MMA7660FC--重力加速度传感器驱动
xiaos
2015-4-10 16:55
static void I2C_Delay(void)
volatile uint16_t t=0xff;
while(t--);
static void I2C_Start(void)
I2C_SDA_HIGH();
I2C_SCL_HIGH();
I2C_Delay();
I2C_SDA_LOW();
I2C_Delay();
I2C_SCL_LOW();
I2C_Delay();
static void I2C_Stop(void)
I2C_SDA_LOW();
I2C_SCL_HIGH();
I2C_Delay();
I2C_SDA_HIGH();
I2C_Delay();
static uint8_t I2C_WaitAck(void)
uint8_t Ack;
I2C_SDA_HIGH();
I2C_SCL_HIGH();
I2C_Delay();
if(I2C_SDA_Read())
Ack=1;
Ack=0;
I2C_SCL_LOW();
I2C_Delay();
return Ack;
static void I2C_SendAck(void)
I2C_SDA_LOW();
I2C_Delay();
I2C_SCL_HIGH();
I2C_Delay();
I2C_SCL_LOW();
I2C_Delay();
static void I2C_SendNoAck(void)
I2C_SDA_HIGH();
I2C_Delay();
I2C_SCL_HIGH();
I2C_Delay();
I2C_SCL_LOW();
I2C_Delay();
static void I2C_SendByte(uint8_t Byte)
uint8_t Bit;
for(Bit=0;Bit<8;Bit++)
if(Byte&0x80)
I2C_SDA_HIGH();
I2C_SDA_LOW();
Byte<<=1;
I2C_Delay();
I2C_SCL_HIGH();
I2C_Delay();
I2C_SCL_LOW();
I2C_Delay();
static uint8_t I2C_ReceiveByte(void)
uint8_t Bit,Byte=0;
I2C_SDA_HIGH();
I2C_SCL_HIGH();
I2C_Delay();
Byte<<=1;
if(I2C_SDA_Read())
Byte++;
I2C_SCL_LOW();
I2C_Delay();
return Byte;
/******************************MMA7660FC******************/
uint8_t MMA7660_WriteByte(uint8_t Reg,uint8_t Data)//Reg MMA7660的寄存器地址 Data 写进寄存器的值
I2C_Start();
I2C_SendByte(MMA7660_Write);
if(I2C_WaitAck())
return 1;
I2C_SendByte(Reg);
if(I2C_WaitAck())
return 2;
I2C_SendByte(Data);
if(I2C_WaitAck())
return 3;
I2C_Stop();
return 0;
uint8_t MMA7660_ReadByte(uint8_t Reg,uint8_t *pData)
I2C_Start();
I2C_SendByte(MMA7660_Write);//MMA7660 的I2C写地址
if(I2C_WaitAck())
return 1;
I2C_SendByte(Reg);
if(I2C_WaitAck())
return 2;
I2C_Start();
I2C_SendByte(MMA7660_Read);//MMA7660的I2C读地址
if(I2C_WaitAck())
return 3;
*pData=I2C_ReceiveByte();
I2C_SendNoAck();
I2C_Stop();
return 0;
void MMA7660_Check(void)
I2C_Start();
if(I2C_WaitAck())
put_str("mei you hui ying \n");
put_str("you hui ying \n");
I2C_Stop();
void Sys_Init(void)
CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
MMA7660_Init();
USART_Configuration();
uint8_t MMA7660_Configuration(void)
if(MMA7660_WriteByte(0x05,0xff))
return 1;
if(MMA7660_WriteByte(0x06,0x03))
return 2;
if(MMA7660_WriteByte(0x08,0x3c))
return 3;
if(MMA7660_WriteByte(0x09,0xe0))
return 4;
if(MMA7660_WriteByte(0x0a,0x00))
return 5;
if(MMA7660_WriteByte(0x07,0x59))
return 6;
return 0;
//想要获取当前的状态 只需要调用
MMA7660_ReadByte() 读取0x03 地址的数据 读出来的数据中 [4:2]的数据才是有用数据 001 010 101 110 分别代表的是 左 右 下 上 .
