标题: 用HSI时钟使步进电机转动的stm32程序 [打印本页]
作者: huge    时间: 2015-2-19 00:45
用HSI时钟使步进电机转动:
#include"stm32f10x_lib.h"
ErrorStatus HSIStartUpStatus;
void NVIC_Configuration(void);
void RCC_Configuration(void);
void TIM2_Configuration(void);
void GPIO_Configuration(void);
#define VECT_TAB_RAM
int main(void)
  #ifdef DEBUG
    debug();/*[初始化外围设备指针]*/
  #endif
  RCC_Configuration(); //初始化时钟与复位
  NVIC_Configuration();//初始化中断嵌套
  TIM2_Configuration();//初始化定时器
  GPIO_Configuration();
  GPIO_WriteBit(GPIOD, GPIO_Pin_7, (BitAction)(0));
  GPIO_WriteBit(GPIOD, GPIO_Pin_6, (BitAction)(0));  //DCY1 DCY2为00,即Normal %0 DECAY
  GPIO_WriteBit(GPIOE, GPIO_Pin_7, (BitAction)(1));
  GPIO_WriteBit(GPIOB, GPIO_Pin_1, (BitAction)(0));  //M1M2为10,即1-2-phase
  GPIO_WriteBit(GPIOA, GPIO_Pin_4, (BitAction)(1));  //正向旋转
  GPIO_WriteBit(GPIOB, GPIO_Pin_0, (BitAction)(0));
  GPIO_WriteBit(GPIOC, GPIO_Pin_5, (BitAction)(1));  //TQ1 TQ2为01,即Current Ratio为50%
  GPIO_WriteBit(GPIOA, GPIO_Pin_7, (BitAction)(1));  //StepReset位
  GPIO_WriteBit(GPIOC, GPIO_Pin_4, (BitAction)(1));  //StepEn 使能位
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_7;   //PA的3.4.7接CLK,CW/CCW,StepReset
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  GPIO_Init(GPIOA,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5 | GPIO_Pin_6;   //PA的6.7接Protect和Mo
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4 | GPIO_Pin_5;   //PC的4.5接StepEn和TQ2
  GPIO_Init(GPIOC,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0 | GPIO_Pin_1;   //PB的0.1接TQ1和M2
  GPIO_Init(GPIOB,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;   //PE7接M1
  GPIO_Init(GPIOE,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6 | GPIO_Pin_7;   //PD的67接DCY2和DCY1
  GPIO_Init(GPIOD,&GPIO_InitStructure);
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel;  //设置TIM2通道输入中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; /*配置优先级组*/
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;      /*允许TIM2全局中断*/
  NVIC_Init(&NVIC_InitStructure);
  TIM_SetCounter( TIM2, 0x0000);
  TIM_ClearFlag(TIM2, TIM_FLAG_Update);        /*清除更新标志位*/
  TIM_ClearITPendingBit(TIM2, TIM_FLAG_Update); //清除TIM2等待中断更新中断标志位
  TIM_ARRPreloadConfig(TIM2, ENABLE);        /*预装载寄存器的内容被立即传送到影子寄存器 */
  TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE); //使能TIM2的更新
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_TimeBaseStructure.TIM_Period = 120;        //设定的最大计数值,计数值到则产生一次中断
  TIM_TimeBaseStructure.TIM_Prescaler = 30;     //分频
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;     // 时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //计数方向向上计数
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_Cmd(TIM2, ENABLE);       //TIM2 enable counter
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                                | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE,ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //在开启时钟里一定要打开TIM2的时钟
void TIM2_IRQHandler(void)
if (TIM_GetITStatus(TIM2, TIM_IT_Update) == SET)
    GPIO_WriteBit(GPIOA,GPIO_Pin_3,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_3)));
作者: 飞蓬    时间: 2015-3-16 11:28
谢谢分享
