标题: 计数器出错 [打印本页]
作者: diangong 时间: 2015-3-21 16:45
标题: 计数器出错
触发一次,跳转好几个数。从网上下的计数程序。 求大侠赐教!涕零感激!
#include "reg52.h"
#define u8 unsigned char
#define u16 unsigned int
sbit sw1=P3^4;
sbit sw2=P3^5;
sbit sw3=P3^6;
sbit e0=P2^0;
sbit e1=P2^1;
sbit e2=P2^2;
sbit e3=P2^3;
u8 ds[4]={0,0,0,0};
u16 num=0;
u8 code table[]={0X3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F,0x00};
u8 ajsm()
static u16 ms;
if(sw3==0)
if(++ms==2)
return 1;
ms=0;
return 0;
void xs()
static u8 a;
a++;
if(a>3)a=0;
e0=1;
e1=1;
e2=1;
e3=1;
P0=table[ds[a]];
switch(a)
case 0:
e0=0;
e1=1;
e2=1;
e3=1;
}break;
case 1:
e0=1;
e1=0;
e2=1;
e3=1;
}break;
case 2:
e0=1;
e1=1;
e2=0;
e3=1;
}break;
case 3:
e0=1;
e1=1;
e2=1;
e3=0;
}break;
TMOD=0x66;
TH0=0xff;
TL0=0xff;
TH1=0xff;
TL1=0xff;
TR1=1;
TR0=1;
ET0=1;
ET1=1;
EA=1;
ds[0]=num/1000%10;
ds[1]=num/100%10;
ds[2]=num/10%10;
ds[3]=num%10;
xs();
if(ajsm())
num=0;
void time0()interrupt 1
if(num<9999)num++;
void time1()interrupt 3
if(num>0)num--;
| 欢迎光临 (http://www.51hei.com/bbs/) |
Powered by Discuz! X3.1 |
