独立按键,按下1个独立键盘,LED灯自动加1程序
mafu
2015-5-6 09:58
#include <reg52.h>
uchar num;
sbit key18=P1^4;
sbit D1=P2^0;
uchar code shu[]={ 0xc0,0xf9,0xa4,0xb0, //共阳数码管段码 0,1,2,3
0x99,0x92,0x82,0xf8, //共阳数码管段码 4,5,6,7
0x80,0x90 //共阳数码管段码 8,9,全灭,横杠
void delay(char z)
char x,y;
for(x=100;x>0;x--)
for(y=z;y>0;y--);
P2=0x7f;
P0=0xff;
P1=0xff;
if(key18==0)
delay(5);
if(key18==0)
D1=0;
num++;
if(num==10)
num=0;
P2=0x7f;
P0=shu[num];
while(key18!=1);
delay(5);
while(key18!=1);
D1=1;
