STM32学习-唯一ID编码
xiongxiao
2015-5-27 16:32
STM32学习-唯一ID编码
完整程序源代码工程文件下载地址:
唯一ID编码 .RAR
(232.68 KB, 下载次数: 15)
2015-5-27 17:25 上传
点击文件名下载附件
下载积分: 黑币 -5
STM32学习日志(19)----唯一ID编码
编译环境: EWARM V5.30
硬件环境: 南京万利 EK-STM32F
STM32 FW: V3.0.0
作者 : szlihongtao
时间 : 2017-07-28
说明 : 1.读取stm32芯片的唯一id码
2.读取stm32芯片的闪存容量寄存器,单位为KB
* @file Project/Template/main.c
* @author MCD Application Team
* @version V3.0.0
* @date 04/06/2009
* @brief Main program body
* @copy
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2009 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_m.h"
/** @addtogroup Template_Project
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval : None
// 延时50ms
static void delay(void)
INT32U i;
static INT32U jjj=5240*50;
for (i=0; i<jjj; i++);
// 时钟设置初始化
static void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
RCC_AdjustHSICalibrationValue 调整内部高速晶振(HSI)校准值
RCC_ITConfig 使能或者失能指定的RCC中断
RCC_ClearFlag 清除RCC的复位标志位
RCC_GetITStatus 检查指定的RCC中断发生与否
RCC_ClearITPendingBit 清除RCC的中断待处理位
/* RCC system reset(for debug purpose) */
// 时钟系统复位
RCC_DeInit();
// 使能外部的8M晶振
// 设置外部高速晶振(HSE)
/* Enable HSE */
RCC_HSEConfig(RCC_HSE_ON);
// 使能或者失能内部高速晶振(HSI)
RCC_HSICmd(DISABLE);
// 等待HSE起振
// 该函数将等待直到HSE就绪,或者在超时的情况下退出
/* Wait till HSE is ready */
HSEStartUpStatus = RCC_WaitForHSEStartUp();
if(HSEStartUpStatus == SUCCESS)
/* HCLK = SYSCLK */
// 设置AHB时钟(HCLK)
RCC_HCLKConfig(RCC_SYSCLK_Div1); // 72 MHz
/* PCLK1 = HCLK/2 */
// 设置低速AHB时钟(PCLK1)
RCC_PCLK1Config(RCC_HCLK_Div2); // 36 MHz
/* PCLK2 = HCLK */
// 设置高速AHB时钟(PCLK2)
RCC_PCLK2Config(RCC_HCLK_Div1); // 72 MHz
/* ADCCLK = PCLK2/8 */
// 设置ADC时钟(ADCCLK)
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
// 设置USB时钟(USBCLK)
// USB时钟 = PLL时钟除以1.5
RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
// 设置外部低速晶振(LSE)
RCC_LSEConfig(RCC_LSE_OFF);
// 使能或者失能内部低速晶振(LSI)
// LSE晶振OFF
RCC_LSICmd(DISABLE);
// 设置RTC时钟(RTCCLK)
// 选择HSE时钟频率除以128作为RTC时钟
RCC_RTCCLKConfig(RCC_RTCCLKSource_HSE_Div128);
// 使能或者失能RTC时钟
// RTC时钟的新状态
RCC_RTCCLKCmd(DISABLE);
/* Flash 2 wait state */
FLASH_SetLatency(FLASH_Latency_2);
/* Enable Prefetch Buffer */
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
/* PLLCLK = 8MHz * 9 = 72 MHz */
// 设置PLL时钟源及倍频系数
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
/* Enable PLL */
// 使能或者失能PLL
RCC_PLLCmd(ENABLE);
/* Wait till PLL is ready */
// 检查指定的RCC标志位设置与否
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
/* Select PLL as system clock source */
// 设置系统时钟(SYSCLK)
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
/* Wait till PLL is used as system clock source */
// 返回用作系统时钟的时钟源
while(RCC_GetSYSCLKSource() != 0x08)
// 使能或者失能AHB外设时钟
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1
|RCC_AHBPeriph_DMA2
|RCC_AHBPeriph_SRAM
|RCC_AHBPeriph_FLITF
|RCC_AHBPeriph_CRC
|RCC_AHBPeriph_FSMC
|RCC_AHBPeriph_SDIO,DISABLE);
// 使能或者失能APB1外设时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_ALL,DISABLE);
// 强制或者释放高速APB(APB2)外设复位
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,ENABLE);
// 退出复位状态
RCC_APB2PeriphResetCmd(RCC_APB2Periph_ALL,DISABLE);
// 强制或者释放低速APB(APB1)外设复位
RCC_APB1PeriphResetCmd(RCC_APB1Periph_ALL,ENABLE);
// 强制或者释放后备域复位
RCC_BackupResetCmd(ENABLE);
// 使能或者失能时钟安全系统
RCC_ClockSecuritySystemCmd(DISABLE);
// GPIO设置
static void GPIO_Configuration(void)
// 使能或者失能APB2外设时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_Init(GPIOD, &GPIO_InitStructure);
// LED5亮
void Led_RW_ON(void)
GPIO_SetBits(GPIOC,GPIO_Pin_4);
// LED5灭
void Led_RW_OFF(void)
GPIO_ResetBits(GPIOC,GPIO_Pin_4);
INT32U un; //闪存容量寄存器
INT32U CpuID[3];
INT32U Lock_Code;
// 主程序
int main(void)
RCC_Configuration();
GPIO_Configuration();
Led_RW_ON();
delay();
Led_RW_OFF();
un=(*( u16 *)0x1FFFF7E0); // 闪存容量寄存器,单位为KB
// 仿真结果为128,与STM32F103VB的型号是一致的
//获取CPU唯一ID
CpuID[0]=*(vu32*)(0x1ffff7e8); // 0XFFFFFF37
CpuID[1]=*(vu32*)(0x1ffff7ec); // 0X31383836
CpuID[2]=*(vu32*)(0x1ffff7f0); // 0X43163562
//加密算法,很简单的加密算法
Lock_Code=(CpuID[0]>>1)+(CpuID[1]>>2)+(CpuID[2]>>3); // X94B0D454
for (;;)
delay();
GPIOC->ODR ^= GPIO_Pin_4; // led5 toogle
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval : None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
LED2---------PC7
LED3---------PC6
LED4---------PC5
LED5---------PC4
KEY2---------PD3
KEY3---------PD4
