用msp430g2553火箭板做的闹钟
dashu
2015-2-2 22:30
用msp430g2553火箭板做的闹钟
因为我的mp4坏了,手机也不太给力,所以自己想用单片机给自己做个闹钟,51单片机又太垃圾了,32又没有学会,就试着用火箭板给自己做个小小的闹钟。
实习的时候写过闹钟程序,所以一个下午就把程序给写出来了,但其中由于有些缺陷,修改了3个下午才调试完成,虽然有些纰漏,但还是挺满意的。
//这是主函数
#include <msp430g2553.h>
#include "wenben.h"
#include "5110.h"
char t=0,t1=0;
/***********TA初始化*********/
void init_TA()
TACCTL0 = CCIE; // TACCR0 interrupt enabled
TACCR0 = 50150;
TACTL = TASSEL_2 + MC_1; // SMCLK, upmode
/************ADC10初始化************/
void init_ADC10()
ADC10CTL0 = ADC10SHT_3 + ADC10ON + ADC10IE; // /* 4 x ADC10CLKs */ /* ADC10 On/Enable */
/* ADC10 Sampling Rate 0:200ksps / 1:50ksps */
ADC10AE0 |= 0x01; // P2.0 ADC option select
main()
WDTCTL = WDTPW + WDTHOLD;
DCOCTL=CALDCO_1MHZ;
BCSCTL1=CALBC1_1MHZ;
LCD_init(); //初始化LCD模块
LCD_clear(); //清屏幕
init_TA();
Port_Init1();
init_ADC10();
__bis_SR_register(GIE);
P1OUT&=0XfF;
timedisplay();
{ if(t==0)
locktime();
timedisplay1();
Red_Code();
if(t1==0)
LCD_clear(); //清屏幕
Port_Init1();
timedisplay();
datado();
#pragma vector = ADC10_VECTOR //ADC10中断服务
__interrupt void adc_isr(void)
ad_value=ADC10MEM; //将AD采样值存入ad_value
#pragma vector=TIMER0_A0_VECTOR
__interrupt void Timer_A (void)
if(++t==20) //每隔1s计数一次,虽然没有专门的时钟芯片准确,但可以用
t=0;
timechange();
if(++t1==120)
{t1=0;
// wenben.h
//显示字幕数据库
unsigned char zimu[]={
0xF0,0x08,0x08,0x18,0xE0,0x00,0x1F,0x20,0x20,0x30,0x0F,0x00,/*"0",0*/
0x00,0x10,0xF8,0x00,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,/*"1",1*/
0x70,0x08,0x08,0x08,0xF0,0x00,0x30,0x2C,0x22,0x21,0x30,0x00,/*"2",2*/
0x30,0x08,0x88,0x88,0x70,0x00,0x18,0x20,0x20,0x31,0x1E,0x00,/*"3",3*/
0x00,0x80,0x60,0xF0,0x00,0x00,0x06,0x05,0x24,0x3F,0x24,0x04,/*"4",4*/
0xF8,0x08,0x88,0x88,0x08,0x00,0x19,0x21,0x20,0x31,0x1F,0x00,/*"5",5*/
0xE0,0x18,0x88,0x98,0x00,0x00,0x0F,0x31,0x20,0x20,0x1F,0x00,/*"6",6*/
0x38,0x08,0x08,0xE8,0x18,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,/*"7",7*/
0x70,0x88,0x08,0x88,0x70,0x00,0x1E,0x21,0x21,0x21,0x1E,0x00,/*"8",8*/
0xF0,0x08,0x08,0x18,0xE0,0x00,0x01,0x32,0x22,0x31,0x0F,0x00,/*"9",9*/
0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,/*":",10*/
0x80,0x80,0x00,0x80,0x80,0x00,0x20,0x3F,0x21,0x00,0x3F,0x20,/*"n",11*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x3D,0x26,0x22,0x3F,0x20,/*"a",12*/
0x80,0x80,0x00,0x00,0x80,0x80,0x00,0x07,0x38,0x1C,0x03,0x00,/*"v",13*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0x00,0x00,0x00,/*".",14*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",15*/
0xF0,0x98,0x60,0xE0,0x38,0x00,0x00,0x31,0x0E,0x1F,0x33,0x0C,/*"%",16*/
0x00,0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x33,0x00,0x00,0x00,/*"!",17*/
0xF0,0x10,0x08,0x08,0x18,0x00,0x1F,0x20,0x20,0x20,0x10,0x00,/*"C",18*/
0x00,0xC0,0x20,0x20,0xC0,0x00,0x00,0x01,0x02,0x02,0x01,0x00,//0,19//
0x08,0xF8,0x88,0xE8,0x18,0x00,0x20,0x3F,0x20,0x03,0x00,0x00,/*"F",20*/
0x00,0x00,0xF0,0x00,0x00,0x00,0x01,0x01,0x1F,0x01,0x01,0x00,/*"+",21*/
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x00,/*"-",22*/
0x40,0x80,0xF0,0x80,0x40,0x00,0x02,0x01,0x0F,0x01,0x02,0x00,/*"*",23*/
0x00,0x00,0x80,0x70,0x0C,0x00,0x60,0x1C,0x03,0x00,0x00,0x00,/*"/",24*/
0x00,0x00,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x23,0x00,/*"e",25*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x1F,0x20,0xA0,0xFF,0x80,/*"q",26*/
0x40,0x40,0x40,0x40,0x40,0x00,0x04,0x04,0x04,0x04,0x04,0x00,/*"=",27*/
0x00,0x00,0x80,0x80,0x80,0x00,0x00,0x23,0x24,0x24,0x39,0x00,/*"s",28*/
0x80,0x80,0x80,0x80,0x00,0x00,0x80,0xFF,0xA0,0x20,0x1F,0x00,/*"p",29*/
unsigned char hanzi[]=
/*-- 文字: 温 --*/
/*-- 宋体9; 此字体下对应的点阵为:宽x高=12x12 --*/
/*-- 高度不是8的倍数,现调整为:宽度x高度=12x16 --*/
0x22,0x44,0x00,0xC0,0x5F,0xD5,0x55,0xD5,0x5F,0xC0,0x00,0x00,0x04,0x02,0x09,0x0F,
0x08,0x0F,0x08,0x0F,0x08,0x0F,0x08,0x00,
/*-- 文字: 度 --*/
0x00,0xFE,0x0A,0x8A,0xBE,0xAA,0xAB,0xAA,0xBE,0x8A,0x0A,0x00,0x08,0x07,0x00,0x08,
0x09,0x0A,0x04,0x04,0x0A,0x09,0x08,0x00,
/*-- 文字: 华 --*/
0x10,0x08,0x7C,0x03,0x10,0x90,0x3F,0x48,0x44,0x42,0x70,0x00,0x01,0x01,0x01,0x01,
0x01,0x0F,0x01,0x01,0x01,0x01,0x01,0x00,
/*-- 文字: 氏 --*/
0x00,0xFE,0x22,0x22,0x22,0x22,0x7E,0xA1,0x21,0x21,0x20,0x00,0x00,0x0F,0x04,0x02,
0x00,0x00,0x00,0x01,0x02,0x04,0x0F,0x00,
0x00,0x7C,0xC4,0x44,0x7C,0x00,0xFC,0x44,0x44,0xC4,0x04,0x00,0x00,0x3F,0x3F,0x22,
0x11,0x00,0x7F,0x44,0x44,0x43,0x20,0x00,/*"距",4*/
0x00,0x00,0xF8,0x08,0x58,0x2A,0x3C,0x48,0xE8,0x18,0x04,0x00,0x00,0x7C,0x03,0x13,
0x1F,0x13,0x13,0x2B,0x53,0x7E,0x02,0x00,/*"离",5*/
// 5110屏幕的库文件
#define res1 P2OUT|=BIT0; //片选
#define res0 P2OUT&=~BIT0; //片选
#define sce1 P2OUT|=BIT1; //复位,0复位
#define sce0 P2OUT&=~BIT1;
#define dc1 P2OUT|=BIT2; //1写数据,0写指令
#define dc0 P2OUT&=~BIT2;
#define sdin1 P2OUT|=BIT3; //数据
#define sdin0 P2OUT&=~BIT3;
#define sclk1 P2OUT|=BIT4; //时钟
#define sclk0 P2OUT&=~BIT4;
#define led0 P1OUT&=~BIT6;
#define led1 P1OUT&=BIT6;
#define buzz0 P1OUT&=~BIT7;
#define buzz1 P1OUT&=BIT7;
#define CPU_F ((double)1000000)
#define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
#define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
#define uint unsignded int
#define ulong unsignded long
#include <math.h>
LCD_write_byte: 使用SPI接口写数据到LCD
输入参数:dt:写入的数据;
command :写数据/命令选择;
编写日期:20080918
void LCD_write_byte(unsigned char dt, unsigned char command)
unsigned char i;
sce0;
if(command==1)
{dc1; }
else {dc0;}
for(i=0;i<8;i++)
if(dt&0x80)
{sdin1;}
{sdin0;}
dt=dt<<1;
sclk0;
sclk1;
dc1;
sce1;
sdin1;
LCD_init: 3310LCD初始化
编写日期:20080918
void LCD_init(void)
{ P2DIR=0Xff;
P1DIR=0Xff;
P1OUT=0XFF;
res0;
res1;
LCD_write_byte(0x21,0);//初始化Lcd,功能设定使用扩充指令
LCD_write_byte(0xd0,0);//设定液晶偏置电压
LCD_write_byte(0x20,0);//使用基本指令
LCD_write_byte(0x0C,0);//设定显示模式,正常显示
LCD_set_XY: 设置LCD坐标函数
输入参数:X:0-83 Y:0-5
编写日期:20080918
void LCD_set_XY(unsigned char X, unsigned char Y)
LCD_write_byte(0x40 | Y, 0);// column
LCD_write_byte(0x80 | X, 0);// row
LCD_clear: LCD清屏函数
编写日期:20080918
void LCD_clear(void)
unsigned char t;
unsigned char k;
LCD_set_XY(0,0);
for(t=0;t<6;t++)
for(k=0;k<84;k++)
LCD_write_byte(0x00,1);
LCD_write_shu: 显示8(宽)*16(高)点阵列数字字母符号等半角类
输入参数:c:显示的字符;
编写日期:20080918
void LCD_write_shu(unsigned char row, unsigned char page,unsigned char c) //row:列 page:页 dd:字符
unsigned char i;
LCD_set_XY(row*6, page);// 列,页
for(i=0; i<6;i++)
LCD_write_byte(zimu[c*12+i],1);
LCD_set_XY(row*6, page+1);// 列,页
for(i=6; i<12;i++)
void LCD_write_str(unsigned char row,unsigned char page,unsigned char *s)
while (*s)
void LCD_write_shu(unsigned char row,unsigned char page,unsigned char s);
s++;
row++;
//定义全局变量,设置7个闹钟,一个时钟
char flag1;
uchar flag2=0;
int nian=2015;
char time[6]={0,0,0,1,1,0},set=5;
uchar yue[12]={31,28,31,30,31,30,31,31,30,30,31};
char lock[7][3],lockset=3,lockge;
char displaytime[6];
int displaynian;
uchar oclock[7];
uchar oclockon;
//每隔一秒会显示在屏幕上
void timechange(void)
{uchar i;
for(i=0;i<6;i++)
displaytime[i]=time[i];
displaynian=nian;
if(++time[0]>=60)
{time[0]=0;
if(++time[1]>=60)
{time[1]=0;
if(++time[2]>=24)
{time[2]=0;
if(++time[3]==yue[time[4]-1]+1)
{time[3]=1;
if(++time[4]>=13)
{time[4]=1;
nian++;
//定时与当前时间相同,闹钟响起来
void locktime()
{ P1OUT=0X8F;
uchar i;
for(i=0;i<7;i++)
if(time[2]==lock[i][2])
if(time[1]==lock[i][1])
if(oclock[i]==1)
P1OUT=0X7F;
LCD_write_shu(2,2,i);
oclockon=i;
void lockdisplay(void)
{uchar j;
if(flag1==1)
for(j=0;j<2;j++)
if(lock[lockge][j]>=60) lock[lockge][j]=0;
if(lock[lockge][2]>=24) lock[lockge][2]=0;
LCD_write_shu(0,0,19);//
LCD_write_shu(4,2,lock[lockge][2]/10);//c
LCD_write_shu(5,2,lock[lockge][2]%10);//o
LCD_write_shu(6,2,10);//.
LCD_write_shu(7,2,lock[lockge][1]/10);//e
LCD_write_shu(8,2,lock[lockge][1]%10);//d
LCD_write_shu(9,2,10);//f
LCD_write_shu(10,2,lock[lockge][0]/10);//.
LCD_write_shu(11,2,lock[lockge][0]%10);//c
//显示当前时间 完全
void timedisplay(void)
{uchar i;
for(i=0;i<2;i++)
if(time[i]>=60|time[i]<=0) time[i]=0;
if(time[2]>=24|time[2]<=0)time[2]=0;
if(time[3]>yue[time[4]-1]|time[3]<=0)time[3]=1;
if(time[4]>12|time[4]<=0)time[4]=1;
LCD_write_shu(2,0,nian/1000);//
LCD_write_shu(3,0,nian%1000/100);//
LCD_write_shu(4,0,nian%100/10);//c
LCD_write_shu(5,0,nian%10);//o
LCD_write_shu(6,0,15);//.
LCD_write_shu(7,0,time[4]/10);//e
LCD_write_shu(8,0,time[4]%10);//d
LCD_write_shu(9,0,15);//f
LCD_write_shu(10,0,time[3]/10);//.
LCD_write_shu(11,0,time[3]%10);//c
// LCD_write_shu(12,0,15);//n*/
LCD_write_shu(4,2,time[2]/10);//c
LCD_write_shu(5,2,time[2]%10);//o
LCD_write_shu(7,2,time[1]/10);//e
LCD_write_shu(8,2,time[1]%10);//d
LCD_write_shu(10,2,time[0]/10);//.
LCD_write_shu(11,2,time[0]%10);//c
// LCD_write_shu(12,2,15);//n*/
{//进行年月日判断
if(nian%4 !=0) time[5]=0;
else if(nian%400==0) time[5]=0;
else if(nian%4==0) time[5]=1;
if(time[5]==1)yue[1]=29;
if(time[5]==0)yue[1]=28;
//x显示当前时间部分
void timedisplay1(void)
{ uchar i;
if(flag1==0)
for(i=0;i<2;i++)
if(time[2]>=24|time[2]==0)time[2]=0;
if(displaynian!=nian)
if(displaytime[4]!=time[4])
if(displaytime[3]!=time[3])
//红外遥控模块,通过按红外遥控,修改时间或者闹钟,或者显示当前温度
#define KEY_0 0x16 //键0
#define KEY_1 0x0C //键1
#define KEY_2 0x18 //键2
#define KEY_3 0x5E //键3
#define KEY_4 0x08 //键4
#define KEY_5 0x1C //键5
#define KEY_6 0x5A //键6
#define KEY_7 0x42 //键7
#define KEY_8 0x52 //键8
#define KEY_9 0x4A //键9
#define prex 0x44 //电源
#define nex 0x40 //模式
#define play_pause 0x43 //静音
#define ch_ 0x45 //模式
#define ch 0x46
#define cha 0x47 //模式
#define __ 0x07
#define _a 0x15
#define eq 0x09
#define _100a 0x19
#define _200a 0x0d
//红外接收头H1838控制脚,单脚控制
#define RED_IN P1DIR &= ~BIT3 //设置输入,红外接收头接单片机PE3口
#define RED_OUT P1DIR |= BIT3 //设置输出
#define RED_L P1OUT &= ~BIT3 //置低电平
#define RED_H P1OUT |= BIT3 //置高电平
#define RED_R (P1IN & BIT3) //读电平
uchar KEY_VAL=0;
uchar code_value=0;
uchar key_code[4];
int ad_value;
//温度显示,计算100次,误差较小
void datado()
{ long int advalue=0;
uchar i;
int IntDegC, IntDegF ;
for(i=0;i<100;i++)
ADC10CTL0 |= ENC + ADC10SC; // Sampling and conversion start
advalue=advalue+ad_value;
ADC10CTL0 |= ~(ENC + ADC10SC);
ad_value=(advalue/100);
IntDegF = ((ad_value - 630) * 761) / 1024;
IntDegC = ((ad_value - 673) * 423) / 1024;
if(IntDegC>0)
LCD_write_shu(1,4,15);
if(IntDegC<=0)
IntDegC=-IntDegC;
LCD_write_shu(1,4,22);
LCD_write_shu(2,4,IntDegC /10);//
LCD_write_shu(3,4,IntDegC%10);//
LCD_write_shu(4,4,18);//c
LCD_write_shu(5,4,19);//o
LCD_write_shu(6,4,15);//.
if(IntDegF>0)
if(IntDegF<=0)
IntDegF=-IntDegF;
LCD_write_shu(6,4,22);
LCD_write_shu(7,4,IntDegF/10);//e
LCD_write_shu(8,4,IntDegF%10);//d
LCD_write_shu(9,4,20);//f
// MSP430IO口初始化
void Port_Init1()
// LED8DIR = 0xFF; //设置IO口方向为输出
// LED8 = 0xFF; //P2口初始设置为FF
RED_L;
RED_IN;
void switchoclock()
switch(oclock[lockge])
case 0:oclock[lockge]=1;LCD_write_shu(0,2,28);break;
case 1:oclock[lockge]=0;LCD_write_shu(0,2,18);break;
default:break;
void setlockortime(void)
if(flag1==0)
switch(KEY_VAL)
default:break;
case '/':++set;if(set>=7) set=1;break;
case '*':++time[set-1];break;
if(set==6&KEY_VAL=='+')++nian;
if(set==6&KEY_VAL=='-')--nian;
LCD_write_shu(13,2,set);
timedisplay();
if(flag1==1)
switch(KEY_VAL)
default:break;
case '/':++lockset;if(lockset>=4) lockset=1;break;
case '*':++lock[lockge][lockset-1];break;
case 0x40:++lockge;if(lockge>=7)lockge=0;break;
case 0x44:switchoclock();break;
lockdisplay();
LCD_write_shu(13,2,lockset);
LCD_write_shu(13,0,lockge);
if(KEY_VAL>0&KEY_VAL<=9)
switch(oclock[oclockon])
default:break;
case 0:oclock[oclockon]=1;break;
case 1:oclock[oclockon]=0;break;
void startit(void)
switch(flag1)
case 0:flag1=1;;break;
case 1:flag1=0;break;
default:break;
// 遥控器键值赋功能值子程序
void Key_Icode(void)
LCD_write_shu(13,2,15);
LCD_write_shu(0,0,15);
LCD_write_shu(12,4,15);
LCD_write_shu(2,2,15);
LCD_write_shu(13,0,15);
LCD_write_shu(0,2,15);
KEY_VAL=' ';
switch(key_code[2]) //第3个字节是数据,第4个字节是反码
{ //为了更稳定,可以加上第4个字节数据的判断
case KEY_0:KEY_VAL=0; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_1:KEY_VAL=1; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_2:KEY_VAL=2; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_3:KEY_VAL=3; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_4:KEY_VAL=4; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_5:KEY_VAL=5; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_6:KEY_VAL=6; LCD_write_shu(13,4,KEY_VAL); ;break;
case KEY_7:KEY_VAL=7; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_8:KEY_VAL=8; LCD_write_shu(13,4,KEY_VAL); break;
case KEY_9:KEY_VAL=9; LCD_write_shu(13,4,KEY_VAL); break;
case prex: KEY_VAL=0x44; datado();
LCD_write_shu(12,4,29);
LCD_write_shu(13,4,25);
break;
case nex :KEY_VAL=0x40;LCD_write_shu(12,4,11);
break;
case play_pause: datado();
KEY_VAL=0x43;
LCD_write_shu(12,4,28);
LCD_write_shu(13,4,29);break;
case ch_:KEY_VAL='/';LCD_write_shu(13,4,24); break;
case ch: KEY_VAL='='; LCD_init(); //初始化LCD模块
LCD_clear(); //清屏幕
Port_Init1();
P1OUT&=0XfF;
break;
case cha:KEY_VAL='*';LCD_write_shu(13,4,23);break;
case eq: startit();break;
case _a:KEY_VAL='+';LCD_write_shu(13,4,21);;break;
case __:KEY_VAL='-';LCD_write_shu(13,4,22);;break;
case _100a:KEY_VAL=0xa2;LCD_write_shu(12,4,1);
LCD_write_shu(13,4,21); break;
case _200a:KEY_VAL=0xa3;LCD_write_shu(12,4,2);
default:KEY_VAL=10;break;
setlockortime();
// 遥控器解码子程序
void Red_Code()
uchar i,j,k = 0;
for(i = 0;i < 19;i++)
delay_us(400); //延时400us
if(RED_R) //9ms内有高电平,则判断为干扰,退出处理程序
return;
while(!RED_R); //等待9ms低电平过去
for(i=0;i<5;i++) //是否连发码
delay_us(500);
if(!RED_R)
return;
while(RED_R); //等待4.5ms高电平过去
for(i = 0;i < 4;i++) //接收4个字节的数据
for(j = 0;j < 8;j++) //每个字节的数据8位
while(!RED_R); //等待变高电平
while(RED_R) //计算高电平时间
delay_us(100);
k++;
if(k >22) //高电平时间过长,则退出处理程序
return;
code_value>>=1; //接受一位数据
if(k >= 7)
code_value|=0x80; //高电平时间大于0.56,则为数据1
k = 0; //计时清零
key_code[i]=code_value; //四个字节的数据
Key_Icode(); //调用赋值函数
// Display_Key(KEY_VAL); //显示按键值
// delay_ms(5);
神不听
2015-2-23 21:28
请教一下 除了单片机那块板子 做这个闹钟还需要买什么配件啊?键盘吗?
神不听
2015-2-23 21:29
挺急的 要做这个作业不知道做什么好 没啥头绪 觉得楼主这个不错呀
神不听
2015-2-24 22:28
楼主 急啊QAQ
后青春期的诗
2015-4-1 21:18
