5*/
{0x20,0x20,0x20,0x20,0x20,0x20,0xA0,0x7F,0xA0,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
0x00,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x01,0x06,0x08,0x30,0x60,0xC0,0x40,0x00},/*"大",6*/
{0x40,0x30,0x10,0x12,0x5C,0x54,0x50,0x51,0x5E,0xD4,0x50,0x18,0x57,0x32,0x10,0x00,
0x00,0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x00},/*"学",4*/
{0x00,0x02,0x1C,0xE8,0x00,0x40,0x60,0x58,0x47,0x22,0x20,0x28,0x30,0xE0,0x40,0x00,
0x02,0x02,0x7F,0x00,0x00,0x00,0x7F,0x21,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,0x00},/*"冶",0*/
{0x40,0x40,0x20,0x20,0x50,0x48,0x44,0xC3,0x44,0x48,0x50,0x50,0x20,0x60,0x20,0x00,
0x40,0x40,0x42,0x42,0x4A,0x72,0x42,0x7F,0x42,0x62,0x5A,0x42,0x42,0x40,0x40,0x00},/*"金",1*/
{0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00},/*"工",2*/
{0x10,0x12,0xD2,0xFE,0x91,0x11,0x80,0xBF,0xA1,0xA1,0xA1,0xA1,0xBF,0x80,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00},/*"程",3*/
{0xFE,0x02,0x32,0x4A,0x86,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0x0C,0x04,0x00,
0xFF,0x00,0x02,0x04,0x83,0x41,0x31,0x0F,0x01,0x01,0x7F,0x81,0x81,0x81,0xF1,0x00},/*"院",5*/
{0x10,0x10,0xD0,0xFE,0x50,0x90,0x00,0x10,0x10,0x10,0xD0,0xFE,0x10,0x10,0x10,0x00,
0x08,0x06,0x01,0xFF,0x00,0x01,0x10,0x08,0x04,0x43,0x80,0x7F,0x00,0x00,0x00,0x00},/*"材",0*/
{0x20,0x24,0xA8,0x70,0xFF,0x68,0xA4,0x20,0x42,0x8C,0x00,0x00,0xFF,0x00,0x00,0x00,
0x08,0x06,0x01,0x00,0xFF,0x00,0x01,0x02,0x02,0x03,0x02,0x02,0xFF,0x01,0x01,0x00},/*"料",1*/
{0x00,0x08,0x08,0x08,0xFF,0x08,0x08,0xF8,0x00,0xF8,0x08,0x08,0x08,0xF8,0x00,0x00,
0x40,0x20,0x18,0x07,0x00,0x20,0x40,0x3F,0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00},/*"加",2*/
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00},/*"工",4*/
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00},/*"程",5*/
unsigned char code E[][16]=
{0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00},/*"C",0*/
{0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00},/*"r",1*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20},/*"a",2*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00},/*"s",3*/
{0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00},/*"y",4*/
{0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00},/*"b",5*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00},/*"o",6*/
{0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00},/*"y",7*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00},/*"e",8*/
/***********************延时子程序***********************/
void delay(unsigned int k)
unsigned int i;
unsigned int j;
for(i=0;i<k;i++)
for(j=0;j<20;j++);
/***********************写命令左***********************/
void write_cmd_1(unsigned char command)
cs1=1;cs2=0;
Di=0;
RW=0;
Lcd_Bus=command;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************写命令右***********************/
void write_cmd_2(unsigned char command)
cs1=0;cs2=1;
Di=0;
RW=0;
Lcd_Bus=command;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************写数据左***********************/
void write_data_1(unsigned char dis_data)
cs1=1;cs2=0;
Di=1;
RW=0;
Lcd_Bus=dis_data;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************写数据右***********************/
void write_data_2(unsigned char dis_data)
cs1=0;cs2=1;
Di=1;
RW=0;
Lcd_Bus=dis_data;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************清内存左***********************/
void clear_1(void)
unsigned char j,k;
cs1=1;cs2=0;
write_cmd_1(Page_Add+0);
write_cmd_1(Col_Add+0);
for(k=0;k<8;k++){
write_cmd_1(Page_Add+k);
for(j=0;j<64;j++)write_data_1(0x00);
/***********************清内存右***********************/
void clear_2(void)
unsigned char j,k;
cs1=0;cs2=1;
write_cmd_2(Page_Add+0);
write_cmd_2(Col_Add+0);
for(k=0;k<8;k++){
write_cmd_2(Page_Add+k);
for(j=0;j<64;j++)write_data_2(0x00);
/***********************显示汉字16*16左************************/
void Chinese_disp_1(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=1;cs2=0;
for(i=0;i<2;i++)
write_cmd_1(Page_Add+pag+i);
write_cmd_1(Col_Add+col);
for(j=0;j<16;j++)
write_data_1(Chinese_character[n][16*i+j]);
/***********************显示汉字16*16右***********************/
void Chinese_disp_2(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=0;cs2=1;
for(i=0;i<2;i++)
write_cmd_2(Page_Add+pag+i);
write_cmd_2(Col_Add+col);
for(j=0;j<16;j++)
write_data_2(Chinese_character[n][16*i+j]);
/***********************显示英文16*8左************************/
void E_disp_1(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=1;cs2=0;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_1(E[n][8*i+j]);
/***********************显示英文16*8右***********************/
void E_disp_2(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=0;cs2=1;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_2(E[n][8*i+j]);
/***********************液晶屏初始化***********************/
void init_lcd()
Lcd_Rst=0;
delay(100);
Lcd_Rst=1;
delay(100);
write_cmd_1(Disp_Off); write_cmd_2(Disp_Off);
write_cmd_1(Page_Add+0); write_cmd_2(Page_Add+0);
write_cmd_1(Start_Line+0); write_cmd_2(Start_Line+0);
write_cmd_1(Col_Add+0); write_cmd_2(Col_Add+0);
write_cmd_1(Disp_On); write_cmd_2(Disp_On);
/***********************LCD显示子程序***********************/
void display(void)
unsigned char i;
for(i=Start_Line;i<0xff;i++)
Chinese_disp_1(0,0, 0);
Chinese_disp_1(0,16,1);
Chinese_disp_1(0,32,2);
Chinese_disp_1(0,48,3);
Chinese_disp_2(0,0, 4);
Chinese_disp_2(0,16,5);
Chinese_disp_2(0,32,6);
Chinese_disp_2(0,48,7);
//西安建筑科技大学
Chinese_disp_1(2,16,8);
Chinese_disp_1(2,32,9);
Chinese_disp_1(2,48,10);
Chinese_disp_2(2,0,11);
Chinese_disp_2(2,16,12);
Chinese_disp_2(2,32,13);
//冶金工程学院
Chinese_disp_1(4,16,14);
Chinese_disp_1(4,32,15);
Chinese_disp_1(4,48,16);
Chinese_disp_2(4,0,17);
Chinese_disp_2(4,16,18);
Chinese_disp_2(4,32,19);
//材料加工工程
E_disp_1(6,24,0);
E_disp_1(6,32,1);
E_disp_1(6,40,2);
E_disp_1(6,48,3);
E_disp_1(6,56,4);
E_disp_2(6,0,5);
E_disp_2(6,8,6);
E_disp_2(6,16,7);
E_disp_2(6,24,8);
//Crasyboye
write_cmd_1(i);
write_cmd_2(i);
delay(3000);//调整滚动速度
//delay(60000);
/***********主程序************/
void main(void)
{ init_lcd();
clear_1();
clear_2();
display();
jxr0345
2015-1-24 22:34
3小时能写出也算是大侠了。谢谢分享
629168335@
2015-3-7 12:50
程序编译不了
曹世鹏
2016-9-29 17:00
来个视频看看呀
阿泽
2019-4-27 22:08
主芯片和从芯片是啥意思啊
zctwss321
2019-4-28 09:39
电路原理呢?大神
zctwss321
2019-4-28 09:42
cs1和cs2管脚啥意思啊?没看懂,老哥
zctwss321
2019-4-28 09:45
写命令左,写命令右都是啥意思啊?啥右左了的
18839723190
2019-4-29 19:35
用的什么字模软件啊,取模方式是什么
yinqing452
2019-9-11 17:25
显示乱码,不知道为什么
