USART test---ATMEGA128
liuqq
2015-5-21 23:36
#include<avr/io.h>
#define fosc 16000000UL //晶振16MHZ
#define baud 9600//波特率
#define com0
void uart0_init(void)
UCSR0B = 0x00; //disable while setting baud rate
UCSR0A = 0x00;
UCSR0C =(1<<UCSZ01)|(1<<UCSZ00);//8bit+1bit stop
UBRR0L=(fosc/16/(baud+1))%256;
UBRR0H=(fosc/16/(baud+1))/256;
UCSR0B =(1<<RXEN0)|(1<<TXEN0);//RXCEN TXCEN
void uart1_init(void)
UCSR1B = 0x00; //disable while setting baud rate
UCSR1A = 0x00;
UCSR1C = (1<<UCSZ11)|(1<<UCSZ10);//8bit+1bit stop
UBRR1L=(fosc/16/(baud+1))%256;
UBRR1H=(fosc/16/(baud+1))/256;
UCSR1B =(1<<RXEN1)|(1<<TXEN1);//RXCEN TXCEN
void putchar0(unsigned char c)
while (!(UCSR0A&(1<<UDRE0)));
UDR0=c;
void putchar1(unsigned char c)
while (!(UCSR1A&(1<<UDRE1)));
UDR1=c;
unsigned char getchar0(void)
while(!(UCSR0A& (1<<RXC0)));
return UDR0;
unsigned char getchar1(void)
while(!(UCSR1A& (1<<RXC1)));
return UDR1;
void puts0(char *s)
while (*s)
putchar0(*s);
s++;
putchar0(0x0a);
putchar0(0x0d);
void puts1(char *s)
while (*s)
putchar1(*s);
s++;
putchar1(0x0a);
putchar1(0x0d);
int main(void)
unsigned char i;
#ifdef com0
uart0_init();
puts0("HELLO!");
#else
uart1_init();
puts1("HELLO!");
#endif
#ifdef com0
if (getchar0()=='t')//按键盘t键开始测试
puts0("test ok!");
for (i=0;i<10;i++)
putchar0(0x30+i);
putchar0(0x0a);
putchar0(0x0d);
#else
if (getchar1()=='t')//按键盘t键开始测试
puts1("test ok!");
for (i=0;i<10;i++)
putchar1(0x30+i);
putchar1(0x0a);
putchar1(0x0d);
#endif
//USART test for atmega128
seabiscuit
2011.12.11.jiujiang
