51单片机控制32个LED多花样流水灯程序
das
2015-4-17 21:11
32个led灯接在51单片机的4个p口上面 刚好32个.下面是程序源码:
#include <reg51.h>
#include <intrins.h>
#define ushort unsigned short //P0,P1,P2,P3数据类型是 unsigned short ;数值范围 :0~~~~65 635
ushort code display_P0[]={ //P0 口显示内容
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐个堆积点亮部分的P0 流水点亮
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, //P0 全灭等待
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P0--》P3逐个堆积点亮部分的P0 堆积点亮
0x7E,0x7D,0x7B,0x77,0x6F,0x5F,0x3F,
0x3E,0x3D,0x3B,0x37,0x2F,0x1F,
0x1E,0x1D,0x1B,0x17,0x0F,
0x0E,0x0D,0x0B,0x07,
0x06,0x05,0x03,
0x02,0x01,
0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 闪烁
0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA,0xAA, //P0--》P3间隔点亮部分的P0 1,3,5,7 亮。2,4,6,8灭
0x55,0x55,0x55,0x55,0x55,0x55,0x55,0x55,
0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3从两边到中间逐个点亮部分的P0逐个点亮
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3从两边到中间逐个点亮部分的P0全亮等待
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3从两边到中间逐个熄灭部分的P0全亮等待
0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3从两边到中间逐个熄灭部分的P0逐个熄灭
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0 闪烁//
0xFE,0xFC,0xF8,0xF0,0xE0,0xC0,0x80,0x00, //P0--》P3从左到右逐个点亮部分的P0逐个点亮
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3从左到右逐个点亮部分的P0全亮等待
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //P0--》P3从右到左逐个熄灭部分的P0全亮等待
0x80,0xC0,0xE0,0xF0,0xF8,0xFC,0xFE,0xFF, //P0--》P3从右到左逐个熄灭部分的P0逐个熄灭
ushort code display_P1[]={
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,0x7F,
0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,0x3F,
0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,
0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,0x0F,
0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,
0x06,0x05,0x03,
0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,
0x02,0x01,
0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
ushort code display_P2[]={
0xFF,0xFF,0xFF,
0xFF,0xFF,
0xFF,
0x06,0x05,0x03,
0x02,0x01,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x7F,0x3F,0x1F,0x0F,0x07,0x03,0x01,0x00,
0x01,0x03,0x07,0x0F,0x1F,0x3F,0x7F,0xFF,
ushort code display_P3[]={
0x06,0x05,0x03,
0x02,0x01,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
0x00,0x00,0x00,
0x00,0x00,
0x00,
void delayms(uint ms) //延时子程序
ushort k;
while(ms--)
for(k = 0; k < 50; k++);
void main(void) //P0---》P3 初始状态
ushort i;
P0 = 0xff;
P1 = 0xff;
P2 = 0xff;
P3 = 0xff;
while(1) //定义P0,P1,P2,P3,
for(i=0;i <946; i++)
P0 =display_P0[i];
P1 =display_P1[i];
P2 =display_P2[i];
P3 =display_P3[i];
delayms(50);
l754768458
2015-4-24 19:06
不错挺好的
吉祥宝123
2015-4-24 21:04
楼主 好好
Mr.C
2015-4-24 23:03
感谢分享
孙小数
2015-6-12 18:08
你能把电路图 和 程序发给我么
WDSH
2015-6-21 19:59
求电路图
编程爱好者i
2016-3-19 10:37
这是什么意思呀
Build target '目标 1'
compiling xx.c...
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"xx.obj"
TO "xx"
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 1E57H BYTE (379%) *
Program Size: data=11.0 xdata=0 code=7782
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: E:\\C51\LIB\C51S.LIB (-----)
LIMIT: 0800H BYTES
目标未创建
2861014362
2016-3-19 13:21
不错,赞一个
